Question about Midas Interactive Cue Club & Sergei Bubkas Millennium Games Double Pack PC
Wh cue club game hangs?
Why does it hangs in the middle?
Cue Club Game looks funny on widescreen monitor
I think you need to change the resolution of the game in game settings to suit the resolution of the monitor you are using that wold be the ideal solution.
(but if not, as a temporary workaround you can change the resolution of your monitor, or of your windows. You don't say what windows or monitor you are using so I can't help until I know. It's not an ideal solution as everything else will look wrong, but it is a solution)
Apr 04, 2014 | eGames Cue Club for Windows
Cue Club for Windows 8
Try reinstalling the game and be shure that your video card driver has the latest update.
Jul 06, 2013 | eGames Cue Club for Windows
Cue club running very slow
Follow these steps to fix this problem: WebRepOverall ratingThis site has no rating(not enough votes)
- Scan PC with Anti-virus
- Scan for malwares
- Fix registry errors
- Update graphic drivers that control your PC.
If problem still occurs then use game optimization tool PCFresher.
Dec 10, 2012 | eGames Cue Club for Windows
Error iKernel.exe 0x10000
when u want to unstall it click right an execute the "Setup" as administrator
that work whith me;;
Aug 07, 2012 | eGames Cue Club for Windows
Whenever I try to play International Cue Club, it says, "unable to connect to Internet - No Internet connection". I have disabled my firewall & i am using internet perfectly but gives problem...
i have download the international cue club from torrent but now i have some installation problem. there is no sign of setup through which i can install it on my pc . any one solve that problem please waiting for the reply
Oct 12, 2011 | Video Game Consoles & Games
While i play the game crashes, often during a break.tried downloading patches but that don't even work. Can't even load the game with the patch. Please help!
It is sad but true that cue club doesn't run perfectly with high graphics card. I don't know why. I played cue club without setuping the drivers. IT ran well. But everytime I set up my agp driver it gets crashed. It didn't happen with only one agp card. I changed at least 10-12 AGP and PCI express. In every situation, I can play the game untill I set up my agp.Whenever I set up my agp it always crashes. Nothing actually worked with me
Sep 13, 2011 | eGames Cue Club for Windows
When i want to play cue club game the mouse speed became very very slow but when exit then normal.
Right Click on the Cue Club Icon and click on properties, and a box will appear
image_thumb12.png?imgmax=800
Step 2
Click on the compatibility tab on the box
image_thumb10.png?imgmax=800
Step 3
Check the Run this program ....... box and press OK
image_thumb7.png?imgmax=800
Now You are done Thanks for reading
Feb 14, 2011 | Video Game Consoles & Games
My computer with cue club crashed how do i get it on my new laptop?
i dont know how to play this game...........................................................................................................................
Jan 25, 2011 | eGames Cue Club for Windows
When i open Cue Club in win7 (laptop model-acer aspire 5738z), it opens in a small square screen rather than full square screen. my pc's resolution is set as maximum. can any one suggest how to play the...
Check the in game options of the game itself. Somewhere in there should be a check box option allowing you to choose between full screen and windowed mode.
If there is no option, then find the shortcut to the game, and right click on it. Then click on properties. On the command line (that leads to the actual game file) go to the end and see if it has -window at the end of it. (might look like c:\program files\egames\cue.exe - window) if you see that window part (or win in some cases) then delete that and see if that helps.
Don't forget to Rate :)
Aug 13, 2010 | eGames Cue Club for Windows
Cue Club fails to Launch
Thanks for choosing fixya.I also had the same problem.Just try to get new copy and then install it.
Mar 30, 2009 | eGames Cue Club for Windows
Midas Interactive Cue Club & Sergei Bubkas Millennium Games Double Pack PC Logo
Top Midas Interactive Video Game Consoles & Games Experts
James Wishart
Are you a Midas Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
