Question about Building Materials
How do ya cut plate glass and what tools are recommended?
    Sergeant:
  • 218 Answers
Once you score the glass you snap it off by applying pressure at the score line like your score line is a hinge and you are breaking it free as if it was rusted tight.
Posted on Jun 21, 2015
    New Friend:
    Problem Solver:
  • 7 Answers
Hi,If you want to cut glass left over form old project or somebody gave it to you for what ever reason the first thing you need to do is make sure that the glass is plate glass becouse if you try cutting tempered glass its going to blow in your face.
Usually tempered glass has a stamp somewhere in the corner which proves that is tempered and the company that tempered it. After you know for sure that your glass is plate glass you need:
1.Safety glasses
2.Glass gloves
3.Glass cutter
4.Straight edge
5.Cutting table or flat surface covered with felt or short hair carpet
6.Measuring tape
7.Clamps (to hold your straight edge while you score the surface)
The thing is you dont cut glass,you score it with the cutter and then brake it.Please let me know what kind of glass are you going to cut so I can be more specific.
Posted on Mar 12, 2015
How to clean between glass on whirlpool oven door
Ya gotta take the door off the stove and remove the base plate then get the glass out and clean it; a few years ago I replaced a handle on a oven door and here is how I did it:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 08, 2016 | Whirlpool Ovens
How do u replace the passenger side quarter glass on a 02 Chevy Tahoe LS
First you have to "cut" the old one out. There are a couple of tools to do this. "Piano wire". (its actually a small diameter cable you pull back and forth that cuts the gasket) Blade (pnuematic powered tool that slices through the urethane) Once you have the old glass out, remove all of the old urethane, and apply new urethane. Comes in a tube, pretty much like caulking. Press it in place, put some painters tape all around it so it doesnt slide before the urethane dries and thats it. Sounds easy, and it is if you are in the business. You can get the glass cheap from a salvage yard. If its a nice Tahoe, I would recommend getting Safelite or other glass installer to do it. EZ to scratch up your paint with the wire, and the pnuematic tool will set you back more than the install would cost.
May 22, 2012 | 2002 Chevrolet Tahoe
How do I replace carbon brushes in vax6131
Bend back the three tabs and cut off the contact wire as close to the top tab as possible. You can then pull the brush (or what is left of it) out. The new brushes have a brass plate the same size as the brush opening. The connection wire that you cut away on the original brush is attached to this plate so you don't have to solder the connection. Push the new brush into the holder (you might have to file the carbon slightly to get it in). Then you have to compress the spring so that it all fits into the brush holder (this is difficult) once this is in keep the sping compressed with a small screw driver or other small tool, and bend the three tabs back over the brass plate to hold it in place. Give that a try and let me know how that works for ya.
Jun 11, 2011 | Vacuums
Very very hot saucepan made round mark on granite. Removal?
My mother had this happen to her. What she did was have a carpenter come in and cut out the mark and install a glass "hot" resistant spot. What i would recommend, cut out the burn and install a ceramic that matches the existing granite so that you can place hot items on it.
Jan 29, 2011 | Granite 15 X 10 X 15" Surface Square...
Replace side view mirror 2002 chevy tahoe
Once you've purchased a replacement mirror glass based on your specific make, model and year simply follow the steps below:
  • Remove all existing glass from the mirror head's plastic inner platform (backing plate).
  • Clean backing plate with rubbing alcohol. Clean back of replacement mirror with Burco Window Glo or other glass cleaner.
  • Apply the Burco Redi Stick adhesive patches and or silicone/urethane to the replacement mirror's back or to the backing plate itself.
  • Align and press replacement mirror to the backing plate.
  • Clean the installed Burco Redi Cuts mirror with Burco Window Glo or other urethane-safe glass cleaner.
Oct 09, 2009 | 2002 Chevrolet Tahoe
How do you replace the driver side rear view mirror on a 2007 Toyota Sienna?
  • Clean backing plate with rubbing alcohol. Clean back of replacement mirror with Burco Window Glo® or other glass cleaner.
  • Apply the Burco Redi Stick® adhesive patches and or silicone/urethane to the replacement mirror's back or to the backing plate itself.
  • Clean the installed Burco Redi Cuts® mirror with Burco Window Glo® or other urethane-safe glass cleaner.
Aug 04, 2009 | Toyota Sienna Cars & Trucks
2003 GMC sierra side view mirror glass replacement
That dependso on if the housing itself is broken then yes. If the face plate that is attached to the mirror itself is flapping around then maybe. If it is just the mirror, just go to your neighborhood auto glass shop and but a "Ready-Cut" mirror for a small amount of money. they come already cut to fit perfectly. As for removing the old glass, take a very small flat screw driver and pry the glass away from the face plate. Once completely cleaned out use the adhesive from the ready cut and place them on the face plate. Next press the new mirror onto the flace pate, being careful not to press to hard or it will snap it in half.
Jun 03, 2009 | 2003 GMC Sierra 1500
R/H rear quarter window repalcement
tv is the wrong adhesive. you must use urethane with a primer. it is available at any QUALITY parts store (NAPA or Carquest comes to mind)
Material Item Specification Urethane Metal Primer Essex U-413
WSB-M2G234-C Urethane Glass Prep Essex U-401
WSB-M5B280-C Urethane Glass Primer Essex U-402
WSB-M2G314-B Urethane Adhesive Essex 400-HV
WSB-M2G316
Removal
All vehicles
ani_caut.gif WARNING: To prevent glass splinters from entering the eyes or cutting the hands, wear safety glasses and heavy gloves when cutting the glass from the vehicle.
  1. Remove the C-pillar trim panels. For additional information, refer to Section 501-05.
3-Door, 5-Door
  1. ani_caut.gif CAUTION: Make sure the cutting blades are changed where the cutting depth changes to avoid damage to the body and trim panels.
    NOTE: Some resistance may be encountered when cutting through the glass locating pegs in the lower corners of the glass.
    NOTE: Lubricate the existing urethane adhesive with water to aid the special tool while cutting.
    Using the special tool, place the flat side of the knife against the quarter glass window. Start at the top and work towards the corners cutting to the given maximum depths:
    1. 20 mm
    1. 60 mm
    1. 75 mm
    1. 90 mm
Wagon
    NOTE: Some resistance may be encountered when cutting through the glass locating pegs in the upper right and lower left corners of the glass.
    1. 20 mm
    1. 30 mm
    1. 50 mm
    1. 40 mm
4-Door
    1. 20 mm
    1. 25 mm
    1. 45 mm
    1. 50 mm
    1. 55 mm
    1. 70 mm
    1. 150 mm
All vehicles
  1. Remove the rear quarter window glass.
  1. Using a soft brush or vacuum, remove any dirt or foreign material from the pinch weld.
Installation
ani_caut.gif CAUTION: When installing urethane installed glass parts, the vehicle must not be driven until the urethane adhesive has cured. At temperatures above 21°C (70°F) and relative humidities above 50%, adequate cure time is typically 24 hours. (Refer to Essex drive away chart for the cure times as temperatures and humidity vary.) Inadequate or incorrect curing can adversely affect the retention of the quarter window glass.
  1. NOTE: Avoid scratching the pinch weld.
    Trim the remaining urethane adhesive. The urethane adhesive must be smooth and free of cuts and contamination after trimming. Avoid touching the urethane adhesive after preparation.
  1. Apply the urethane metal primer to any exposed or damaged metal on the pinch weld.
  1. If reinstalling the original rear quarter window glass, remove the excess urethane adhesive.
  1. Clean the rear quarter window glass with a non-alcohol based window cleaner.
  1. ani_caut.gif CAUTION: Wipe off the urethane glass prep immediately after each application because it flash dries.
    If installing a new rear quarter window glass, apply urethane glass prep twice around the glass surface to be urethaned.
  1. If installing a new rear quarter window glass, apply urethane glass primer to the same area that was prepped in the previous step. Allow 5 minutes to dry.
  1. Cut the urethane adhesive applicator tip to specification.
  1. Apply a bead of urethane adhesive on top of the existing urethane bead on the pinch weld. Make sure that all gaps in the urethane adhesive are smoothed into one continuous bead.
  1. Position the rear quarter window glass to the flange, and press the retaining tabs into the flange to engage.
  1. Install the rear quarter window glass.
  1. Check the rear quarter window glass installation for air or water leaks through the urethane seal.
  1. Install the C-pillar trim panels. For additional information, refer to Section 501-05.
May 29, 2009 | 2004 Ford Focus
Windshield removel
First you will need a chrome removal tool KD 2038 or similar. You slide it under the edge of the trim between trim and glass, and slide up or down until you can make contact with clip. This tool will pull the clip back and let the trim pop loose. Now removing the glass. You need to be very careful. I wear a pair of heavy leather gloves while cutting the glass out. I have a Blue Point brand # YA 109A cutter from Snap On but I'm sure you could find it in another brand. You get it worked under the edge of the glass and pull. I guess fine wire like piano wire will work but have never tried it.
You might also find that one of your glass people does a little work on the side and have them drop by and cut it out for you.
Good Luck and be careful
May 05, 2009 | 1984 Chevrolet El Camino
Passenger Side Mirror Glass Discoloring on Bottom Edge
Hi,welcome to fix ya. this is pretty easy heres how click here be sure to heat the glass with a blow dryer first to soften the tabs on the glass . If there is anything else I can help you with let me know .
Apr 01, 2009 | 2004 Acura TL
Building Materials Logo
585 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
