Question about Carrera SHARK/N Sunglasses
<!-- from fixya rte -->How to change the Carrera Shark lenses. - Carrera SHARK/N Sunglasses
I have a new Carrera watch, the day is not shown in English, can it be changed?
Most watches have two dates English and another language. Pull the crown out to the first click and turn it clock wise. this may change the date, if so turn the crown anti clock wise and will change the day. It will click over to English.
Dec 26, 2017 | Carrera Watches
I have a carrera digital wacth for men how can I set the date and time
try pulling the stem out and rotating it . some watches have to be near midnight to change the date .
Jan 24, 2015 | Carrera Watches
I need replacement earpieces for my carrera ca914/s.
The company that owns Carrera does not offer any replacement lenses or part for their sunglasses. I know, you pay that much for the glasses and no service options. You may want to contact the guys at www.sunglassreplacementlenses.com. All they do are lenses and could probably custom make you a new set for reasonable price.
Thanks
May 31, 2011 | Carrera CA 914/S Sunglasses
Have a scratch on one lens. Can this be taken out?
Scratches on lenses are very hard to take out. If they are buffered then it will change and degrade the optics of the lens. There are a few solutions that have been known to remove small and light scratches such as furniture polish, or cd/dvd cleaning solution.
Jan 10, 2011 | Carrera Clothing Accessories
How much does it cost to do an oil change on a porsche 911 carrera 2003
Probably anywhere from $49 to $89 on up depending on which oil change you choose, using full synthetic oil. e.g. Walmart prices.
Maybe at the dealer it's more.
Jul 14, 2010 | 2003 Porsche 911 Carrera
Olio carrera 4s porsche
Usually the specs are located in the owners manual. It tells you the grade and amount of oil required on an oil change. If the specs are not in the owners manual, you can look at the oil fill port on the engine and normally has the recommended grade of oil. Otherwise, see if you can get your hands on a service manual. Good Luck.22
Jun 13, 2009 | 2007 Porsche 911 Carrera S Coupe
I want to do an oil change on my 2006 porsche carrera s
Remove allen key drain bung in centre of flat sump pan to drain oil, then using oil filter removal tool unscrew plastic oil filter housing situated just forward of sump, replace filter and sealing ring/washer. Refill via filler tube 8 litres and run engine till hot. leave for approx 2 mins and check level via instrument cluster (job done and saved £200)
Mar 18, 2009 | 2006 Porsche Carrera
Quickly change date on my Tag Carrera
When yoy pull out the crown you will notice there are two clicks. You have to pull out crown to the first click only and then adjust a date by turning the crown.
Rate me, please.
Mar 13, 2009 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
Carrera SHARK/N Sunglasses Logo
56 people viewed this question
Top Carrera Clothing Accessories Experts
Da Doc
ray gallant
Bill Boyd
Are you a Carrera Clothing Accessory Expert? Answer questions, earn points and help others
