Question about HEALTHRIDER Pro H450i Treadmill HRTL61706
I plug my healthriderpro H 450i into a outlet that had no ground.It work for a little bit but turn off and nothing happens when I hit the reset button.What could be the problem?
Tried another outlet and hit the reset button but nothing happened.
    Novelist:
    Habit-Forming:
  • 144 Answers
Check cable between lower and upper boards :-)
Posted on Jan 10, 2015
  • 9,639 Answers
The ground on the outlet is only for safety reasons. It will not affect the operation of the machine. Check for a fuse on the control board.
Posted on Nov 20, 2014
Plug ins are not working on one whole wall
Is there one of them (maybe even in another room close by) that has two small buttons on the plate that say "test" and "reset"? If so, press the test, then press the reset button. That might set the ground fault interrupter circuit back on. The button should pop out when you press test, then go back in when you press reset.
Mar 30, 2015 | Kitchen Ranges
While running in a screw to install a new electrical outlet cover, the outlet made a small pop and the lights flickered but immediately came back on. I plugged in the unit to see if it worked and nothing...
You say the unit is 220 volt, but the plug you installed has a white wire which is normally on a 120 volt outlet. A 220 volt outlet would have 2 black wires and ground. If you do have 220 there, and the reset does no good, I've seen those resets(they are basically built in GFI) blow out and had to bypass/put different chord on. there are fuses on the control board but I would check that last
Jun 24, 2011 | Frigidaire FAS257S2A WallWindow Air...
I have two Haier HDN655E dehumidifier's. One works fine and the other wont come on. I have tried unplugging and plugged back in, hit the start button and nothing happens. Is there a reset switch or a...
Have you tested the outlet it's plugged into, to make sure it still has power? If it doesn't, check the circuit breaker panel in you home for a tripped circuit breaker. If there is one, unplug the dehumidifier, before resetting it. Then plug the dehumidifier back in. If the circuit breaker trips again, the problem is within the dehumidifier or the outlet is faulty (i.e. Loose wire, burned wire, broken outlet). If the outlet is not faulty, you should contact Haier America Parts and Repair 877-337-3639.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Apr 28, 2011 | Dehumidifiers
My rice cooker does not start; although the clock works.
I had this happen, and it turned out that the GFCI power outlet had tripped. You may want to try plugging something else in the outlet first and see if that item works - if that other item doesn't work, hit the reset button on your GFCI outlet, alternatively you may have to switch the breaker in your breaker box.
Feb 02, 2011 | Zojirushi NP-HBC18 Rice Cooker
After moving to a new home, the freezer keeps tripping the breaker every few days
My first instinct is to ask you, are you plugging this freezer into a GFI outlet, one which has a breaker switch as part of the outlet? If so, that is the culprit and not the freezer, as refrigerators and freezers will often trip this ground fault indicator because water can on occasion reach ground, which causes the breaker to trip on the outlet.
Test this by plugging the freezer into a non GFI outlet for longer than a few days. Nothing is broken and you dont need refrigerator repair service.
Sep 29, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
NOTHING TURNS ON, PLUG IS OK SAID ELECTRICAN
If you have plugged the tub into another outlet and the jets work fine, it is not a control module problem. The tub should be plugged into a gfci outlet. If it is, there may be a reset switch on the plug it is plugged into, or there may be a switch somewhere else in your bathroom that has the reset switch on it. You can buy a tester for about $3 or $4 that plugs into your outlet to test if it has power. Hope this helps.
Nov 19, 2009 | Jacuzzi EH85-959 Real Whirlpool Bath 6...
I have a never used air conditioner, I put it in window plugged it in, when you hit reset button the green light power indicator comes on, when you hit test it shuts off, the power will not turn on at...
I'm assuming that you're hitting the buttons on the GFI outlet. The test will test the grounding of the outlet. The reset fixes it. These have nothing to do with the A/C. Hit reset and leave it alone.
There is a control panel with fan and temperature switches in the a/c unit somewhere. Turn on the fan/ a/c switch and set the fan on high. Move the temperature switch to mid-range. The noise on the unit should be a bit louder as the compressor kicks in to do the cooling.
Jun 13, 2008 | Samsung Heating & Cooling
Used kenmore stackable washer and dryer P/N 145781-000A
was the machine working when you bought it? if there's 240 available, then a problem is in the machine NOT your wiring. both motors, the dryer and wash motor may be 240 volts OR 120 volts - a hot leg to ground. the feeder should be a four wire because the white is the neutral and the ground an equipment ground. at the panelbox both the equip gnd and white terminate at the neutral bus.
Sep 10, 2007 | Washing Machines
HEALTHRIDER Pro H450i Treadmill HRTL61706 Logo
88 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
