Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
My headset is vibrating. How do I fix it?
Charging it for several days, turning on and off
After charging my headset it will not work all it does is vibrate
Does it ever vibrate? Like if you power off completely, then power back on, phones that can vibrate will usually vibrate once as you see the bootscreen appear.
Or how about the keyboard? Does the vibration work with each keypress if you have that setting turned on?
If none of these work, then it is likely that the vibration motor is broken. Remember that it's essentially the only moving part inside the phone, so it's not surprising that it is prone to breakdown.
Mar 24, 2016 | Radio Communications
My headset will not charge fully and after a couple of hours needs re charging light does not flash for long
If it's old then the battery has probably worn out and no longer holds much charge. See if it can be replaced.
Dec 29, 2014 | Plantronics Cs540 Wireless Headset
It wont turn on
leave it charging for a couple days, if it doesn't turn on after that it's probably done for.
Mar 25, 2014 | Veho 360 Bluetooth speaker
Vibration ane blinking red light
When a call on your phone comes in i will vibrate, flashes red when battery is low. The light will also be red when its charging. It will turn off when its charged.
Mar 09, 2014 | LG HBS-700 Bluetooth Headset
Plantronics audio 995H wireless headset not charging when plugged into computer. It does not show a red light for charging. When turned on it stays blue for several seconds then flickers red for 2 or
38cafd7a-6060-4717-bc4f-b4db91cc266a.jpgI recently fixed my 955 headphones... it's probably not going to be attempted by most folks, but it saved a great set of headphones from being tossed and replaced.
Basically you need to remove the right side padding and take out the 3 screws. This gets you access to the battery. The battery is a standard 3.6V lithium battery. Pretty much the same that is in most cell phones and many small toys. You can simply replace the battery with something like:
http://dx.com/s/3.7v+li
Or... here's what I did... add a lithium USB charger to the battery.
http://dx.com/s/li+arduino
Now, if the battery dies I can plug it into USB and the phone will work while it charges.
Nov 12, 2013 | Plantronics .Audio 995 Digital Wireless...
Afterglow Headset won't turn on.
The battery is shot. These aftermarkets sit on the shelves for a long time, probably because they aren't made very well, and tend to break not long after purchase.
Jan 02, 2013 | PDP PS3 - Bluetooth - Afterglow AP.3...
LG HBS 700 wont stop vibrating
I fixed my Headphones that would not stop vibrating by leaving them ON until the Power drain out and they stopped vibrating. Then Turned them OFF, plug in the charger they began to Vibrate again but after the charge they Stopped Vibrating and have been ok ever since
Jun 14, 2012 | LG HBS-700 Bluetooth Headset
Earpiece vibrating & heating
do you know if the codes of the headsets are the same i lost mine and i need help
Aug 17, 2007 | Plantronics Discovery 640 Wireless Headset
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
44 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
