Question about Waring BB180 NuBlend Blender with Toggle Switch & 44 oz. Polycarbonate Container
How do I remove the coupler from the waring bb180 blender to replace the part?
I unscrewed the bottom and the 4 screws attached to the top plate but cant get the coupler off to pull the motor out
  • 3 Answers
SOURCE: Waring blender BB180
try to soak hot water around the base unplug firts and pour hot water slowly at the base
Posted on Jan 01, 2008
SOURCE: I recently needed to replace
Deb66, you may have found this already, but there is another thread on this site that addresses this same problem. . .
http://www.fixya.com/support/t409495-waring_blender_new_blade
I hope you haven't been blenderless for three months. . .
Posted on Jul 30, 2008
SOURCE: broken gasket can't find a replacement
Go to www.webstaurantstore.com They have all the parts. I have these blenders for my my nutrition club and this is the only place I have found parts at very reasonable prices.
Posted on Nov 08, 2010
  • 394 Answers
SOURCE: i have a waring
Hi I am Steve, lets get you some help.
I assume this is the retaining collar on the blender that you twist to release the top assembly rather than anything else.
It could just be out of alignment and gently shaking the bowl whilst applying a pressure to the collar may clear whatever is causing the jam.
Posted on Feb 06, 2011
SOURCE: Waring blender - model 51bl25
My Waring 51BL16 is having difficulty blending and some mechanism on the inside keeps spinning once the blender has been turned off...any ideas?
Posted on Aug 28, 2011
Does anyone have a schematic showing how to put the motor back together. mine was taken apart, and now I can't find the washers and need to replace and put everything back together correctly. any help...
follow this steps . God bless you
  1. Unplug the blender and remove the jar. Undo the screws securing the baseplate. Separate the baseplate and attached motor collar from the base housing.
  2. To remove the switch housing, remove the decorative facing to get at the top screws. Remove the lower screws from inside the blender base.
  3. Hold the fan to keep the motor shaft from turning as you unscrew the drive stud. Remove the shield and any washers. Unscrew the fan nut to remove the fan.
  4. Disengage the strain-relief fitting from the housing. Remove the wire connector joining the power cord and the lead to the brush housing.
  5. Label and disconnect the lead wires from the switch block. Remove the motor mounting bolts and lift out the motor if necessary.
  6. To free brushes, remove the leads attached to the brush housing. Use a screwdriver to press lead terminal through the slot in housing. The brush spring may pop out (don't lose it!).
Nov 24, 2013 | Waring MBB518 2Speed Blender
Remove stud drive from blender
You have to use a flat edge screw driver for locking the motor shaft.
first you put the screw driver to the slit on the motor shaft at at the bottom side at the same time you should use suitable wrench for unscrewing the stud
I hope this helps
Mar 30, 2013 | Waring 502696 Drive Stud
How do i replace clutch in base of blender
here is a solution that worked for me (see below)....to get the clutch out I used a flat-head screw driver in the bottom of the base to hold the cooling fan and then screwed the clutch out with a clockwise turn. I have yet to order a new clutch ($2.70) at http://www.ereplacementparts.com/waring-bb180blender-parts-c-120019_120020_130537.html but the removal works. Good luck.
Hello
There are two type of fittings for this gear. In some models it will be push in type, and for others it will be screw type. If your model has push type one, just pull out it from the shaft. You may have to excert a strong force to pull it out. If it is screw type, you have to open its lower lid by unscrewing its secrews, hold the cooling fan and hold the gear at the top, twist it in 'CLOCKWAYS' direction, [not counterclockwise], to screw it out. OK.
Mar 14, 2011 | Waring BB180 Work Top Blender
We have an old Waring Futura 900 blender that leaks at the bottom of the glass around the beater blades. How do you repair? Is there a gasket?
Yes their is a gasket. However try to tied the hole blade kit a litle harder since it might be loose, it might be also dirty you can loose it clean it and put it back.
Have a visual insections since the glass might be broken a litle bit also.
Good luck
Aug 09, 2010 | Waring BB180 Work Top Blender
The gear at the base of my waring bb 180s blender is stripped
You can try the sears online parts store for help they may be able to get the parts you need as they are pretty much the same. iF YOUdon't find it let me know and I will resurch it for you and find the part it is eather the druve nut has come loose or the teeth on the plastic shaft has worn off, it is possible to super glue it to hold if you cant find the part.
Nov 12, 2009 | Waring BB180 Work Top Blender
Broken gasket can't find a replacement Waring NuBlend BB180 without buying the whole replacement blades kit. just need the gasket.
Nov 05, 2009 | Waring BB180 Work Top Blender
Square drive pin for Osterizer blenders?
I simply slid a small screwdriver in through one of the holes under the base to prevent the fan from spinning and unscrewed the pin counterclockwise using some small channel lock pliers. No disassembly necessary.
Jan 26, 2009 | Oster 4134 / 4126 Classic Beehive Work Top...
Replacing rubber drive coupling
My coupler was split in two, and I couldn't screw it off. I had to do the following:
1. Take the blender apart (mine had 2 screws on the bottom). 2. Remove the motor housing from the blender (mine was loose from removing the two screws earlier). 3. Remove the fan by removing the fan nut. 4. Take apart the motor housing. Mine had two machine screws with 1/4" hex heads holding a bracket that tied the two ends together. Once those two screws are removed, you can take the motor out of the housing. Be careful on the fan end of the motor, because it's got two spring loaded brushes that will come together once the motor is pulled through. 6. Once you have the motor out of the housing, you'll have something to grab onto so you'll be able to unscrew the broken coupler. I used a pair of channel locks and gently grasped the motor body, and then just used a regular pair of pliers to grab the broken coupler. It's regular thread (lefty lucy righty tighty), so twist accordingly.
Once you have the coupler off, just put everything back together. The hardest part is holding apart the spring loaded brushes while you push the fan end of the motor shaft back through the motor housing.
Took me about 20 minutes to do everything.
Good luck.
Nov 20, 2008 | Oster 4093-8 Osterizer Classic Blender...
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
Dec 28, 2007 | Waring BB180 Work Top Blender
Waring BB180 NuBlend Blender with Toggle Switch & 44 oz. Polycarbonate Container Logo
95 people viewed this question
Top Waring Blenders Experts
karen renee may
Level 1 Expert
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
