Question about Refrigerators
Stop water under fridge
Does water come under fridge that does not come from a leak in the water supply? Am I supoosed to empty a water basket under the fridge? how often?
  • 54 Answers
I'd go to the manufacturer of the appliances website. There you might be able to contact customer service or look through the original owner's manual. That might help.
Posted on Nov 19, 2014
SOURCE: The water input to the water filter is leaking - admiral model GC2224GEKB
my water filter water line is leaking from the bottom in the back of my refrigerater. How can i get to it to repair it.
Posted on Oct 09, 2008
Bgillespie
  • 89 Answers
SOURCE: water leak from under fridge when water dispenser is used
The water line is broken somewhere from the water dispencer all the way down to the water valve. I usually find that it is broken next to the water valve. Hint: Water valve is blue and located behind the fridge in the compressor department. Water line is 1/4inch clear tube that is probaly now a "yellowish" color. Easy to spot, easy to fix, especially if located next to water valve...
Posted on Dec 02, 2008
SOURCE: water leak
Icemaker has become extremely slow in making ice and will not keep up. It is making ice but seems to be sporadic.
Any suggestions???
Posted on Jan 15, 2009
Thunder55
  • 318 Answers
SOURCE: heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Posted on Jan 19, 2009
  • 1891 Answers
SOURCE: Leaks water inside fridge when
if this is a top mount freezer / the drain needs to be cleaned . it could be iced over or pluged with algi . hope this helps mm
Posted on Sep 01, 2010
I am getting water leaking from under my fridge freezer it stops when I turn the mains supply off for the water filter.
I would check the water lines that supply the water to the fridge, and any visible lines on the fridge itself. I used to have a problem where the plastic lines would get brittle and snap at the ends - I also use a product called Floodstop that has sensors that automatically shut off the water to the fridge if any of the sensors detect water leakage - plus it tests the valve once a month to make sure it actually works when you need it too -
Oct 07, 2017 | Refrigerators
I have a leak under the freezer section and I have had this for a while. Emptied draws and I have disconnected the water supply and it is still leaking/dripping.
Hi,food for fort,just maybe at the back of the fridge on top of the copper ball there is a water tray maybe its full.(it takes the moisture out of the fridge thats what the hole in the back wall of the fridge)
hope this was helpfull.
Mar 20, 2015 | Daewoo FRAX22B3B Black 622 l Fridge...
Water leaking from bottom of my Bosch fridge (irregular - might be defrosting??)
There is a tray under many refrigerators that traps water so that it may harmlessly evaporate. It or the drip tube may have become dislodged, possibly by cleaning under the unit. The tray should easily be removed, then you may see if it or the tube is the problem.
Nov 19, 2014 | Bosch Refrigerators
Water leaking under a fridge freezer
There can be 2 reasons for this ... the first is that the machine is causing condensation and is dripping on to the floor. Automatic defrosting fridge freezers do this but usually the quantity of water evaporates before any is on the floor.
If the Fridge / Freezer has an automatic Ice maker, or has a cold water supply, then I would suggest that there is a water leak to the system. In this case, find the water supply feed and turn it off to eliminate this as the source.
If this stops the leak, then either the supply is leaking or the problem is inside the fridge / freezer and you will need either a plumber or a repair man to fix the problem.
Aug 21, 2014 | Refrigerators
My refridgerator leaks
either there is a pub hole in the giving on the ein or our just is not tightened enough at the connection. is there water ay the bottom if the fridge cause usually there is so reservoir to keep water cold ay the back boutin of the fridge. youre going to have to look for water and follow the trail. remember water cant flow upwards so lllllll for the leak above the highest place you find water
Jan 08, 2012 | KitchenAid Refrigerators
No pot or instructions, how much water do you put in the coffee pot?Need a replacement pot for vp17 series. thank you
You should be able to pick up a replacement/new pot at your nearest Restaurant Supply store. Make sure you get a 64 oz./ 1/2 gallon pot.
Before plugging in your brewer, unscrew the sprayhead located just above where the filter basket sits and replace the basket, pour 3 pots of cold water through the opening on the top if the brewer is empty. This brewer has a reservoir that holds about 2 1/2 pots of water at brewing temperature when heated. Make sure you put an empty pot under the filter basket after pouring in the water. Water will flow from the brew basket when the reservoir has reached its capacity. Once water flows you can then plug in and energize your brewer and replace the sprayhead. It will take about 15 to 20 minutes for the brewer to reach brew temp, you will hear the heating stop. Put an empty filter and a dose of coffee (I recommend starting with a heaping measuring cup of drip ground coffee) into the filter basket, lightly shake it level, replace the basket and pour through 1 full pot of COLD water in the top. For best results pour the brewed coffee into a pre-heated thermal server if you plan on holding the coffee for more than 10 minutes or so.
Enjoy!
Jan 04, 2011 | Bunn VP17-1 Coffee Maker
Refrigerator does not produce ice or water. Kenmore Elite Refrigerator Model Number: 795-775-69600
If you have both ice and water stopping you have a water supply issue.
Water enters under city pressure through an eighth inch supply line.
Start simple and work from there.
If the fridge was moved the line can get kinked. Slide the fridge out and check you have water to it. You can loosen the supply line connection just a little and you should see water leaking. If not it is a plumbing issue in the house. Most likely a the supply line is kinked or possibly someone closed the shutoff valve to the fridge.
OK so we have water to the fridge.
Water comes in and connects to a water filter and then to the door.
If the filter is badly clogged it can cause low pressure to the door and that would cause the problem. Check the filter.
If no go still then check where the water is stopping.
Remove the from cover from under the unit. That is the plastic grate at the bottom of the fridge. It will just pull off but be gentle and take your time so as not to break anything.
Water supply will run through a clear plastic hose. It runs to the filter then to the bottom of the freezer door and up through the door.
You can sometimes see where the water has stopped and clear or replace parts as needed.
There is a connection just before entering the door from the filter. You can loosen that to see if you have water to that point.
If you have water past the filter the problem is in the ice maker and water supply inside the freezer door. Water can leak here, expand, and crack plastic parts easily.
If there is water to the door then you need to dig into that. This gets a little more complex to describe but in short take the ice maker out and check for water supply or broken parts. The problem is probably before the ice maker as your water in the door is not working. This indicates it is not just the ice maker.
Hope this helps.
Mar 12, 2010 | Kenmore Refrigerators
Refrigerator is leaking/dripping clear water, but the ice maker lines have no leaks and it appears to be coming for the middle of bottom of the box somewhere.
You may have a leak from the water supply line that is attached to the fridge from the house hold line near the bottom right corner of the fridge.
Jan 29, 2010 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Not brewing full pots of coffee
Check the in line water fliter. It may need to be changed.
You can try this also.
Put the brew basket in place with no coffee in it, put an empty decanter under the basket. take a full decanter and pour it in the water fill screen at the top of the unit. When the wtaer stops dripping and the unit is back up to temp, try a full brew cycle.
If it works OK, it just got low on water in the tank
Could be caused by a plugged up filter or lime scale build up.
Dec 28, 2009 | Bloomfield 8572 Coffee Maker
Heavy water leak in basement under fridge
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
