Question about Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater...
How do i know if the control unit is bad on an aquastar 1600H
The unit just stopped producing hot water. the voltage on the hydro generator is 0.5 vac. how do i know if the control board is good or bad
  • Peter Klepl
    Peter Klepl Nov 20, 2014
    i took the hydrogenerator off last night and found that the parts inside were broken. there was a rubber washer curled up, looks like it was coming apart for quite some time. possibly this was a defective hydrogenerator
    Problem Solver:
  • 5 Answers
That voltage does not seem high enough. Supposed to be 1.6 VAC and I got 2.5 VAC. Do you have the water flow turned to the maximum? Is there something blocking water flow? The hydro voltage should be checked separetly from everything else, so if you can't get the VAC higher, my guess would be that's the problem.
Posted on Nov 19, 2014
  • 5 more comments
  • Peter Klepl
    Peter Klepl Nov 19, 2014
    so cleaning the hydro generator might raise the voltage?
  • zawy Nov 20, 2014
    If it's clogged, and if it can be cleaned, then maybe. I assume you have good and strong water flow when you turn on a hot water faucet. If you do, and if you disconnected one of the 2 wires of the hydrogenerator like you are supposed to (so that voltage is not drained off of it) and set your voltmeter to AC and it said 0.5, then something is wrong with the hydrogenerator.
  • Peter Klepl
    i took the hydrogenerator off last night and found that the parts inside were broken and had been deteriorating for quite some time. waiting for a new part to arrive
  • zawy Nov 20, 2014
    hmm, that's not cool.They should make water heaters to last a long time. I'm disappointed with Bosch. Since when did Germans starts doing shotty engineering (microswitch) or going cheapo on parts (hydrogenerator deteriorating)?
  • Peter Klepl
    i have no idea, but i wish that Rheem or one of the other popular brands would come up with a hydrogenerated tankless water heater as i would gladly upgrade to their equipment.
  • zawy Nov 20, 2014
    For 32 years I
  • zawy Nov 20, 2014
    For 32 years after reading about them in popular science I've wondered why tankless is not standard.
  • 33 Answers
SOURCE: Bosch Aquastar 2400E LP Does Not Heat Water
Sounds like the water flow sensor and servo, may just need cleaning, get it checked out by a Bosch agent
Posted on Jan 17, 2010
1stBSP
  • 52 Answers
SOURCE: i have a 250SX aquastar bosch tankless hot water
The 250 MUST have the condensate line connected. EC comes from gas supply problems and CO2 levels not being adjusted. LP units require 3/4" smooth gas pipe or 1" corrugated pipe minimum size. The LP regulator needs to be turned up to about 13 inches of water column and with all the gas appliances on, measure no less than 11 inches of water column. The CO2 levels must be measured by a qualified gas technician with a calibrated (with in 6 months) CO2 analyzer.
Posted on Apr 11, 2010
KenjiFox
  • 142 Answers
SOURCE: bosch aquastar Aq125-hx does not
That particular tankless water heater has hydro-generated ignition. In order for it to function, it requires a certain water pressure and velocity. You can try turning on the hot water in two location in your house to see if that gets it started. If it does, try getting a higher flow shower head, or removing the limiters in your faucets.
Posted on Jan 07, 2011
solarstarene
  • 159 Answers
SOURCE: Bosch 1600H-NG Natural Gas AquaStar
Possible flow sensor issue. Check to see if your water pressure fluctuates a lot or is fairly steady. These units are sensitive to the pressure. take care.
Posted on Mar 04, 2011
SOURCE: roblem with the Bosch 1600H-NG
Problem could be air supply, gas supply, venting, part failure or combination of listed things.
Best place to start is manual.
http://www.boschhotwater.com/BoschModel1600H/FeaturesandSpecs/tabid/1024/Default.aspx
Typical 1600 manual shows troubleshoot starting page 19
http://www.boschhotwater.com/Portals/7/TechManuals/1600H_English_0606.pdf
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
BOSCH error codes:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 05, 2011
Bosch 1600 h not lighting pilot light
If your getting a spark the generator should be ok I would clean the pilot injector and re try
Nov 16, 2014 | Bosch 1600H-LP Liquid Propane AquaStar...
Aquastar gwh 1600 h igniter fails clicks does not spark
If there is not a clicking sound, it almost always means the main ignition or control unit (box with red and green lights and wires coming from it) is not getting the supply voltage. The voltage is supplied by a generator that is getting energy from the flow of water (the "hydro generator"). First disconnect the wire connector at the hydogenerator and check the voltage while water is running. The manual says you should read 1.6 VAC (I read 2.5 VAC). Make sure your voltage reader is on AC, not DC. If you have at least something like 1 VAC, then the next thing to check is the "microswitch" that allows the hydro generator voltage to reach the ignition unit. To check it, disconnect the other wire connector that is on the black wire coming from the hydrogenerator that is closer to the ignition unit. Then with the water running, stick a small screwdriver in the male plug side to short the two wires in order to bypass the microswitch (per Bosch tech support instructions). You should now here clicking and see the unit work. This is what happened with me and tech support said I needed to order a new microswitch and gave me a part number and telephone. But don't stop reading here. You can see the microswitch when looking up at the underneath of the unit. It's a small white 1x1 inch box-like shape held by 1 screw. After removing it, I noticed the microswitch had a removable cover (which is strange for a switch) and opened it to discover the internal switch can actually move inside because it "automatically adjusts" itself when it is first put in (it stays more firmly, but not rigidly in place when the cover is on). So you can mess up when putting it in. Don't bump it. It can easily get out of its working range of motion, which is why mine stopped working: it was a bad design to use this type switch in this application. So I slide the internal switch back close to the spring side ("default" position), put the cover back on, carefulyl screwed it in place, and now it works.
The purpose of the mechanical microswitch is to not allow the hydroenerator voltage to the ignition unit unless the "pushrod" has opened the main gas supply. It prevents clicking if there is no supply gas, so it is not needed (you can electrically bypass it with a splice) if everything else is working fine. But don't blame me if you do this and for some reason it ruins the more expensive ignition unit. The microswitch is turned on by the pushrod when the pushrod leaves it's default position. The the pushrod moves only about 2 to 3 mm when you turn on the water. You can see the pushrod when you unscrew the microswitch, and you can watch it move. The problem is that the microswitch mounting is not precise enough for the small pushrod movement and the pushrod's default position can change with age of the diaphragm or change in the grease. So their automatically adjusting microswitch that makes up for lack of precision in design and pushrod movement can stop working when the pushrod changes position. My unit was 2 years old.
Mar 04, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater. Problems with constant hot water. The heater turns ok but (i think) when i turn on the cold side the heater stops. at...
Feb 19, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
I have a Bosch GWH 1600 Tankless hot water heater. Sometimes it would spark, I would turn water offf an on a few times at the valve, and it would click and start. I took about the Hydro Generator, I...
Having the same problem with mine. Looking for a replacement generator. Seems that if your water pressure or flow is not adaquate your will have this problem. Get worse over time. I took mine apart and it got better then started doing the same thing again. I turn on several faucets to overcome problem. Still it not good. The 1600H does not appear in the Bosch website parts list models. They do say that a third party does the fulfillment in the notes at bottom on other units...maybe call them
Dec 24, 2010 | Bosch 1600H-NG Natural Gas AquaStar...
I have a 16h Bosh hydropower hot water heater . The unit suddenly has no spark .I have taken off the little generater cap and thouroughly cleaned it and the internal turbine . With no improvement . All...
sounds like the generator has packed up. check water flow and clean any filters on the water line. you will need a service agent to check milli volts on generator and power pack
Dec 15, 2010 | Bosch 1600H-LP Liquid Propane AquaStar...
1600h same problem with ingiter
It is a control box issue but now I have to decide if I want to spend $270 to fix or for $299 buy a regular water heater. By my calculations being this is year three, the 15 year life expectancy of this 1600h water heater will cost me $1500 in parts alone.
Sep 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch tankless GWH 1600 H NG won't always ignite. The igniter sparks, but doesn't always light the gas. It just clicks. When installed it lit every time, now it takes more and more tries to get it to...
The manual says to hold a match near the pilot while the ignitor is trying. It says that if the unit lights the pilot orifice may be dirty or clogged. Then the manual says to check the voltage on the igniter. It should be 1.3 volts DC minimum if it is not means the electronic control box is defective.
Let me know the status ...Kevin
Mar 29, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 1600H NG
I hope this helps!
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/1600HTechSupport/Troubleshoot/tabid/1094/Default.aspx
Copy and paste to google search engine!
Jan 29, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater... Logo
113 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
