My tv keeps coming up with storage device read failed in a blue box on the tv screen can anybody tell me how to fix this please
Re programming
  • Televison & ... Master
  • 9,587 Answers
Is there a memory stick in the USB port on the TV?
Posted on Nov 19, 2014
Our screen turns blue and goes to new devices input. We have nothing else connected to tv except Brighthouse cable box. If we push the exit button on the tv remote it then goes to showing a cable box and...
Your TV probably has multiple "inputs" (coax, HDMI, component, et cetera). Use the "input" (or "source") button on your TV to cycle through all those available "input" streams.
If you select "coax", and there is *NO* coax cable connected to the back of the TV, you *WILL* see the "blue-screen". Select a different source that is "active".
Feb 24, 2015 | Televison & Video
My Westinghouse TX-42F810G TV volume (only) is decaying. Any ideas?
Are you saying the DVD & chromecast have good volume on this TV ? Is your problem with the cable box only ?
Are you using a surround sound system with the TV ? If you are using the sound from the tv only & all your other unit work ok sound wise I would assume the cable box is bad .
Jan 12, 2015 | Westinghouse Televison & Video
Little background. Had lightning in the area. With that said, I have 2 other tvs that are working,along with the dishtv boxes working. The box for this tv is working as far as I can tell. but not sure....
Did you UNPLUG it from the wall for about an hour to let it reset itself? Turning it off does not kill the power and the CPU, they are running 24/7 the minute the TV is plugged into the wall outlet.
The EPROM or the main board may be damaged.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Oct 22, 2010 | Vizio SV470XVT 47 in. LCD TV
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
Devices do not display visual or audio input, just a blue screen.
You need a repairman. These sets have a bunch of small capacitors that fail on these sets. There is more than one board with this problem. Do your homework and find a good reputable repair shop to fix this for you. It's not something the average person can do. Sorry for the news. Not a simple fix. Mistubishi has a problem with capacitors and it's been this way for more than 20 years. It's ALWAYS bad capacitors that cause Mitsubishi's to fail.
Dec 24, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Copy TV to DVD/R
sao ha sao ha sao ha sao con cac
sadfassa
sdadas
dasds
adsa
ds
dsa
das
das
dasd
asdas
das
das
Apr 11, 2008 | RCA DRC8335
Common problem...yet no working solution...
I think there's a capacitor that holds a charge for the blue-ring-of-death. The fix is to hold the menu button down for about 30 seconds (blue ring disappears) and continue holding for about 15 more seconds (or until re-boot). The additional time is required to discharge the capacitor.
If that fails, there is a safe-mode: place the device in hold, and press the mic and menu buttons at the same time. This usually doesn't apply to the blue-ring problem, but it may help.
Mar 11, 2008 | SanDisk Sansa e200 MP3 Player
Blue screen of death
Try to reinstall windows by repairing it.
Mar 04, 2008 | Gateway M275 Tablet PC
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
