Aquarius wf320 washing machine will not drain lights number 2 and 4 flashing
  • 3 Answers
Pump is bad. Pumps can cost as much as machine.
Posted on Nov 19, 2014
  • Kelly cook Nov 19, 2014
    Thanks very much for letting me know probably best to buy new machine now
Aquarius wf320 washing machine draining not working lights number 2 and 4 are flashing
Could be one of two things.first try the penny trap at bottom front of machine.unscrew cover and check for captured debris such as a coin button etc .if this is clear the next possible reason is the water pump has failed or blockage in the drain pipe or even twist in pipe at the back of machine.
Nov 19, 2014 | Washing Machines
I need to get to filter on my wf320 hotpoint washing machine
Disconnect power from circuit breaker or unplug power cord before starting. The filter in the hotpoint aquarius 1200 is in the front bottom side, hidden by a trim panel. Remove the trim panel at the bottom of the front side and find the access at the right hand side. Keep a large flat container ready to collect water from drain filter.
Pl say so if helped
Mar 16, 2013 | Hotpoint Washing Machines
Please help the washer fills up and turns the
Seems like a blockage or maybe pump worn out. Fill machine and take grey outlet pipe on rear of machine. Place this pipe as low as possible into a bowl. If water flows free from this pipe then your pipes are not blocked and most likely you will need to change your pump. Before you try this just put machine onto spin and ensure this will work when machine is almost empty
Mar 12, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius wf320 door won't open.
what you need to do is say 'abracadabra' 3 times , then swear allegience to the queen always remembering Glasgow Rangers are the best ..hee hee
May 04, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Why do the lights just keep flashing?
Try unplugging it and rubbing the plug on a soft dry cloth, static electricity can cause problems.
Try opening and closing door acouple of times, if still no luck , suggest you call engineer
Dec 09, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF320
interlock is device which prevents door opening when machine is operating. why do you want to change it?
to access interlock. remove door gasket from cabinet in area of door handle and interlock is held by 2 screws from outside
Aug 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
HOTPIONT AQUARIUS WF320
interlock may be stuck try changing that
May 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
