Why is my Boxlite 22n projecting vertical dotted lines
  • Office Equip... Master
  • 10,291 Answers
The DLP chip needs to be replaced. You can get them on line from shopjimmy's web page.
Posted on Nov 19, 2014
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
My tv blinks and no power on the screen. People tell me its the bulb and someone also told me it could be the ballast
In a projection TV there are three CRT high illuminessence tubes no ballasts or bulbs, do you have a dot in the middle of the screen??? do you have a white line (horisontal or vertical)??? is it realy a projection TV not LCD or PLASMA???? post the make and model if you want us to help!!
Sep 24, 2011 | Televison & Video
Rca 61 inch dlp has vertical lines accross the screen , they come and go by themselves
Hi,If you are experimenting vertical lines ,color distortion,pixilation,or white dots on the screen you might be having an issue with the Dmd chip.This is how the DMD chip works: http://electronics.howstuffworks.com/dlp1.htm Basically the dmd chip is composed of around 2 million pixels that create the image on the screen.You will need to replace in order to fix your problem.Have a blessed one!
Feb 06, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
Non convergin "dot"
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Philips 55PW9363 55" Rear Projection...
Majic focus lines very broad
Undue the calibration! It sounds like the dynamic contrast is up too high.
Jan 03, 2009 | Hitachi 57SWX20B 57" Rear Projection...
White dots/green lines
The problem could be in vertical blanking or video processor circuit. Also redish vertical lines may be from external RF or magnetic interference. Move set to new location away from appliances and speakers
Apr 21, 2008 | Sony KP-53V85 53" Rear Projection...
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Gateway laptop vertical dotted lines across the screen
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Ron-
Dec 13, 2007 | Computers & Internet
44 people viewed this question
k24674
jasbo
jasbo
