Question about Sport & Outdoor - Others
The electronic soreboard no longer illuminates
I can't find the model # on the unit. Where can I get a manual
  • Cristian medina
    Cristian medina Nov 19, 2014
    Hi Chuck , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
I have an 06 ford explorer the instrument cluster lights and radio lights don't work
Are these the lights you are talking about ?
Instrument Cluster and Panel Illumination The instrument cluster and panel illumination is used to provide backlighting to the instrument panel, switches, and control components when the headlamp switch is in either the PARKING LAMPS ON or HEADLAMPS ON position. The level of intensity is adjustable by rotating the instrument panel dimmer switch either up to increase intensity or down to decrease intensity.
Fixed Backlighting When the accessory delay relay is energized, switched voltage is supplied to the non-dimmable components and switches.
Dimmable Backlighting When the parking lamps or the headlamps are in the ON position the smart junction box (SJB) monitors the input from the instrument panel dimmer switch. The SJB sends a pulse-width modulated (PWM) voltage to the dimmable components and switches based on input received from the instrument panel dimmer switch. The SJB also sends a message over the controller area network (CAN) to the audio unit, and the instrument cluster to indicate the backlighting intensity level.
If you don't know about PWM an smart junction box your better off taking your vehicle to a quailified repair shop ! You don't the diagnostic tools or technical information . May have DTC'S - diagnostic trouble codes stored in the SJB (computer ). Do you know where SJB is located ?
Visual Inspection Chart Electrical
  • Smart junction box (SJB) fuse 23 (15A)
  • Bulb(s)
  • Circuitry
  • Connectors
  • Illumination source(s)
  • Auxiliary climate control switches (if equipped)
  • Door lock control switches
  • Window control switches
  • Headlamp switch
  • Dual electronic automatic temperature control (DEATC) module
  • Audio unit
  • SJB
  • Instrument cluster
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, connect the diagnostic tool to the data link connector (DLC) and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
  • check that the program card is correctly installed.
  • check the connections to the vehicle.
  • check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
  • CAN circuits fault; all electronic control units no response/not equipped, refer to Section 418-00 .
  • No response/not equipped for SJB, refer to Section 419-10 .
  • System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out the self-test diagnostics for the SJB.
  1. If the DTCs retrieved are related to the concern, go to the Smart Junction Box (SJB) Diagnostic Trouble Code (DTC) Index.
  1. If no DTCs related to the concern are retrieved, GO to Symptom Chart .
    • The control illumination is inoperative
    • Fuse
    • Go To Pinpoint Test A .
    • The instrument cluster illumination is inoperative
    • CHECK the audio unit illumination for correct operation.
      • If the audio unit illumination operates correctly, INSTALL a new instrument cluster. REFER to Section 413-01 . TEST the system for normal operation.
      • If the audio unit illumination does not operate correctly, REFER to Section 418-00 to continue diagnosis of the communications network.
    • The audio unit illumination is inoperative
    • Audio unit
    • CHECK the instrument cluster illumination for correct operation.
      • If the instrument cluster illumination operates correctly, REMOVE the audio unit. REFER to Section 415-01 . SEND it to an authorized repair facility. TEST the system for normal operation after the repair.
      • If the instrument cluster illumination does not operate correctly, REFER to Section 418-00 to continue diagnosis of the communications network.
Sep 04, 2016 | 2006 Ford Explorer
The selector button no longer works on unit or remote...AU...CD...Tuner ...etc. WHY???
If the selector button on the unit AND the corresponding button on remote has no effect, then the problem lies with the digital circuit responsible for changing inputs and not the Remote or the selector knob on unit.. I am assuming that the other functions do work.
That puppy needs to be repaired unless you can live with the input that it is stuck on. U might try unplugging the unit for a while and then replugging it. On some newer models this "reboots" the electronics and restores operation
Jan 19, 2015 | Panasonic Sa-pt750 Multi 5 Dvd Player...
Unit will not power up, when plugged in to AC the mute -20 dB is lamp is illuminated. Is there a reset feature?
Sony consumer grade electronics are notorious for electronic component failure due to the low quality grade of their components. It's likely that the whole circuit is not receiving power. If you are handy you can search the internet for a service manual and follow the flow chart to troubleshoot the defective circuit.
Dec 22, 2013 | Sony Str-d665 Dolby Pro Logic Surround...
The red alert light indicates that the filter needs to be cleaned. I have cleaned it but the light remains on. I have turned the unit of and on again but it doesn't change the light. The unit is...
Tunr the unit OFF & unplug it for 15 minutes. Then plug it back in and turn it on. The electronics should have reset and reverted back to the original factory settings & the red light should no longer illuminate, as long as the filter was reinstalled properly.
Hope this helped you and thanks for choosing FixYa.
Aug 08, 2011 | Heating & Cooling
My la cornue oven not heating, turn 1st knob to function desired and then temperature knob to desired temp but oven does not heat up
First thing should be to make sure the top selector switch is not set to the optional Pizza element.
Make sure the power to the unit is OFF. Also keep in mind that the following tests should be done by a qualified appliance specialist. To find one near you, contact the La Cornue Service Center @ 877-522-6768
Is this the first time using the oven? If so, make sure the overall power to the range is 240 volts. This can be checked at the main terminal block.
If your model has three indicator lights and the red light is illuminated, then it is likely the hi-limit thermostat has tripped and you will need to reset it. The reset switch is located underneath the cycling thermostat. To access this, you will need to remove the front fascia. Please note: The original safety thermostat is no longer available. Use current safety thermostat (reference: 06ELTS01). If your model has only two indicator lights and the red light is illuminated, that means the oven is heating up. If the red light is not illuminated when the thermostat is set at the desired temperature, then check the hi-limit thermostat.
Power relay/contactor on the back of the unit should be checked. It
Jan 06, 2011 | La Cornue Grand Maman Dual Fuel (Electric...
My garage door opens but does not close. I have a stanely screw drive model # sd550. I can get it to open but I can not get it to close. I am guessing my sensors are in the wrong place but I need a manual...
the electronic sensor eyes being off are the most common cause of this.
They need to be pointed at each other so they can "see" each other.
Commonly, the units have a light on them that will illuminate when they can see the other half of the unit on the the other side.
Also check the terminals that the sensors connect to, and make sure that they are connected.
Oct 27, 2009 | Stanley 100 ft. Tape Measure, FatMax
Illumination not working when faceplate is open.
Wire braid out to the faceplate has got a parcially broken wire on it. Sony referes to it as a flexible circuit board. Part can be purchased from sony directly, an on a one to 10 scale to replace about a five.But it does involve taking your radio apart. So if you are handy at electronics. you can look it over. If you have doubts let a professional do it.
Jan 05, 2007 | Sony CDX-M8815X CD Player
Sport & Outdoor - Others Logo
478 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
