Question about Ovens
Lamona Oven starts squeaking/squealing after about 15-20 mins. It will continue even after the oven knob is set to 'off'. It will then eventually stop about 30-40mins after cooking has finished.
  • Shane Todd
    Shane Todd Nov 20, 2014
    Hi Ryan , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? I need the model number of your oven. Thank you.
  • 1462 Answers
SOURCE: Oven
oven has two fans. the second fan is out of sight and cools the casing. it is operated by a seperate stat. not unusual for it to run for up tohalf hour after switching off. if it runs for an excessive time may be a fault nwith fan stat
Posted on Mar 20, 2007
  • 139 Answers
SOURCE: Oven will not stay alight
You have aproblem with you ffd ( flamme faliure device which is located in the oven.. Or if your oven has a thermocouple that has gone. Yo need to replace either one of them depending which one you have in your oven
Posted on Nov 18, 2007
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
BNewberry
  • 93 Answers
SOURCE: Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
Posted on May 15, 2008
barkencoa
  • 3463 Answers
SOURCE: CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Posted on Feb 22, 2010
Testimonial: "GR8 JOB HAVE ALREADY SEARCHED ON THE NET BUT THIS CONFIRMS. NICE ONE CHEERS."
Stoves Q720 GRF DO main oven ignitor clicks / sparks continuously
Might be the PC board, or it might just be the switch behind the oven knob - try disconnecting the wire leading to that switch and see if the clicking stops. If it does, the switch is bad. If not, suspect the electronics.
Aug 23, 2014 | Ovens
No temperatures on the oven
Easiest thing to do is to Get your Model Number, log onto www.searspartsdirect.com and order the new knobs... Or go to your local appliance repair center or Appliance parts store and order them and you will be able to get fix it for the future.
Download LAMONA HJA 3300 HJA3300 User Guide English
Mar 03, 2014 | Ovens
I have a lamona hja3400 oven and the element has stopped working. I'm trying to get the element out but it seems to be fastened on the back of the oven not inside it as with other types of ovens. Does...
hi my lamona oven started to make a noise like a pinging noise it was working the noise would come and go it would get worse half way through cooking. but last night the noise seemed to have lasted longer and the oven knocked itself off any ideas what the problem could be.
Aug 30, 2013 | Ovens
Moffat Stove with a self-cleaning oven. I would like to know how to clean the oven using the "self cleaning" feature
hi there! I have a moffat stove and hopefully these instructions help you.
First clear out the racks in your oven. Take them out and remove any excess chunks at the bottom.
Then close your oven door and lock it by pulling the lock latch.
Now looking at your oven knobs [not your burner knobs] turn both of them so they are both on the arrow knob [your oven knobs should have small pictures on them and both should have arrows]
Now you need to set the time so in the middle of your oven their should be a timer and one start and stop timer on top of each other. Both timers go in increments of half an hour. So if you are starting your self cleaner at 3 move the dial to 3 or if you are starting at 3:30 move the dial to one tick after 3. Once you set your start timer, you need to set your stop timer.
Setting your stop timer, it is recommended to set it for 3-5 hours. I set mine for 4 hours. So then set stop timer to time you want the cleaning to be. If you set your start timer at 3:30 put your stop timer at 7:30.
The oven will start cleaning according to the time you set. The oven will get very hot. I recommend to not used the burners as the temperature goes to 500 degrees! You will smell an odor and that is your oven cleaning.... Hope this helps...
Sep 13, 2010 | Ovens
F-10 code and continuous beeping
Your board is going bad
Aug 25, 2009 | Ovens
Moffat Self-Cleaning Oven will not self-clean
did you try setting a start and stop time with the time knobs? i had the same problem til i set 3 hrs on the start and stop, then let it sit (after locking the door and turning the knob to clean). after it was warmed to cleaning temp, the light for cleaning came one...
Nov 10, 2008 | Ovens
Squealing oven
there is a separate casing fan hidden out of sight and this is what is squealing.
take oven out, remove top and back panel and you can see the casing fan. try wd40
Sep 17, 2008 | Neff B1641 Single circotherm super...
Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Jun 26, 2008 | Ovens
Faulty oven
you need to either set the time, or just press the centre button to activate the cooker.
Sep 19, 2006 | Whirlpool AKZ159IX Oven
Ovens Logo
59 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
