Question about OES Genuine 2007 - 2009 Mercedes-Benz E63 AMG Engine Coolant Recovery Tank OES Ge
<!-- from fixya rte -->Over heating with no leaks - OES Genuine 2007 - 2009 Mercedes-Benz E63 AMG Engine Coolant Recovery Tank OES Ge
  • OES Genuine Master
  • 10,291 Answers
Replace the thermostat in the engine.
Posted on Nov 19, 2014
Why is my car leaking water out of the radiator cap only when the heat is off but when the heat is on it don't leak ???
turning the heat on lowers the temperature of the water running through the engine which in turn lowers the pressure in the radiator
Dec 18, 2014 | 2005 Ford Mustang
Engine heating and a leak under van
Fine the engine is heating and you say leak under van. What is the leak, is it water/ coolent/ oil or what?
is it possible to know where the leak is coming from?
Mar 31, 2014 | 2000 Dodge Grand Caravan
1999 Blazer is over heating. I replaced the thermostat. I get zero warm air and yet the engine over heats in under 20 minutes of driving
Repair coolant leak.
If you cannot locate the leak, run a pressure tester and try to locate the leak.
Nov 06, 2012 | Chevrolet Cars & Trucks
What does the codes p0442,p0136 &p0141 mean on my 2001 ford taurus it failed inspection for these codes
P0442 FORD - Evaporative Emission System Leak Detected Small Leak
Possible causes- Missing or loose fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- EVAP canister or fuel tank leaks
- EVAP system hose leaking
- Fuel tank leaking
P0136 - O2 Sensor Circuit Malfunction Bank 1 Sensor 2
Possible causes- Rear Heated Oxygen Sensor Bank 1 harness is open or shorted
- Rear Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Faulty Rear Heated Oxygen Sensor Bank 1
- Inappropriate fuel pressure
- Faulty fuel injectors
- Intake air leaks may be faulty
- Exhaust gas leaks
P0141 FORD - O2 Heater Circuit Bank 1 Sensor 2
Possible causes- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit fuse
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit poor electrical connection
- Faulty Engine Control Module (ECM)
Sep 27, 2012 | 2001 Ford Taurus
Jandy Lite 2 LJ Water Leaking
I have the same problem, removed the heat exchanger and found a small rubber gastket that was ripped. The gaskets can be found at parts store. Set of 18 about $20.00.can.
May 27, 2010 | Jandy Lite2 LJ125 Ceramic Gas Heater
LLD125 pool heater leaking water from inside
My heat exchanger was cracked. I found an old welder who knew how to weld the cracks for $100 vs $900 for a new exchanger,. Also ordered replacement seals for the 2 chambers. I used high temp automotive engine sealant as an additional sealant precaution. Also inspected tubes and cleaned corrosion. Works fine last 3 years. Takes some mechanical skills.
May 18, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
The heater in my megane coupe (97) is a no goer and blows out cold! Great in the weather weve had! My Dad did try to fix a leak I had by puttin in some RADWELD and not long after - I lost my heat...is...
stop gap measures cause more problems than they fix
will have to replace the heater core ( if that was the leak)or fix the leak properly, flush out the cooling system properly and refill with the correct coolant conditioner mix
May 14, 2017 | Renault Sport Cars & Trucks
Coolant Leak
rear cylinder block core plug its behind the bell housing.It has been caused by running the engine with no antifreeze which also acts as an anti corrosion inhibitor .
Nov 20, 2009 | Jaguar S-Type Cars & Trucks
Coolant leaking into car from passenger side
Coolant passes through the heat exchanger below the dashboard heating the interior air from the engine heat. The heat exchanger or its pipe is leak somehow.
A temporary measure is to change the heat/cool knob to cold position. This disconnects the radiator.
Note: If the leak is before the valve then it will not stop leaking.
Also if you use the heater then You need to get the pipe repaired.
Aug 12, 2009 | 1986 Chevrolet Cavalier 2 Door
OES Genuine 2007 - 2009 Mercedes-Benz E63 AMG Engine Coolant Recovery Tank OES Ge Logo
55 people viewed this question
Top OES Genuine GPS Experts
Lawrence Oravetz
Ron Reynolds
Are you an OES Genuine GPS Expert? Answer questions, earn points and help others
