Question about HP LaserJet M1005 MFP Printer
How can i repair str z2062 power supply of my hp m1005 mfp laser printer ?
Str z2062 power supply burns
STR Z2062 is available on ebay (goo.gl/QZhclV) for People Living in India.The Burnout of the said IC is one of the main problems faced by many people.
Posted on Oct 28, 2015
    Habit-Forming:
  • 42 Answers
First of all; it is DANGEROUS to fix a power supply if you don't know what you are doing. Thus; don't even think about to open power supply tower, if you are not qualified enough.
If you are a qualified person, you can go on with below steps by taking risk on your own.
You must discharge biggest capacitors in order to avoid any fatal electrical shock. Even it is disconnected from electricity plug, power supply may keep high voltage in it for long time. Once you discharge big capacitors; you may diassemble power supply tower. At your question you mentioned about burned power supply which makes it a little bit easier. (I assume you discharged big capacitors) Once you open psu tower; do visual inspection on each capacitor. If there is a burned area start with it. Remove blowed capacitors and replace them with same valued new capacitors. If you can't see the values on blowed capacitors; you need to find board diagram of your psu. Otherwise you can't find suitable one to replace. Besides; check form of other capacitors. If there is a change on any capacitor's form, replace them too. The best way to find out dead capacitors is using capacitor testers. If problem caused by another type item; its not easy to find it as finding bad capacitors.
Posted on Nov 19, 2014
Testimonial: "HI Sir, How r u ? I'm experience technical person of this field. Capacitors r all fine. STR Z2062 and other small smd type resistance were burn. i was try to change str and resistance but power supply not worked. when i was plug in power supply and switch on power comes on 10v Capacitor ( who is Located after driver transformer ) for a second and disappear 2 or 3 second after. please give me more suggestion. thanks you for giving your valuable time."
  • Utku
    Utku Nov 22, 2014
    Hi Abhay; I wish i could help you more. I dont have
  • Utku
    Utku Nov 22, 2014
    Hi Abhay; I wish i could help you more. I don't have any circuit diagram or datasheet related with hp m1005 mfp laser printer power supply. At my previous comment; i thought that it might be common capacitor problem. It might be leaky components or shorted winding or... It is hard to say something without having any information.
Hi i need hp mfp 1005 smps circuit str z2062 circuit in smps board smd resitor like code r 502 504 506 pls send circuit giagram
try to find the schematic diagram here : PDF file :www.xtrade.kz/files/parts/HP/mfu/HP_LJ1005mfp_partlist.pdf
Dec 06, 2016 | HP Office Equipment & Supplies
Loss my drivers for HP Laserjet M1005 mfp
If you go to H.P's website and go to support imput that you need drivers for your laserjet m1005 mfp. and you will either be able to down load it right away or they will send you an e-mail with it or a link to retrieve one..Good Luck
Nov 15, 2012 | HP LaserJet M1005 Printer
Scanner 12 error
HP LaserJet M1005 mfp is not work properly. printer show scanner error 12 ple. solution
Nov 08, 2012 | HP LaserJet M1005 All-In-One Printer
My HP Laserjet m1005 mfp is showing error 6, please provide support and help us in solving the error
Jan 24, 2011 | HP LaserJet M1005 Printer
Sir my hp laser jet M1005 MFP printer driver give me plz
Hi
You can get the drivers from HERE.
Just select the Operating System and the Langauge which ever you want and you can download the drivers.
All the Best.
With Regards:-
Subhankar Ghosh
Nov 01, 2010 | HP LaserJet M1005 Printer
Hp M1005 Laser printer showing no print cartridge while I've replaced a new cartridge.
hi
it means you have a paper jam
open up the tray, take the paper out and place back.
switch off printer and turn back on.
i have just found this on the internet myself and I have struggled for a week, but now ok...
May 20, 2010 | HP LaserJet M1005 Printer
Scanner error 12
uninstall the software of scanner and reinstall it
check your cables for loose contacts
Jul 04, 2009 | HP LaserJet M1005 Printer
HP LaserJet M1005 MFP Printer Logo
1,200 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
