Hello my name is Helal. I have Sanyo 42" lcd TV have no picture but have sound. Screen black.
  • Televison & ... Master
  • 9,587 Answers
Look for a bad fuse on the power supply board. If all are ok then look at the board that has a flat ribbon cable going to the bottom of the screen. This board usually is close to the center of the screen once you take the back off the TV. Parts can be gotten from shopjimmy's web site.
Posted on Nov 19, 2014
  • 135 Answers
SOURCE: screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
Posted on Aug 23, 2009
  • 458 Answers
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
Posted on Oct 28, 2009
  • 8457 Answers
SOURCE: Sanyo 42" LCD will not turn on!!!
Power supply board is dead.Buy a refurbish power supply board at Shopjimmy.com,Ebay.com for the replacement.
Posted on Mar 26, 2010
SOURCE: screen is black but we have sound
The problem is a faulty inverter kit (2 boards).
I live in the Netherlands and had it twice, tv is 2 and a half years old! In the Netherlands Philips replaces the inverterkit without any
costs for the consumer (even after warranty time) cause they have
admitted that it is a production fault.Philips made a new inverterkit
which should solve the problem indefenit.Be sure the kit is Version
1.3! I had 1.2 after the first problem, and that went wrong after 7 months again. Today got revision1.3 installed which is Philips final solution.
Posted on Jul 21, 2010
Testimonial: "Thanks very much for your help. I will contact Phillips Ireland and see what they can do.Thanks again"
SOURCE: Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Posted on May 08, 2011
Hi I have teviono 42" lcd4203id model and tv is white picture nothing on there the TV powers up light comes on but it doesn't bring picture what the fault would be?thanks
TEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID
www.ebay.co.uk/.../TEVION-42...TV-MODEL-LCD4203ID-/1213...
eBayTEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID in Sound & Vision, Televisions ' eBay.Missing: white
main board for tevion lcd4203id 42" lcd tv mhdv4201 ... - eBay
www.ebay.co.uk > ... > Other TV & Home Audio Accs.
eBayMAIN BOARD FOR TEVION LCD4203ID 42" LCD TV MHDV4201-ZC01-01 (B) ... Mouse over image to zoom .... *Please open the back cover of TV then check the part number of screen, it would be on white label at back of screen ... of actual item in yourTV as well as check either if it is compatible with your TV model.
LCD TV Repair made easy # 1 - YouTube
? 7:38
https://www.youtube.com/watch?v=GryA_Zl4EBk
Aug 27, 2009 - Uploaded by Grants Pass TV Repair
I have a 2008 model Sanyo dp42848 42' lcd tv with ccfl lighting. .... bought a Seiki tv and within 1 month ...
LG 42LC2D 42 in. LCD HDTV Fusing unit - Que
Dec 29, 2015 | Televison & Video
My Sanyo 42" flat screen
There is a problem with the board of your television.That problem is in vertical section, theres a leak capacitor at the vertical section of the board.Its better to replace all the leak capacitor to make the picture back to normal appearance.If you can't do the repair or replacement of of capacitor try,Call a repair technician to do the repair or troubleshooting..Thanks..
Aug 25, 2011 | Sanyo 42 in. LCD TV
Teco 32" flat screen whilst watching my tv the
I would love to help you.
Please respond by PRESSING REPLY OR COMMENT
Did you experience any storms recently? IE. the power cut off unexpectedly?
Bruce
Jan 13, 2011 | Sanyo 42 in. LCD TV
My screen is not showing whole picture even when zoom not on
Hello; You need to select the best " aspect ratio or other name on the Sanyo remote" Read your Sanyo owner's manual or download it for more Info. John
Dec 19, 2010 | Sanyo 42 in. LCD TV
My 42" sanyo lcd has
Hello, a no picture with sound condition can be caused by several things inside your LCD TV. A power supply circuit with a missing voltage source could be one cause of the problem, an inverter circuit or HV circuit could be another. The best answer to your question is to have it checked out by a qualified tech. If you have a little knowledge of electronics you could try to repair it yourself, you can sign up for our great tech support where they can assist you on the steps to take to get it up and running.
Nov 06, 2010 | Sanyo 42 in. LCD TV
My Screen Went Black and i can only hear Audio.
Ur tv the LCD inverter board it dead.This board it help to get a backlight to ur LCD screen panel go through the Tuner board to produre a picture.Replaced this LCD inverter board u will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 26, 2010 | Sanyo 42 in. LCD TV
Sanyo dp42647 picture is black but has good sound worked great yesturday
sanyo lcd dp42647 turns on and has sound no picture black screen
Dec 27, 2009 | Sanyo 42 in. LCD TV
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
No sound and black screen
lets get together, start a list of names and sue companies selling crappy wares at way too high prices! email saryejade@aol.com
Nov 09, 2008 | Sanyo DP42746 42 in. Plasma Television
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
