<!-- from fixya rte -->Remote doesn't work,with cable cable - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,482 Answers
You should set the remote control with the set-up code said for your Cable box brand. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Nov 26, 2014
Doesn't receive signal from remote control
if it works intermittenly then the remote dosent need reprogrammed. SOoooo....
line of site comes to mind. your box needs to see what your remote shoots out. sometimes something ends up in front of the reciever spot on the cable box (FYI: a flashlight at the right angle can help find the sweet spot on most devices)
maybe the dvr is going bad watch EVERYTHING you want to see one last time and have it swapped (like death, you can't take anything with you)
good luck (I hope its just a line of sight problem)
Apr 01, 2013 | Motorola Mobility DCH3416 (160 GB) DTV...
Tv cable and dvd lights keep flashing and tv doesn't get signal
The remote is in safe mode, remove batteries and reinsert batteries while keeping the button 2 pressed.
Aug 04, 2012 | Logitech Harmony 200 Universal Remote -...
My remote stopped working, I changed the battery but it still doesn't work.
have remote checked out at advance auto,could be ur keyless entry sensor bad
Aug 21, 2011 | 2001 Ford Taurus
I need codes for a Symphonic DVD player...
Found this by google:
Symphonic DVD/CD player Model WF-104 worked with Comcast Cable remote
with code 0675
- If this doesn't help post the Model name too.
Jul 29, 2011 | Televison & Video
Can't get "no signal" off
Hey cthaemar, it sounds like it may have been switched off the correct channel. If it is hooked up with a Coaxial cable it will be on channel 3 or 4, and if it is hooked up with an AV cable then it would be on one of the inputs.
If it's channel 3 or 4 try pressing the gray TV button on the remote and changing the channel. If that doesn't work you may need to use the TV's remote or the TV itself.
If it's on an input press the same gray TV button and then try pressing Input. With this you can also try the TV remote or the TV itself to change those if our remote doesn't change it.
Let me know if you have any other questions or concerns!
Tommy Faust
DISH Network
Jul 12, 2011 | DISH Network 322 DTV Receiver
Wont turn on
try the following;
disconnect your remote lead, connect the remote terminal to the positive terminal with a piece of wire. If the amp powers up then the remote output from your headunit is at fault. You can connect the remote lead to a switchable live at the headunit end to work around this problem. The amp will switch off when you switch the ignition off and vice versa.
If that doesn't work then there may be a problem with your positive feed so check your fuse (there should be one near your battery where you see the amp cable connect)
If that doesn't work, check how secure your earth lead is, kicker amps use a lot of power so these connections need to made to a clean metal surface. Scrape the paint away if you need to, make sure you have bare metal to connect to.
Lastly, if you have only just installed the amp, check that you have thick enough power cable. As I said before, the amp will draw a lot of current, if the main power cable is too thin then you may not be getting enough current to power the amp.
Hope this is helpful.
May 07, 2011 | Kicker ZX-350.4 Car Audio Amplifier
Trying to incorporate my Hannspree remote with my cable remote as to use just the cable remote......? Thanks, ph
Hi, unfortunately the only way to use your particular brands remote with your cable companies remote is if the cable remote has what's called a "LEARN " key. This is used for cloning another remotes codes to the cable's remote. Unfortunately most tv suppliers don't provide their codes for universal remote use. The first thing i would do is contact your cable providers customer assistance to see if they have setup codes for your brand. then if that doesn't work then you can always buy a universal remote with a " LEARN " function, enabling use with hanspree tv as well as current cable box. I hope this was helpful and thanks, let us know how we did, Good luck ,Prodzilla
Apr 13, 2011 | Hannspree ST42DMSB 42 in. LCD TV
Remote doesn"t work. Only have
check that all of your cables are plugged in correctly and that the input is set to to correct cables on the remote there is a button that should say input press that a menu will appear and then you can scroll through your input options keep trying until one works
there is also usually a button on the tv that does the same thing
Mar 06, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Jan 17, 2010 | Vizio VW32L 32 in. LCD HDTV
Tv sound doesn,t work from remote ,but works on tv
Are you using an HDMI cable from your cable box to the TV? I found that the sound greatly improved and volume control was better after switched to an HDMI cable. Originally I was using component cables that were supplied by the cable company. Note: I bought my HDMI cable on line for $10. I've seen the same cable in the store for $35.
Mar 07, 2009 | LG 37LC7D 37 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
