Question about Bench Grinders
Is the 4A912B Dayton 10" 1 HP bench grinder 3 phase or 1 phase?
Looked for a manual online
  • 9,870 Answers
If the plug on the cord has 2 flat prongs and one round one then its 110 VAC single phase. If the motor has 4 wires then I'd suspect 3 phase. The data plate on the motor will tell you for sure.
Posted on Nov 19, 2014
3 Suggested Answers
  • 172 Answers
SOURCE: Need part numbers to replace eyeshields on Dayton bench grinder
Your grinder is listed on page 3085 of the Grainger catalogue. The part number for the eyeshield is 00281.00 and the number for the lower eyeshield bracket is 00280.00. The right hand upper eyeshield bracket is number 25188.00 and the upper left hand bracket number is 25177.00. All of this can be ordered through Grainger at 1-800-323-0620. Marvin T.
Posted on Jan 13, 2010
Testimonial: "This was very helpful. I have ordered parts from Grainger. Thank You."
rowdy45176
  • 2176 Answers
SOURCE: I am looking for a Dayton Bench Grinder Manual
I would try and call Grainger parts to see if they have one. I know they deal with and sell Dayton equiptment. If no luck let me know and I will try and find another source.
Posted on Mar 25, 2010
What would be a good replacement for a FLYGT 3152 3 phase grinder pump that uses guide rails?
you can still buy them
FLYGT 3152 3 phase grinder pump Google Search
Ads
  1. Grinder Pumps - saniflo.ca‎
    Adwww.saniflo.ca/
  • Grinder Pump Solutions, Ideal for Home Installation. Easy Install!
    Install Anywhere · No Maintenance Required
  • What's the Best Grinder Pump? - E/One Pumps Lead the Industry.‎
    Adwww.eone.com/grinder-pumps/sales-contacts
    1. Find Your Local Distributor & Get a Quote on Grinder Pumps for Your Next Project
      Proven & Reliable Pumps · Distributors Across USA · Industry Leader 45+ Years
    Search Results
    Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump 208/230V 3 ...
    https://www.sumppumpsdirect.com > Shop by Brand > Liberty Pumps US$1,363.60 - ‎In stock
    Buy Liberty Pumps LSG203M Direct. Free Shipping. Tax-Free. Check the Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump (208/230V 3-Phase) w/ 25' ...
    Grinder Pumps - Sump, Effluent and Sewage Pumps - Grainger ...
    https://www.grainger.com/category/grinder-pumps/sump...pumps/pumps/.../N-hv1 6 results - When it comes to Grinder Pumps, Grainger's got your back. ... 208/230VAC(3) .... Phase AC, Discharge NPT, Max Head - Pumps, Pump Body Material ...
    [PDF]3 Phase Simplex Control Panel Grinder & Vortex Pumps - Hydromatic
    www.hydromatic.com/resources/images/27454.pdf 3 Phase Simplex. Control Panel. Grinder & Vortex Pumps. Owner and Operational Manual. Your pump has 5 colored wires. White, Black, Red, Blue and Orange.
    Faggiolati 3 Phase Grinder Pump - Water Pumps from Pedrollo
    www.pedrollo.co.uk/pump.../Faggiolati_Three_Phase_Grinder_Pump_G271T6T1-_J... Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0. Online Catalogue ' Grinder Pumps ' Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0 ...
    Vertix 3 Phase 400T Grinder Pump - Pedrollo Distribution Ltd
    www.pedrollo.co.uk/pump-shop/.../Vertix_Three_Phase_400TGrinder_Pump.html
    Vertix Three Phase FTR400T Grinder Pump. Online Catalogue ' Grinder Pumps ' Vertix Three Phase FTR400T Grinder Pump ...
    images of other pumps that might suit you.
    Jul 04, 2017 | Grinders
    I have a Baldor 1022W grinder but i'm not sure how it is wired. I've tried looking for wiring schematics but have been unsuccessful. All I need to know is how to tell if the grinder is wired 115V...
    first off what does the plug look like? that would be one clue and also usually under the bottom plate there is a wiring breakdown. Let me know if you need more help
    May 12, 2011 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
    I have a Buffalo B-10CB(CH) bench grinder and the on/off switch has broken, it's a push/pull type. What can I replace it with to make it work safely?
    You could connect the wires of the switch together inside and bypass the switch. Then I would connect in the power cable a switch rated for 1 hp. You can use surface mount electrical box, with two cable connectors (one for the cable going into the grinder, the other for the cable going to the male cord end of the cable. Install a 120 volt switch inside the box (similar to the light switch in the wall). Make sure that the switch is rated for 1 hp. I would install the switch under the bench, under the grinder.
    Joe
    Feb 28, 2011 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
    I have a 1/3 hp motor with a capacitor. There are four motor leads coming out of motor, the capacitor is mounted in the wiring box. This motor does not have a centrifugal switch, to isolate the capacitor...
    I am in the process of replacing a capacitor on a Craftsman 6 in 1/3 grinder, 2.8 amp, single phase, 110v. Not sure on the centrifugal switch. model 319.190621, ser B9530. When I took the old one out the black wire from the capacitor went to the cluster of back wires (in my case 3) in the wire nut. The blue wire from the grinder went to red wire from the capacitor in a wire nut. Hope that helps you....
    Maybe you can help me... the specs on the capacitor burned off when it failed. Can you tell me what the capacitor specs are on yours?
    Nov 16, 2010 | Craftsman 6" Bench Grinder with Lamp
    I am looking for a Dayton Bench Grinder Manual...more specifically a parts breakout. Dayton Bench Grinder Model 1Z707W. Thanks, Mike
    Feb 16, 2010 | Grinders
    Jan 13, 2010 | Grinders
    Jet AFS-1000B Air Cleaner shuts down after running a short time.
    HI
    I know this stinks but if the ents to the motor are clean you need your motor rebuilt. There are probably many people in your area who can do this look in yellow pages for electric motor rebuilding, alternator, starter
    Dec 02, 2009 | Jet Equipment & Tools 577101 6 1/2 Hp 1...
    Bench grinder, 110/220?? wired up properly according to diagram on grinder, just turns on as soon as it's plugged in but it just humms, it does not spin the grinding wheel.it is a monster w/ a 3/4 hp...
    LIKELY the capacitor which is usually in the base is bad.
    The capacitor shifts the phase angle in one of the two windings which creates a pseudo rotating field to start rotation.
    Nov 07, 2009 | Saws
    Grinders Logo
    881 people viewed this question
    Top Bench Grinders Experts
    Dennis Boxerman
    Darrell
    Tom Chichester
    Are you a Bench Grinder Expert? Answer questions, earn points and help others
