Question about Splendide Washing Machines
New tvm63x splendide. Dryer stops and restarts during drying cycle. What could be causing this? Thanks.
  • Splendide Master
  • 9,587 Answers
Check for a lint build up in the vent hose. Too much will trigger a sensor in the dryer to shut off to prevent a fire.
Posted on Nov 19, 2014
ZJLimited
  • 17970 Answers
SOURCE: Splendid washing/dryer; washing cycle
You will need the agitator repair kit to repair it, that knob at the top shaped part just unsnaps, get a flathead screwdriver and pry it up and off. The knob part is #1 in the next diagram link, then pull the cap with the handle#23 up and off, then remove the bolt#2 then the upper part of the agitator will come off; check the diagram copy/paste this link in your browser...
Juts like a sample; here's the one for your model you can order -->> appliancepartspros.com/part_details.aspx?part_id=3138838&pn_=285811
Keep in mind that (generally) this kit comes with instructions and installation guide.
Posted on Jun 02, 2011
kapishtech
  • 2272 Answers
SOURCE: My splendide 2100XC is running through the cycles
"The red light will start flashing along with the pre wash light". There is a fault code on this.How much time the light blinks.does the light blinks non stop or does it blinks few times then stop blinking then again starts blinking.Exactly how many times the light blinks then pauses then again blinks. ------------- Example If the Status/Door Lock light, • Flashes 3-times • Pauses for 10 seconds • Then, flashes 3 times The machine is displaying an "F03" Fault Code. --------------------------- There is owners manual for your washing machine available.In that the details are provided about the blinking lights.click this link directly:----- http://www.splendide.com/splendide_wd2100xc.htm ------------ Also click this link for direct manual:--- http://www.splendide.com/service/TRAINMAN_Complete.pdf --------- It has been seen in some cases that. Prewash light flashing is a fill problem.
A faulty inlet valve or if drain hose is in a stand pipe it could be siphoning. Check the inlet valves to see if one has gone open circuit.
you should check:
1. The outlet pipe, for blockages or feeding into a blocked outlet
2. The pump: is something jammed in it?
3. The trap on the bottom of the machine: is it filled up? (Hard work; be careful!) (It is difficult to remove without damaging anything, and put back on, and you have to clean it very thoroughly before refitting)
4. The soap dispenser tray: is it gunked up badly? Wash that mould off!
5. Does the water dribble in? Check the inlet pipes, the filter where they come in, and the water valves in extremity. ---------------------------
If they are fine then its the control board at fault.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 23, 2010
SOURCE: Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
Posted on Nov 01, 2008
jumptrout51
  • 3361 Answers
SOURCE: dryer squeals off on during the cycle
The rear drum support must be replaced.
Part number 5303281153
Posted on Apr 21, 2009
  • 25 Answers
SOURCE: F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
Posted on Jun 03, 2009
How do you dry clothes in this machine please
A fairly common problem! The official instructions are
Before using your dryer, wipe the dryer drum with a damp cloth to
remove dust from storing and shipping.
1. Load clothes loosely into the dryer and close the door. Do not
pack the dryer. Allow space for clothes to tumble freely.
2. Turn the Cycle Control knob to the recommended cycle for the type of load being dried. Use the Energy Preferred Automatic Setting (,) to dry most heavyweight and medium weight loads. See "Drying, Cycle, and Temperature Tips."
3. Select a temperature setting on models with a Temp/Fabric selector. The cycle descriptions include temperature setting suggestions.
4. Push the START button.
Stopping and Restarting
You can stop your dryer any time during a cycle.
To stop your dryer
Open the dryer door or turn the Cycle Control knob to OFE
NOTE: The Cycle Control knob should point to an Off area when
the dryer is not in use.
To restart your dryer
1. Close the door.
2. Select a new cycle and temperature (if desired).
3. Press START
Extracted from
http://www.manualslib.com/manual/511763/Whirlpool-Lte5243dq.html?page=10#manual
Nov 14, 2015 | Whirlpool AWZ410 Front Load Washer/Dryer
Erratic Drum Operation
Can you clarify the problem, I don't fully understand what the actual problem is?
Oct 24, 2008 | Splendide 2000S Vented Washer/Dryer
My Splendide 2000 combo stops midway in the wash cycle. What is the cause and how can I fix it please?
If it doesn't go from the wash to the dry, check to make sure that both the washer and the dryer are set before the start of the cycle. It also could be blowing a fuse.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Sep 13, 2010 | Splendide 2100 Vented Washer-Dryer
Spendide 2100 won't do dry only cycle?
I own a Splendide 2100; it is installed on my sailboat. I love it, but it is a little picky. To do a "dry only", set the time you want and then ensure the dial is on "Reset" (doesn't matter which one). The LED should flash very slowly indicating it is ready to run a cycle. Turn the dial to the "Dry" indicator of the dry cycle you want. You will hear a very short gush of water (not sure why it does this) and the dryer will start. If you want to stop it before the time runs out, turn the dial to "Reset", power it off for at least a minute, then turn it back on. You should hear the lock click letting you know you can open it. Don't force the handle or you can break it.
Apr 10, 2010 | Splendide 2100XC
Drain pump continues to run during the drying cycle. Since this is a vented dryer there is no need for the pump to cycle on and off. The noise is annoying, and it is just shortening the pump life. Is this...
It actually sounds like a sensor or microprocessor fault, and yes you are right it would shorten the life of the pump. I don't think it is a "Design Flaw" But it does need to be looked at by a reputable service center/man.. Ask for a firm "Quote".
Feb 02, 2010 | Splendide 2000S Vented Washer/Dryer
Frigidaire Model FSE446RHS shuts off mid cycle
Hi, If the motor is shutting down mid cycle and can not be restarted untill cooled, the motor will need changed. It is shutting off on a safety overload. These motors cost about $145.00
Please let me know if I can assirt you further.
Vic
Jun 01, 2009 | Dryers
Aug 24, 2008 | Splendide 2100 Vented Washer-Dryer
Splendide 2000 doesnt work at all on wash
I have exactly the same issue. The door normally locks, but doesn't do anything on wash.
Jul 29, 2008 | Splendide 2000S Vented Washer/Dryer
Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Washing Machines Logo
102 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
isaac johny
isaac johny
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
