Question about Garden
Adjust needle valve?
Changed gas, restarted umpteen times, arm sore from restRting every two minutes
  • Carole Sheaves Nov 19, 2014
    Leaf blower is a McCulloch MB3201
    Sergeant:
  • 253 Answers
Sounds like a float bowl prob.... follow the gas hose from the tank to the carb.... little bowl on bottom will have 3 to 4 screws holding it on...remove carefully... the float on the inside will have a needle that plugs off the hole the gas comes through when the bowl is full then allows more gas in as it empties... yours probably has varnish( old gas) restricting the movement of that needle and not allowing gas in fast enough... clean it with emery cloth and the tube that the needle fits into with a small needle... if it is real bad soak it in straight gas line cleaner for the night... hope it helps
Posted on Nov 20, 2014
  • 4 more comments
  • Carole Sheaves Sep 24, 2015
    Where ids the bowl
    No bowl on Mcculloch blower?
    How to find needle
    How to adjust needle
    How to adjust carburetor needle
    How to adjust carburetor needle?????
  • davis bugden Sep 24, 2015
    Unless you have adjusted a carb needle before take it to the small engine mechanic.... easy to fu K it up
My kymco leaks gas from the overflow on the bottom of the carb constantly I have cleaned the carb many times and tried to adjust it at the needle valve but still leaks from the overflow
Hi Shannon:
Possibles:
- Needle valve has been compromised, possibly held open with grit.
Carefully dismantle and blow out all orifices with compressed air.
- Float level set too high. Review the way the float shutoff mechanism works. Make sure the float moves up and down easily and that it still floats as intended. Double check the lever that moves the needle valve. Make sure it is correctly connected to the needle.
Reply as a COMMENT to this post to let me know what you find.
Cheers.
Feb 22, 2016 | Kymco 2010 MXU 375 IRS 4x4
Why does my rocker arms clack away after motor warm up on 85 1340.
you could have a worn camshaft or valve lifters or valve train components like rocker arms or you need to adjust the valves. too thin of oil viscosity or oil that is not changed for long times can do this as the oil thins out.
Sep 19, 2014 | Cars & Trucks
Need help starting a gx340 honda with new ring kit ,honed cylander,lapped valves,adjusted valves with new ex valve seal.started warmed up and changed throttle level from low for 10 min to med for 10 min...
If there is air in the tanks, it will be harder to crank, drain air out before starting, Also check spark plug. Sometimes i put gas where the plug goes, just a little pinch of gas though. put spark plug back and give it a few cranks.
Oct 02, 2013 | Honda Jenny GT8HGB-30P 8hp 30 Gallon GX...
\If ryobi 410 r tiller sits in the upright position for a few days cylinder fills with gas. what is the problem?
try www.jackssmallengines.com for parts carburetor has something not allowing the needle to seat properly
Sep 13, 2012 | Ryobi Cultivator
1995 Olds Silhouette rattled badly, died while running
I think you had better have a local shop inspect this for a failed engine connecting rod.
Aug 23, 2012 | Oldsmobile Silhouette Cars & Trucks
Mower is stalling out loosing power when i mow changed spark plug put a new air filter on and still wont run also changed gas out but wont run dies out when i mow
check main valve in carberator for dirt adjust main feed needle close and open to 2 full turns and adjust from their for max power
Aug 19, 2010 | Toro Lawn Mower With Toro Power Tools
I own a 2004 TTR-225-S and when we try to start it will not get any gas to flow to the carburator
remove fuel line from petcock and see if fuel runs out, if not remove petcock from tank and clean filter screen, if it does come out, check for inline fuel filter change it, if it dont have one check fuel pump if it has one, or could be diaphrams in carb split and not building vaccuum to draw gas thru
Apr 11, 2009 | 2004 Yamaha TT-R 225
1983 Ford F250 will start but won't idle without holding down gas
hi! there, its really help good of replacing old ones,perhaps the condition of current flow to ignite continously your combustion due insuffcient current supply from your ignition system could positively stop your engine,if you maintain this ignition system the engine won't stop running.in such a case this type of model need mostly to be tune up some internal part on the head cylinder should take place of correctnes such as intake and exhaust valve,the rocker arm seat valve and spurk plug.if you done this your worry will be lessen.have a nice day.
Apr 02, 2009 | 1983 Ford F 250
Garden Logo
185 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
