Nothing
First we need to know what brand and model your vacuum is. But usually you would make sure your vacuum is unplugged. Flip it over and look at roller brush part of the vacuum and find the screws that can be unscrewed to remove the cover of the rotating brush. Once that is off, you will find find a belt on the side of the roller that will need to be removed if broken. You will need to pull out the roller and put the new belt in and stretch it to the motor part which will sping the belt causing to spin the roller brush. Then reassemble and screw cover. Plug vacuum and happy cleaning !
