Question about Coleman Heating & Cooling
Where can I get a schematic for a Coleman 3500A816 air handler?
I'm currently searching online. I'm trying to fix a broken down unit that continues to send power to the heat strip when the fan is not functioning. There are a couple of disconnected wires inside and I want to find out where they belong.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
With some units you must set thermostat to fan on to get the fan to run in heat mode.. or it could be a bad motor or fan relay . Generally in electric heat units one side of heater is always live then the sequencer turns heater on when thermo calls for heat.
Posted on Nov 30, 2014
farfield
  • 462 Answers
SOURCE: when I turn the air on the heat strips comes on at the same time
Is this a central heat? From the size i assume it is.
You say air conditioning on part of your question then use heat pump on another part. So it is important for us both be on the same page.
With all due respect some people think they have a heat pump and it is just AC and electric heat also but is not a heat pump.
. If you have the outdoor AC unit running with your thermostat set for heat and the air coming off the out door unit is cold, or you see it "steam up outdoors" off the out door unit at times (we call this mode defrost).
If you actually have a Heat pump system some times it is wired to have the strips come on at the same time the heat pump comes on especially if you experience a lot of weather below 40' occasionally and have an emergency heat setting on your thermostat you most likely have a heat pump.
If you have a heat pump for sure now the heaters can come on with the outdoor section if
1 they are wired to do so or
2 the thermostat has 2 stage heating and the second stage is telling the elements to come on, or
3 the outdoor thermostat (if so equipped) is telling the elements to come on.
Any 1 or combination of these 3 items can cause the elements to come on wit the out door unit.
Posted on Mar 12, 2009
SOURCE: Wiring Diagram for Ruud Heat Pump
Unfortunately, the wiring diagrams for heat pumps are not so easy to come up with. The outdoor unit will have its own diagram, but may not include the indoor air handler and will probably not include the thermostat. That said, the orange wire is commonly run from the thermostat to the reversing valve in the outdoor unit. This wire is usually not connected to the indoor airhandler. The orange wire is usually used in a unit that has the reversing valve energized in cool. Ruud, however has its reversing valve energized in heat. Probably not useful but maybe helpful
Mike
Posted on Mar 26, 2009
  • 16 Answers
SOURCE: Goodman forced air gas furnace not firing
if your power vent moter is not running you should not have have glowing ignitor.Frist the vent moter must close an air prove switch in series with the idnitor .seems you have a stuck air prove switch.Its the one with a hose attached
Posted on Apr 07, 2009
co7196
  • 3433 Answers
SOURCE: coleman rv rooftop unit, fan runs in on but in auto nothing works
R = HOT 12V
W= WHT- GND
Y = YELLOW / POSSIBLE THERMOSTAT
G= GRND FOR THERMOSTAT
f = FAN
F=FAN
aSSUMING THIS IS A TWLVE VOLT SYTEM- The two f's Would be fan control intake and exhaust - fan direction
White is always ground and so is green.. green is more of a static ground where white is a load grnd.
Red is always hot. in low voltage
I hope this helped. No instructions in kit?
Posted on May 18, 2009
SOURCE: Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Posted on Aug 19, 2009
Fans working outside but no air is coming inside, on my 3 ton air conditioner
Check air handler up in attic follow stat to power box on handler look for blown fuse.pull power at unit first
May 22, 2014 | Coleman Propane Forced Air Heater...
Need wiring diagram ,colman central electric furnace 3500a816
I have the diagram pasted to the cover over the sequencer. I only have a 5 megapixel camera, but I am willing to try and get a picture of it if it will help.
Nov 03, 2010 | Coleman Heating & Cooling
There is no schematic or number on air handler .outside unit is Goodman # CPE48-1FB.How can i get a schematic for Air handler.
I need more info than just the outdoor unit number. The air handler will be a specific number. If you pull the access panel off the heater, there will be a faceplate inside with the unit name and model number as well as a schematic on the back side of the door.
May 12, 2010 | Goodman CKL60AR60 Air Conditioner
Inside unit freezing
There are varius items that make the unit inside (air handler) freezes up .If the fan motor in the air handler doesn't work it'llice up.If the filter is dirty it'llfreezes up. If the coil in the air handler is dirty it will freezes up.And if the unit is low in refrigerant(freon) it'll ice up.If is low in gas means there's a leak and before recharged it needs to be fixed.
Apr 23, 2009 | Heating & Cooling
Jan 05, 2008 | Heating & Cooling
Heating & Cooling Logo
104 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
