Question about Canon Ir 3300 Black & White Copier
Error code E000064-0000
My machine showing E000064-0000 error code in two side printing. and paper has jammed in the Finisher section. i can replace the charging ruler and Drum but still it's showing above error. but single side printing and copy works are not showing above error and machine working properly in single side copy works. what can I do?
    Sergeant:
  • Canon Expert
  • 224 Answers
E064-0000 Description The presence of a high-voltage error is communicated by the composite power supply PCB (The output for primary charging, developing, or transfer has deviated from a specific level of voltage) Causes The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty. proce Remedy 1. Contact Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact? YES: Clean the contact, and set it once again. 2. Wiring Is the wiring between the contacts for the following normal: DC controller PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller? a. DC controller PCB (J301) <-> composite power supply PCB (J136) b. composite power supply PCB (J130-7) <-> primary charging roller contact c. composite power supply PCB (J130-1) <-> developing assembly contact d. composite power supply PCB (FT133) <-> transfer roller contact NO: Correct the connection. 3. Composite power supply PCB, DC controller PCB Try replacing the composite power supply PCB. Is the problem corrected? YES: Yes. NO: Replace the DC controller PCB
Posted on Nov 21, 2014
Why can I print a test page out but with regular printing it jams and gives c-1182 error
Finisher motor issue, remove the finisher/and unplug does it work?
what are you printing are you using staple or hole punch try printing single sheet of paper.
Jul 08, 2014 | Konica Minolta bizhub C250 All-In-One...
Xerox docucolor 240-250 not stapling/folding, error codes 012-243, 012-229, 012-225
Koday Hero 7.1 carriage jam. Stuck to the left side. No paper jam can be found but can't get the carriage to move.
Nov 15, 2013 | Office Equipment & Supplies
Ricoh MP 5000, says it has a paper jam, but I can't phyicial see a jam, wont print, scan, copy, or fax
if the jam still shows when you turn the machine off and on then you will have to look first to see which tray you were using at the time take the tray out and look inside the frame to see if paper has stuck by the feed rollers then open the side paper path guide to check non is on teh way up from there the next is reg transfer and fuser sections also pull the duplex out to make sure its not under the travel plateand last is to check betweent ehfuser exit and finisher opent he dooor on finisher if you have one and lift the plate at top right had the paper can sometimes be hidden there... failing that the sensor for the paper exit from fuser to duplex can sometimes jam a small bit there...if you know how to get into the sp modes you can go to data log 1 there you have the jam counters and jam history look at latest and the area will show up where it could be last. good luck A..
Jun 26, 2009 | Ricoh 4506 Copier
Error code E584 and paper jams
• Feeder motor , • Shutter closed sensor • The shutter closed detecting switch does not turn on even when the feeder motor has been driven in reverse for 1 sec or more.
clear dust from the finisher sensor
Feb 23, 2009 | Canon imageRUNNER 400S Copier
Docu color 252 fault code 012-324 ???? Bill
HERE is the manual for your unit.
HERE is the online support page.
THESE are all the available documents for your Copier
Your error code 012-324 is not listed in any documentation.
Is there something it is doing/not doing when this error comes up?
Their customer service will help you with the error code.
Please call 1-890-925-050 and have your 10 digit serial # available.
Thank you for Using FixYa!
Jan 20, 2009 | Xerox DocuColor 12 Color Copier
Error message on Cannon IR 3300
that is a stack delivery error could be one of the motors or a board do you have the internal finisher or external
Jan 13, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Intermittent error code E713-0004 Already replaced every board in copier and finiser (R-1). Also replaced the wire harness from copier to finisher, even tried another R-1 finisher, still throws code.
E713-0004 -05 Title Finisher IPC communication error (checksum error)
Remedy 1. Check the cable connection of the Finisher.
DC Controller side: J462, Finisher Lattice side: J9043
2. Replace the Finisher Controller PCB.
Description Communication between the host machine and the Finisher was lost
Dec 18, 2008 | Canon Office Equipment & Supplies
Canon iR8500 with Error E000583-0001
Hello Jeremy,
This error code has to do with your finisher. The auxillary tray is not finding its home position or does not leave the home position within the alotted time. Check for binds. I have limited exposure to the K4/3 finisher but try this. Turn the copier off, and open one of the finisher doors. Now turn the copier back on with the finisher door open so it cannot initialize. Once the copier is basically ready except the finisher door is open, close the finisher door and observe all the **** (and theres alot) initialize. This may help determine the problem. I hope this helps...........................SPINAL
Mar 12, 2008 | Canon imageRUNNER 8500 Copier
Canon Ir 3300 Black & White Copier Logo
176 people viewed this question
old marine
old marine
