Question about Dryers
Why does the amish electric fire place goes off when switched to high
  • 14,363 Answers
Hi Melvin,could be the heater is drawing too much current from the wall socket or wiring is loose,try another plug in from a different room.
Posted on Nov 19, 2014
Do the Amish vote in presendential elections?
Amish electoral participation is limited, though some Amish do vote
Nov 11, 2016 | Cars & Trucks
Are the Ohio Amish backing Trump?
mate google Amish communities
you do no understand the Amish beliefs or culture
Oct 27, 2016 | Miscellaneous
How do I clean the dust from an Amish fireplace
This shut down is a safety feature on the unit so it doesn't over heat.
You need to remove a cover that's in the back on the bottom and
take compressed air to blow out the dust. Concentrate on the
blower especially. Best done out doors.
This is also a good opportunity to see if the blower still turns
freely. If not it'll need lubed or replaced.
Sep 01, 2014 | Unknown Heat Surge Amish Crafted...
2002 fxdl no power white wire high beam indicator on dash indicates high beam is on still no power
Well, electricity is electricity and wiring circuits are wiring circuits. I do not have a 2002 fxdl electrical service manual either so cannot help there. On a 2003 the white wire goes from the headlight to four pin connector 38B and from there to four pin main harness connector 38A pin 2 and from there to connector 20A pin 4 and from there to (fxdl only) connector 21A pin 2 to connector 21B pin 2 to high beam indicator light which has BK wire ground going to 21 B pin 6 to 21B pin 6 after which it joins other BK ground wires to speedo and to 20B pin 12 and then to 20A pin 12 to TS/TSM pin 12 (ground)
POWER from ignition switch into lighting 15 amp fuse by connector 38 pin C R/BK and out from fuse by BE to connector 24A pin3 and out connector 24B pin 3 BE into handlebar switch then out from handlebar hi/lo switch into connector 24A pin 4 W and then out from 24B pin 4 W to connector 20A pin 4 W (which joins to speedo connector 20B W and also goes to connector 38A pin 2 W which goes to 38B W pin 2 to the headlight high beam element on the right side pin with the low beam element connection on the left side (on the wiring diagram) (Ground wire is also on the (diagram) right side and goes also to HDI position lamp is on the bike and HDI position light power is from connector 38B pin 1 O/W etc.
Connector 20 is a 12 place Multilock is console gauges connector located under the console on fxdl
Connector 21 is a 10 place Multilock console gauges connector located under the console on fxdl
Connector 24 is a 6 place Deutsch left hand controls and horn connector located on the frame backbone
Connector 38 is a 4 place Multilock headlamp connector located on the frame backbone
Jun 19, 2014 | Harley Davidson Motorcycles
My heay surge stove will run for awhile and then shut down
The heater is thermostatically controlled, so once the room temperatures reaches the heater's preset temperature, the heater cycles off. This is normal.
However, If the heater goes off BEFORE the room reaches the preset temperature, suspect a high temperature safety switch that may be tripping. Does the heater come back on after it cools down?
Oct 08, 2013 | Unknown Heat Surge Amish Crafted...
Powerboards
When place face up, dust and fibre gets in and jams up the contacts of the switch. Common problem with powerboards. Bad
contact and high current can create much heat. Be aware of fire danger.
Jun 10, 2013 | Video Game Consoles & Games
How to clean amish heaters
I was told my Amish heater only needed taken apart and cleaned to make it work nicely again, So is there any instructions that I can look at while I do this so that I don't mess anything up inside the unit ?
Oct 30, 2012 | Heating & Cooling
Can you get Amish furniture picnic tables?
Yesyou can get all types of tables in Amish furniture, but I've seen some reallynice picnic tables - see this link http://www.pinecraft.com/amish-outdoor-patio-furniture/amish-outdoor-patio-tables/amish-picnic-tables.html#.UA-pZfX_nos
Jul 25, 2012 | Furniture
Dryers Logo
76 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
