Question about Air Tools & Compressors
Gas leaf blower runs for 2 minutes, then stops
Changed gas, tried adjusting choke, still quits , then need to pull starter again. Grrrrr
  • 4 Answers
Have change the spark plug yet
Posted on Nov 19, 2014
My Weed Eater FL1500LE will only run on full choke and will stop when changed to half choke or throttle is moved from fast idle to any lower speed. I have replaced both fuel lines, thoroughly cleaned the...
It is obviosly fuel starvation, have you actually replaced the fuel filter on the end of the hose in the tank? try richening the fuel mixture by unscrewing the H and L screw on the carb 1/4 turn on each, you may need a special tool to grip and turn these.
Sep 22, 2013 | Weedeater 2 Speed Gas Blower FL1500LE ()
Why does a leaf blower keep stalling after a period of use?
Ignition coil may be getting too toasty. Full throttle for 10 minutes.. yeah man no one does that. If factory calls for 50:1 gas/oil mix then richen it up to 40:1
Aug 21, 2013 | Poulan Garden
Gas blower engine surges and shuts off when engine gets hot
check your fuel lines for cracks, could be sucking air or could be your carb needs cleaning, make sure you clean the screen inside the carb, if you run it with the choke on partially does it smooth out and quit surging, if so it is definitely a fuel problem. Hope I helped you. 2StrokeJim
Nov 27, 2011 | Poulan 25CC Gas BlowerVac
E-250 purchased in 4/2010. Last month or so it runs for 2 to 3 minutes very erratically constantly requiring the choke and speed to be varied. Now it runs for about 30 secs and quits for good. I cleaned...
You need to pull the hose from the tank and check it. Also check the carborator. I would pull the carb and soak it in oven cleaner for about 10 minutes. Spray it very good then rinse it well. That should clear things up.
Aug 28, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
ECHO PB-500T - Stopped running and added gas fuel mix. Quit running again with full tank and now flywheel is stuck and I can't pull to start it. What is the problem?
My $350 Echo PB-500T seized up. I almost cried.
The solution was to drain the fuel tank.
  • Refill fuel tank with an 2-cycle Oli/gas mixture.
  • 40:1 =3.2 oz to one-gallon gas, do not use Alcohol base gas.
  • Remove the spark plug.
  • Pour approximate 1/8 oz 2-cycle Oli into the spark plug hole.
  • Remove the pull cord assembly (4-bolts)
  • This reviled the crank shaft-Pull cord bracket
  • I use a large monkey wrench to turn the shaft (CW) Clock-wise.
  • Complete approximate 20 revolutions.
  • Reassemble, but don't install the spark plug yet.
  • Complete approximate 20 more revolutions
    by pulling the pull cord.
  • Use q-tips to swab the top of the piston, as much as possible.
  • Install the spark-plug and crank, it will smoke for amount 7-10 minutes
Jul 30, 2011 | Echo Gas Blower 162 MPH 450 CFM Blower...
Wont idle have to run on 1/2 choke
yes, i have one myself. you must adjust the carb. there should be two screws to adjust the gas and air flow. try adjusting them to the right, both of thlem
May 15, 2010 | Homelite Consumer Products MightyLite...
Mb 3200 gas leaf blower will start when choke
The carburetor could need rebuilding or you have some bad gas. I would mix up some 2 cycle oil and fresh gas from the station. I would try the new fuel mixture first.
Good Day.
Nov 02, 2009 | McCulloch 26cc Gas Blower Mcb3208
I don't know how to start the blower (gas powered) and I don't have the owner's manual...any help is appreciated. There's the choke, the primer, and the blow strength gauge
I would push the primer in about 3 times, then pull the choke out, then try and start it. It probably won't start, but it might turn over. Then push the choke in and try starting it again. It should start within the next 2 pulls.
Sep 01, 2009 | Poulan Featherlite Gas Blower, with Low...
Leaf blower will not achieve full RPM's
try removing the muffler and scraping out any carbon build up in the exhaust mouth of the block. if that doesnt help you will probably need to replace the carb.
Nov 15, 2008 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
