Question about Kitchen Ranges
Where is the breaker or fuse for the oven light ?
When changing the oven light bulb (not knowing if the oven light switch was on or off because the bulb was burned out} the glass part of the bulb separated from the bulb base and created a spark which I assume shorted out a fuse or a breaker somewhere in the stove circuit. what I want to know is the location of fuse or breaker. I really would like a wiring diagram for this range.
  • 9,742 Answers
Check for a tripped breaker in your power panel for the house. There's where the breaker for the oven is.
Posted on Nov 19, 2014
Testimonial: "It is not the breaker for the stove at the main power panel. the rest of the stove works ok. It is just the circuit for the oven light . If I had a wiring diagram for this stove I could trace it and find it myself."
  • Lawrence Oravetz Nov 20, 2014
    Look on the internet for a diagram. The manufacturers web site may be helpful.
3 Suggested Answers
iwillfixforu
  • 619 Answers
SOURCE: Whirlpool GR450LXLQO range while changing oven
You will have to replace the light socket. Part number is 3150505 at approx. 30.00. Hope this helps
Posted on Feb 03, 2010
mkh5094
  • 145 Answers
SOURCE: correct wire gauge and circuit breaker to use?
If it is only the oven that is electric and not the entire stove, the required wire size is 10/3 with ground and a 30AMP circuit breaker. If it is the entire stove then you need 50AMP range cable and a 50AMP breaker. If your doing your microwave also, you need a 20AMP breaker and the wire you need is 12/2 with ground.. If the current breaker you were running was 30AMP I would keep that for your oven and run new wire for your microwave.
Posted on Apr 30, 2010
Is there an internal reset button?
The short may have blown an internal fuse.
Jan 20, 2015 | LG LMV1630ST Microwave Oven
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
The under unit light burned out and tripped the circuit breaker. Replaced bulb and reset breaker but light doesn't work. I see there is an internal fuse. Could this be the problem as there is no power...
These remarks are not make and model specific.
Did you test the new light bulb?
I would not normally expect a burned out light to trip a breaker.
You may have a blown fuse. I suspect the fuse you see is to protect the oven. If you popped a breaker, you may have blown a fuse. I'd be looking for a short somewhere, maybe in the wire that powers the light, maybe in the hardwire that supplies the oven.
Make sure you turn the power off before you go poking around. And, above all, avoid the silver can inside, it IS lethal.
Let me know if this helps.
A
Sep 21, 2009 | Maytag MMV1153A Microwave Oven
Changed the lite bulb on ge double ge eletric oven and it blew
There is no reset switch on the oven you blew the breaker in the control panel. you will have to find it and flip it.
Dec 21, 2008 | GE Profile JTP56 Electric Double Oven
The vent fan and surface light do not work
1. Check your circuit breaker for this m/w. Reset it.
2. Microwaves usually have 20A fuse inside. It could be broken.
Dec 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
AEG D2160 Double Oven - electrical fault
you may find that one arm of the oven selector switched has fused to its contact.
Sep 07, 2008 | Ovens
GE Spacemaker XL1400 - lights underneith don't work.
Check power outlet and breaker , recock breaker .
Open oven fuse test both end , test power cord both, if those testing point okey , try plug power and test it .
Jan 17, 2008 | Samsung MW1030WA Microwave Oven
Re: Solution #1 Nov 1,2006
This rarely blows the internal fuse, but the fuse is located either behind the control panel on the floor of the oven or on the door switch holder. You can send us e-mail via our Web site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Thanks very much.
Apr 15, 2007 | GE JVM1630 Microwave Oven
Kitchen Ranges Logo
132 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
