Question about Tablets & eReaders
Can the battery be replaced for a irulu ax740 if so how or where can one be bought. I can't get it to hold charge.
What do I do with a screen showing a battery/triangle/!
Unfortunately Irulu tablets are cheap Chinese junk. If you get 8 to 10 months out of one you are lucky. We had a guy on here a few months back who had three in 8 months for his kids. They are sold as an entry level tablet to see if you want to spend the money on an iPad, Samsung or Asus.
Try a reset. Hold the Volume Up button and the Power button until something happens.
If that doesn't work hold those two buttons plus the home button for a factory reset.
Apr 19, 2016 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Why doesn't it stay charged?
Have you tested the battery? Probably not holding charge cause its done, old, defective!? How old is your unit and have you ask about replacements for it?? Just my suggestion. THen check out the ease of installing a new one!! Way cool!!! Good luck my friends
Jan 24, 2016 | Irulu 7" 4gb Google Android 2.3...
My irulu X7 will not charge unless I hold charger n place. Otherwise it won't maintain the connection. What can I do?
If it's tha chargering socket, nothing. Ig it's the charger's plu, try to replace it.. I don't know wht kind of a charger is used by Irulu, hope it's a standard cable.
Aug 09, 2015 | Tablets & eReaders
My IRULU tablet will not charge.How can I fix it? Is there an internal battery,where is it?
Either the charger or connector has a problem. There is a battery, but it is not a normal replacement item. You will find the battery behind the back cover.
Jun 16, 2015 | Irulu 7" 4gb Mid Google Android 2.3...
I bought two irulu tablets but the both broke in the same exact spot, in the charging port. the pin broke out and i cant charge them now. Is this a flaw with all irulu tablets or just the two I bought
I would definitely follow your friends advice. If they are under warranty, you should be able to get them fixed. If the battery can come out of the tablet, you can use a universal charger to charge the batter, but I am assuming it doesn't.
If you know how to solder, then you could replace the port yourself, but this is risky, so getting pro help is the best bet.
Feb 14, 2015 | Tablets & eReaders
How do I reset my tablet
Depending on age and usage I'd check the charger you're using. If charging from a PS, and not the USB port on your computer try the computer. If it's older and has been used often, might be the battery. For the later I think you will need a tech to open it up.
I think it has a one or two year warranty, did you register it when you bought it? There is a white sticker under the stand which has the SN, then call the maker and see if they can help.
Feb 12, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Why won't my tablet turn on?
Damaged charger? Damaged battery? Damaged Screen?
Try charging it for 8 hours. Stick a pin or paperclip in the rest hole and hold your breath.
Dec 11, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
My irulu 7" tablet will not charge it will only flash on and off
Most probably the battery is dead. If you allow the rechargeable batteries to be discharged below 10% of its full capacity then damge may result for the battery. Changing a tablet battery is an expert's job. Generally this will be soldiered to the wires. So desoldering and resoldering with a new battery are involved. While the batteries are not very costly the replacement service may be costly. Better contact the manufacturer/supplier of the tablet.
Jan 08, 2014 | Irulu 7" Google Android 4.0 Capacitive...
My 7 inch irulu tablet does not charge
Try a different charger that is capable with your device, check battery, or reset if you can. Luck to you
Jan 04, 2013 | Tablets & eReaders
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
