Question about Straight Talk Motorola EX431G Cell Phone
Ex431g is stuck on vibrate/silent mode. won't ring
Pressing #, pressing button lower left
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
How do I turn off silent mode on my Lg 365 as choice seems to be silent or vibrate and cannot find profiles under settings as stated in manual
The quickest way - on the left side of your phone there is a button with up and down arrows. Keep pressing the up arrow and this will raise the volume up, or keep pressing down and you can set it to vibrate or silent. Also, you can change it from the menu. Go to Menu > Settings > Audio & Ringtones > Ringtone and there are all of your options here. You can go to Volume and set the volume, Alert Type and set if you want it to vibrate/ring, etc. I hope this helps, if you still have questions feel free to ask :)
Apr 28, 2011 | LG Neon GT365 Cell Phone
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
Lg 720 shine will only vibrate, will not ring
Press the "Star" button on the bottom left of the keyboard for a few seconds to get it out of the silent or vibrating mode.
Jan 17, 2009 | LG Shine CU720 Cellular Phone
Cect a8+ unable to put on silent mode when phone is ringing
i) when phone is ringing, you  have only two options either to 'answer' the phone or to 'reject' the phone, otherwise you dont have any option keeping ur phone in slient mode at that point of time(when phone is ringing).
ii) however you can keep ur in slient mode without going to your profiles by just selecting(# button) from number key pad(where u normally dial phone number......), you have to press hold # button to go into silent mode and press hold same button to come to ur general profile
iii) I'm using same CECT A8+(IPHONE), you can ask me any questions in future.............
Thanking you
M. Sridhar
Jan 05, 2009 | Dual Electronics CECT P168 Cellular Phone
Iphone silent mode
The best way to fix this is to hold the Power and the Home button for 15 seconds or so, basically hold them both until the Apple Logo reappears. I work at o2 and have seen this problem a few times, its nothing major, just annoying
Hope this helps guys
Alen Boardman
Aug 23, 2008 | Apple iPhone Smartphone
Can't turn off the mute on my phone
I have the same phone, when you close it with the camera facing you you will see the two buttons on the left side. One is long (on top) and the small one is on the bottom, or under neath it. You press the long putton which is above and you should see the word STYLE: followed by either "Silent" " Vibrate" "Loud" etc. Once you have pressed the skinny long button on the left side and the screen says STYLE: silent then you press the little button below it once, then press it again, etc it cycles through the different ringing modes like silent, vibrate, vibrate then ring, soft, and loud. You press it until you see a setting you like and then press the long skinny button on top to set it. I keep mine on Loud. I hope this helps.
Jun 10, 2008 | Motorola Mobility E815
Stucxk on vibrate
As per instructions of the manual:
"...Your microTALK® radio can alert you to incoming signals by
sounding an audible call tone, by vibrating silently or both. To change call settings:
1. Press the Lock/Mode button until the Call Setting icon flashes on the display. The current setting (“01” vibrate + ring, “02” vibrate only or “03” ring only) is displayed.
2. Press the Channel Up or Channel Down button to change the call setting.
3. Choose one of the following:
a. Press the Lock/Mode button to enter the new setting and proceed to other functions.
b. Press the Hi•Low/Enter button to enter the new setting and return to Standby mode
Should you need a copy of the manual, it is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 16, 2008 | Cobra 22 CHANNEL 2-WAY RADIOS
Stuck on silent mode and cannot get the ringer to ring
All you have to do is hold the pound (#) button down. It will then say exit silent mode. If you ever want to put your phone back in silent mode, just hold the pound (#) button down.
Dec 22, 2007 | Samsung SCH-a870 Cellular Phone
İPhone not ringing
you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
cheers!
Nov 15, 2007 | Apple iPhone Smartphone
Straight Talk Motorola EX431G Cell Phone Logo
Top Straight Talk Cell Phones Experts
Mike
Mike
Computer Repairing
Computer Repairing
cwradio73
Are you a Straight Talk Cell Phone Expert? Answer questions, earn points and help others
