Question about Garden
Having trouble with noise from the drive system and failure of drive belt
  • 1 more comment
  • Eugene Rounds Nov 19, 2014
    Hi Ed Grant, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Will need make and model info. Also which belt has failed; some mower used multiple belts in both deck and drive systems?
  • Ed Grant
    Ed Grant Nov 19, 2014
    The scag tiger cub mower uses separate belts for the hdy. drive system and the mower deck. I am sure that the noise is coming from the hdy drive system. the noise increases with engine rpm increase.
    The reason ask the number of belts as you specify which equipment you had. You reply narrow it down to 35 Scag Tiger Cubs models..
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Replace drive belt, check any pullies and bearings.
Posted on Nov 19, 2014
  • 1,169 Answers
This assumes that the failed belt was the drive belt.
For the Scag Tiger Cub Series they are using two ildler pulleys in the drive system. Check these for bad bearings. If they are smooth turning but still a lot bearing play replace them as they can lock up at anytime and destroy a belt. The only other items in the drive system is the two hydro pump/transmissions and the engine.
As for the noise varying with engine the same can said about the deck components when they are in operation.
Recently developed a whinning when I first start to move
Where is the whining noise actually coming from .. engine/gearbox or elsewhere?
A whining/screeching noise could be a drive belt .. such as the belt that drives the alternator.
On a manual car it could be the clutch bearing making the noise until it warms up. Does the clutch make a noise when you depress the pedal? That's the thrust bearing .. the bearing that operates the clutch.
I don't think you have too much to worry about. If you had engine trouble there would be knocks, rumbles and strange noises at all speeds.
A whining noise is usually associated with something spinning/turning .. such as a pulley/idler on a drive belt or a bearing alternator.
Put your mind at rest - get a mobile mechanic's opinion.
Feb 16, 2016 | 2001 Buick Park Avenue
What making my belts whine its a 1986 pontiac parisienne
High pitched whining noise, usually means the belts need changing. they are slipping a bit, on the pulleys. Good-Day!
Jun 21, 2014 | Cars & Trucks
Clicking noise coming from hard drive
Clicking noise is giving you an indication that your hard drive is about to fail as clicking is one of the symptom of physical hard drive failure. This type of hard drive failure situation needs to be handle on time to rescue yourself from a data loss situation. Also i would suggest you to shut down your system stop doing anything on your system and immediately take expert data recovery assistance if you really want to save your data.
Feb 26, 2013 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
This water pump is making funny noise how can i solve this
A water pump on any auto making noise is a sign of bearing failure on the water pump drive stem. The only remedy is to have the water pump replaced or replace it yourself. The bearing gets water intrusion or dries out and the bearing fails. The water pump is not expensive but labor costs can be substantial depending upon the location of the water pump. Many water pumps are driven by the timing belt on smaller cars. Gaining access to the water pump often involves removing the timing belt cover and the timing belt. Failure to reinstall the timing belt in the exact same position as it was removed can cause catastrophic engine failure. Without your vehicle make and model this response is generic most vehicles.
Thanks for choosing FixYa,
Kelly
Aug 03, 2011 | Renault Le Car Cars & Trucks
Need to replace a pulley on a 2001 silhouette. don't know which onw though
The pulley youll need to replace is called a pulley tensioner,it comes with a automatic tensioner and a pulley all in one unit, when this tensioner wears the drive belt can no longer maintain a correct tension, when tensions are loose a belt noise develops as high RPM are achieved you develop a squeeling noise even at start up. Failure to replace a worn tension developts a glaze on the drive belt thus wearing it out quicker,by all practical means if you reuse the same belt the rotation must be followed,drive belt being rubber in nature developts conicity and fail if rotation is not maintain,so it always a good idea to replace the drive belt when you replace the pulley tensioner
Apr 26, 2011 | Oldsmobile Silhouette Cars & Trucks
2002 PT Cruiser. Vehicle shut down while driving. Received P0340 Trouble code..No camshaft position sensor signal at pcm. I replaced Position Camshaft Sensor, book suggests life on these 5-10 years, It...
This could be related to a loose camshaft drive belt. If you have slack in the belt the camshaft will rebound on over run causing the P0340. It can also be a Crackshaft sensor problem too.(P0335) Hope this helps...
Mar 06, 2011 | 2003 Chrysler PT Cruiser
Screeching noise coming from the drive belt is this common
When your drive belt becomes old and stretches so it is no longer tight enough the belt will make a loud squealing noise and will need to be replaced. While the drive belt is off during replacement, you or the mechanic replacing the belt will need to turn each pulley in the system that can be turned by hand to see if any of those are making a metallic noise also. If they make a metallic noise, they are worn out. It is common for a drive belt to wear out and cause this noise.
Jul 25, 2010 | 2001 Mazda 626
Lookng for serpentine belt routing diagram for 1998 2.4 L sunfire
1998 Pontiac Sunfire Belt Routing Diagram
A drive belt routing diagram is needed when replacing a drive belt to help simplify the installation process. The problem arises as there are many different ways a drive belt can be configured. In this configuration the belt length will vary not allowing the belt to be installed. Also alternative configurations could turn a particular accessory the wrong direction, creating more problems. Always reinstall the drive belt in the exact configuration as the previous belt to prevent these problems. Always use high quality replacement products to avoid premature drive belt failure. If a multi rib drive belt fails it must be replaced immediately to avoid such situations such as engine overheating and loss of the power steering system. Whenever a belt replacement is required inspect the pulley condition to ensure there are no sharp edges on any of the pulleys, this will cause the belt to shred and fail. Confirm that all pulleys are free from debris such as small pebbles, these pebbles will cause the belt to pit and significantly impair the belt performance. The belt tensioner plays an important role to the drive belt performance, if this tensioner is weak it can allow the belt to lose tension allowing the belt to jump and skip. This condition will result in noises such as squeaking, chirping and ticking.
Hope helps (remember rated this help).
Jul 11, 2010 | 1998 Pontiac Sunfire
Bad slapping noise.
could be something with the timing chain system. There were some complaints about the chain slapping the cover and even a good number regarding failure for these cars. If it's anything more than a slight tick I would, or have a professional, take a look at it. If one of the guides, or the tensioner, or even a link in the chain itself let go it can spell big trouble if you try to drive it.
Apr 09, 2010 | 1993 Saturn SL2
1991 park ave 190k miles, loud bearing noise from serpentine belt area at idle, goes away at speeds 10mph and up. has new water pump and alternator, belt is not jumping around, a/c is still cooling. noise...
The serpentine belt area is large. Remove belt and spin the IDLER PULLY of the belt TENSIONER. and listen for a bearing noise. A common failure. Hope this helps
Apr 30, 2009 | 1991 Buick Park Avenue
Garden Logo
151 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
