Question about Candy Ovens
I have a Candy TCP21x oven and the bottom fan oven has stopped working as well as the digital display, the top oven still works. Any ideas?
I know it is not the fuse as the top oven still works. The digital display has been flashing (as though there has been a power cut) for a couple of days. I used the main fan oven yesterday, however, it won't turn on today and the digital display is also not working.
    Problem Solver:
  • 47 Answers
Problem with the board.. is it under warranty? Have tech get replacement if it is. May have to pay labor.
Posted on Nov 26, 2014
  • 4 Answers
SOURCE: Main oven won't turn on
I'm figuring you've probably resolved this, since you posted in November (and I've just joined the site today). However, I thought I'd post a solution just in case anyone else surfs in and finds the same problem.
We have the same sort of oven. After the power has been off, the oven won't work until you set the time on the clock. I think it's because of all the automatic timer features.
On ours, you have to press the two buttons with arrows on at the same time as turning the clock dial to change the time.
Good luck.
Posted on Jan 07, 2009
  • 1214 Answers
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Posted on Jan 14, 2009
barkencoa
  • 3463 Answers
SOURCE: CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Posted on Feb 22, 2010
Testimonial: "GR8 JOB HAVE ALREADY SEARCHED ON THE NET BUT THIS CONFIRMS. NICE ONE CHEERS."
SOURCE: Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
Posted on Aug 07, 2010
SOURCE: frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Posted on Aug 12, 2010
Candy Built in double fan oven bottom oven not getting hot
Cheak the coils. Do a continuity test also look for signs of an electrical short(small scorched area) and clean the contact where the coil attaches to the appliance.
Apr 17, 2014 | Candy Ovens
Hotpoint oven suddenly stopped working
Sounds like a control board problem. When the display goes out that is usually a dead board.
Mar 10, 2014 | Hotpoint Ovens
Candy oven broken
Poor quality connectors or crimped wires I would think.
Sep 16, 2017 | Ovens
My candy fan oven has no heat when turned on
If the fan is working o/k, then it is going to be a faulty oven element, fitting a new one should solve the problem.
Mar 29, 2010 | Candy Ovens
My candy oven r43/3xuk wont switch on. The power
If the fan is working o/k then it is likely to be a faulty oven element if it is a
electrically heated oven.
If it were the timer, not even the fan would work.
Mar 28, 2010 | Ovens
CANDY OVEN
Feb 22, 2010 | Candy F248P Electric Single Oven
I have a dual oven. The bottom one which is a fan oven stopped heating. The light is on, the fan is on but not heat is generated. What can I do?
You need to replace the oven element at the rear of the oven, where the fan is located.
Hope this helps.
Dec 11, 2009 | Candy Ovens
Candy F254/3X single fan oven, grill works, oven doesn't.
If fan is working o/k, then you need to fit a new oven element
Please`rate my solution.
Thanks.
Aug 24, 2009 | Candy F248P Electric Single Oven
Ovens Logo
94 people viewed this question
Top Candy Ovens Experts
ashburton
ray gallant
Dado
Are you a Candy Oven Expert? Answer questions, earn points and help others
