My Gibson kg 6 only stays lit for 3 seconds then the flame goes out
  • 148 Answers
Clean your flame sensor probe with sand paper or relace it
Posted on Nov 25, 2014
  • 9 Answers
SOURCE: FLAME GOES OUT AFTER SHORT PERIOD OF RUNNING
TRY REPLACING THE FLAME SENSOR.
Posted on Dec 15, 2007
  • 333 Answers
SOURCE: dyna-glo rmc-fa100a won't stay lit after releasing pilot knob
You should hold the pilot knob in at least 1 to 2 minutes, if it still goes out you need to replace the thermocouple. I hope this helps you out.
Posted on Nov 29, 2008
SOURCE: pilot light will not stay lit
Clean the pliot light tube with a Q-Tip and alcohol. Clean 2 inches deep. This will increase the pilot light flame and it will heat up the thermocoupler so it will stay lit.
Posted on Dec 06, 2008
detox101
SOURCE: Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
Posted on Jan 14, 2009
SOURCE: my mr heater mh9b won't stay lit
my mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a bit. Any suggestions?
Posted on Dec 14, 2009
Furnace won't stay lit. Intertherm Model M2RC-080A-16BN. Ignightor glows, flame starts and after a few seconds the flame shuts off. Then it starts the cycle again. It goes thru this cycle a fe
It sounds like the flame sensor is bad. If thats not the case you may need to replace the control board. You should make sure the flame sensor is directly into the flame.
Nov 20, 2014 | Intertherm Heating & Cooling
My Gibson kgs6 furnace only stays lit for 3 seconds then goes out but comes back on I change the igniter I change the flaming sensor I change the gas valve I change the board
Try moving the gas valve back just a little in the closed direction. Aone valves reclose if open too far. This will let little to no fuel through.
Nov 19, 2014 | Heating & Cooling
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
I have a 11 year-old york diamond 80 furnace. The flame sensor lights up and ignite the flame for about 5-6 seconds. Soon the flame goes out once again. There's this clicking sound that is heard every
You need to clean the sensor with steel wool so its very clean check sensor connections . If it is still not working you could change sensor also check out the pressure switch .
Jun 20, 2017 | Heating & Cooling
Model 7732 serial # B-92114 80-11 new 3308741.002 board 6/201 new 46-0452 thermocouple...
THESE USE SUCH A SMALL AMOUNT OF GAS ITS CRAZY... I REMEMBER STARTING MINE, MY FINGERS WOULD HURT SO BAD AFTER WAITING FOR IT TO GET GOOD FRESH GAS UPTO THE PILOT LIGHT TO STAY LIT.. THE ONLY THING YOU CAN DO IS BLEED THE LINE OF AIR AT THE FRIDGE. OR SIT THERE FOR ABOUT 10 MINUTES HOLDING THE START BUTTON.. YOU WILL SEE THE FLAME TURN FOM A KINDA WHITE TO THAT BRIGHT BLUE COLOR . THAT IT ! THAN IT WILL STAY LIT .. IF NOT THAN YOU WANT TO MAKE SURE THE BULB IS IN THE FLAMES PATH. I HOPE THIS WORKS FOR YA.. CUZ PARTS CAN BE KINDA HARD TO FIND, AND THERE NOT FUN TO WORK ON .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 24, 2011 | Refrigerators
Maytag gas dryer ldg7314aae my flame will not stay lit. Heats up flame kicks on then goes for about 20 seconds then shuts off. The dryer runs for about 20 more seconds and then the same thing happens...
you have done a lot . try running the dryer off the vent . when the burner is short cycling it a air flow problem . if off the vent does not solve problem ck the fan for a bad center . very common problem . and clean vent . ck outside for air flow and condition of vent hood .. hop this helps ..
Dec 03, 2009 | Dryers
My mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a...
Nov 17, 2009 | Mr. Heater MH9B Ceramic Utility
Patio heater ignites and stays lit with pilot. Then goes out.
Press and hold for 60 seconds and then it should stay lit (this is a safty feature on most models!)
Dec 18, 2008 | Endless Summer gwt501a Open Flame Patio...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
