Question about Stihl Genuine Ms 210, 230, & 250 Chainsaw Service Tune Up Kit In Box
Stihl ms 210. Starts ok revs fast then cuts out. Have to re start on full choke then run fast again on 1/2 choke and again stops after 2-3 seconds.
New carb fitted but problem persists
    Sergeant:
  • 322 Answers
You have an air leak causing the unit to run to fast. The air leak is also over powering the flow of fuel causing it to die. Hopefully you have not tried running it repeatedly like this or you may have done severe internal damage due to running it to lean
Posted on Nov 21, 2014
Testimonial: "Many thanks Kelly Any thought as to locating air leak or should I just replace all fuel system tubes etc. Thanks again for you help.Derek."
  • Kb B
    Kb B Nov 23, 2014
    there are several possible places it can leak. it can be in the carburetor, the engine seals could leak, the sealant at the base of the cylinder could be leaking, etc. your best bet is to take it in to an authorized STIHL dealer
2 Suggested Answers
  • 6468 Answers
SOURCE: Stihl Leaf Blower BG86c no top speed
take off the muffler and run it the screen inside it might be plugged and you can clean it off by opening the muffler
Posted on Jun 13, 2012
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
My stihl whipper snipper loses power and cuts out when i try to rev and apply throttle.
With 2 strokes I always start with 'AIR' 'FUEL' 'SPARK' from the sounds of it the choke might be stuck on (choking the motor ha ha) also check the air filter, You have fuel and its moving through but the fuel filter might be slightly clogged. As its starting and going on low your spark unit is ok but you might need a new spark plug.
Dec 21, 2015 | Stihl Garden
I was using my o17 saw today it was runing Just fine I shut it off when I went to start it again it fired on choke seting after that I could not get it to do anything what is wrong with it
All 2-strokes love to run rich when cold thus full choke till it kicks, half choke to start and leave on for 5 seconds high rev's to warm & lubricate, then no choke to run. Restart when hot is 1 pull full choke (you are now flooded) & then no choke til it starts. Try it. Works every time on all of my 2-stroke engines.
Apr 22, 2015 | Garden
My br420c blower runs fine for about 20 seconds and then shuts off like the switch has been turned off
possibility 1) It sounds like it is sucking air with the gasoline. 2) don't rush the choke, leave it running on high with 1/2 choke. When you go to move the choke to off, move it very very slowly while the governor can catch up and raise the revs. Or slow the revs down before turning the choke off.
Oct 23, 2013 | Stihl Br420c Magnum
Saw runs good but when shut off it wont start again for sometime
Check your fuel filter in case it is clogged. When starting pull cord on full choke 5 times quickly. Wait 2 or 3 seconds...try again if it asks like it wants to start..then put on 1/2 choke...goes thru same process. Check spark plug.
Sep 28, 2013 | Stihl 25" Chainsaw Saw Bar 30030008830 Ms...
Troybilt Engine wont accelerate
The machine is running too lean on the fuel mixture, if the fuel filter in the fuel tank is clean ( replace if needed ) then you can unscrew the H screw on the carb to richen it up, you may need a special tool to turn the screw if it is an anti tamper type.
Jul 08, 2013 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
What is the starting procedure?
Start with the choke on full press the fuel siphon button till the lines are full of fuel. pull handle until it tries to start but stops. move the choke to half then start again. let it run for 60 seconds on full. don't move the choke to full or it will stop. Either slow the revs and then put the choke on full or keep the revs high and slowly move the choke to full (to allow the governor to slowly advance with the new revs)
Nov 03, 2012 | kawasaki Krb750b Backpack Leaf Blower
Mcculloch 210 strimmer lost power now wont start for more than afew seconds
remove the muffler and run it the mufflers plug up and restrick the exhaust some mufflers you can open and clean the screen
Sep 14, 2012 | Garden
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Stihl Genuine Ms 210, 230, & 250 Chainsaw Service Tune Up Kit In Box Logo
163 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
