Question about Scotch 9" Tl901 Hot Laminating Machine / Laminator
HOW DO I UNJAM MY SCOTCH LAMINATOR
IT IS WRAPPED AND WE CAN NOT GET THE MACHINE UNDONE TO UNWRAP. HAVE TAKEN THE SCREWS OUT OF THE BOTTOM BUT WILL NOT COME APART.
How do I get something out of that the laminator ate?
You can't do any more laminating until you do. Some laminators have to be used with a document carrier and some don't. It sounds like yours does need one. This happened to me once. You have to remove the screws on the bottom, lift off the top and you will find your document and laminate pouch wrapped around the roller. Using a sharp paring knife or nail scissors, cut the pouch along one side making sure not to damage the ceramic roller. I have a recollection that I cut the pouch away on both sides. I used a chef's boning knife as this was at work in an airport business class lounge.
Oct 12, 2016 | Apache Al18p 18 Professional Laminator
How do I unjam it?
first, remove both rollers with the film on them, then I usually cut the film between the red/orange rollers and the rear gray rollers, this allows you to run the laminator in either forward or reverse to unwrap the laminator, there is not exact science here, just use common sense and don't use anything sharp up against the rollers. West Laminating Svcs 405-324-6092
Aug 05, 2015 | Gbc HeatSeal Ultima 65 Laminating System
How do I feed New laminating film through straight? Top roll of new film is wrapping around bottom heat roller
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
Aug 30, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Scotch Thermal Laminator not heating up.
well it sounds like you may have cut a wire or pull one somewhere. i would go ahead and take it apart carefully and check everything. may have unplugged something hopfully! let me know whwat happens!
Jan 31, 2014 | 3M TL902VP Scotch 9" Thermal Laminator...
Please help!!! I put a pouch into my scotch TL901 laminater the wrong way and it is completely Jammed in the middle of the machine!!! I used a flashlight to see how bad it was ad it is completely shredded...
Unplug laminator. If it does not open up -check to see if the machine has a pouch jam lever. The lever will make it easier to remove the jammed pouch. Put the screw back after you clear the jam.
Jul 12, 2017 | Office Equipment & Supplies
Film is wrapping around bottom roller instead of going out. how do I get it unwrapped?
Get a scotch brite general purpose pad, be sure to let machine cool down before you start to cleaned roller. And you can thread your laminate film.
Sep 03, 2013 | Gbc HeatSeal Ultima 65 Laminating System
SCOTCH TL901 MANUAL
I have a scotch tl901. The laminating sleeve went into the machine and must have rolled around the roller inside. Is there a way to get it out? Is there a way to open the machine? I must have put the sleeve in open side first.
Oct 03, 2010 | Office Equipment & Supplies
I have a scotch brand laminator tl901- it is jammed...and making a clicking noise...is there a way to open the system and try to unjam it?
First, make sure that the unit is unplugged and has sufficient time to cool off. Then remove six screws on the bottom of the laminator. The screw driver shaft must be thin enough to fit into the holes where the screws are located. Two are very easy to find -- one on each side in deep holes. The other four are hidden under small black rubber disks that the laminator rests on. peel up the rubber disks and remove the rest of the screws. At this point it is easy to remove the cover and remove the jam. To replace the cover you must use a thin tool to pull back the release level so it will fit into its opening in the cover. Replace the six screws and you should be able to ready to laminate again.
Jul 10, 2010 | Office Equipment & Supplies
Scotch 9" Tl901 Hot Laminating Machine / Laminator Logo
Top Scotch Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Scotch Office Equipment and Supply Expert? Answer questions, earn points and help others
