Question about Olympus Cameras
Stylus 850SW - no image through the lens. Display shows old pics and all menu items.
Firmware upgrade
    Top Expert:
  • Olympus Master
  • 6,702 Answers
Please don't try to do a firmware upgrade, on a device that is not working 100 %. You need a good working device, to be sure the software is placed in the flash memory, as it was meant to be.
I don't think there will be any firmware around for this camera. So if anything is wrong with the camera, first try to find out what it is. Solve the problem, and only then (if available) upgrade.
Posted on Dec 04, 2014
advance
  • 107 Answers
SOURCE: Blury Display on FE140
It sounds like your lens's focus element is stuck. Given the events you describe it is possible that a grain of sand has worked its way into the focus motor's gearing and jammed it up. Normally the small motor moves the focus optic in and out to achieve proper focus, if its movement is limited or completely jammed you will experience blurry pictures. The camera will have to be disassembled and the sand cleaned out to restore normal function. There are repair providers you can find online who can work on your camera. David Millier Advance Camera Repair
Posted on Mar 23, 2007
dbarchitect
  • 150 Answers
SOURCE: Canon Powershot A70
There is a button on the back that can be pressed called Disp. (stands for Display). There are two or three settings it flips through each time you press the button. Press this button a few times to cycle through the choices in each of the playback and camera mode to see if this resolves your issue. Happy snapping...
Posted on Nov 23, 2007
t00nz
  • 4738 Answers
SOURCE: no image in lcd viewfinder
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on May 25, 2008
welcomejee
  • 10594 Answers
SOURCE: No image on Cybershot DSC-T1
It is known problem of bad ccd imager in Sony DSC-T1 Cyebershot camera and ccd imager will be replaced.
Sony will repair this camera free of cost for ccd imager problem as per announced scheme. You will be charged $20 for shipment.
Click Sony CCD Imager Support fro details.
Posted on Apr 12, 2009
AlbertHallX
  • 39 Answers
SOURCE: blurry lens after using it underwater
Sadly that symptom indicates that the camera is broken.
The device's seal protects both from the condition that you are seeing, but also protects the internal circuits from moisture.
If water has gotten inside the camera, I would pursue returning it and getting a replacement from the company.
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
Posted on Apr 29, 2009
Hi I hv a toshiba smart tv it's two years old , it comes on but does not hv pic it does hv sound
if you choose the menu does it display menu items or is there no image at all? No image at all when you press menu would mean the backlight is likely not working and requires repair. If you do get menu items on screen check the image settings and ramp up brightness and contrast
Jan 14, 2016 | Toshiba Televison & Video
Stuck on please wait
Check your current firmware version before beginning:
  1. Turn on the camera.
  2. Tap the menu tab at the bottom of the monitor to display the setting controls and tap Setup (wrench icon)
  3. Tap Firmware Version in the Setup menu(wrench icon)
  4. The cameras firmware verison will be displayed.
  5. Turn off the camera.
Basic Download and Installation instructions: (New firmware versions contain all previous versions.)
Windows
  1. Create a new folder with an appropriate name on your computer's hard disk.
  2. Download F-S4300-V12W.exe to the folder created in step 1.
  3. Run F-S4300-V12W.exe to create the folder titled S4300Update, containing the following:
    • firmware: folder containing the firmware.bin file
    • firmware.bin : the firmware located inside the firmware folder.
  4. Insert the memory card containing the firmware folder into the camera and turn on the camera.
  5. Tap Firmware version in the Setup menu and follow the instructions displayed to upgrade the camera's firmware.
  6. After the upgrade is complete, turn the camera off and remove the memory card.
  7. Check the Firmware version item in the setup menu to confirm that the camera's firmware has been upgraded.
For detailed instructions, please see the PDF files below.
Macintosh
  1. Download F-S4300-V12M.dmg.
  2. Double-click the F-S4300-V12M.dmg icon to mount the disk image titled, F-S4300-V12M.
  3. A folder titled S4300Update, containing the following files, will be created inside the disk image:
    • firmware: folder containing the the firmware
    • firmware .bin: the firmware
COOLPIX S4300 1 2 firmware update Nikon Knowledgebase
Mar 28, 2014 | Nikon COOLPIX S4300
Olympus Stylus 850 SW LCD screen will not turn on. The camera itself will turn on and take pictures but i must do it blindly. i cannot see the pictures nor can i see through the lens.
If you camera is built with a viewfinder there is usually an option to de-activate the lcd screen. Usually if you press the display or play button on the back it will re-activate. Also try to access any of the menu's by pressing the menu button. If this does not work also then the LCD is probably bad or not making connection. You would have to find a local service center for repairs. www.phototech.com is the local service center in NYC or you would have to send directly to Olympus in Woodbury Long Island.
Good Luck
Paul
Jul 05, 2011 | Olympus Stylus 850SW Digital Camera
When power on blured screen apear and blured image
1. Try cleaning the lens with a soft dry cloth. Do NOT blow on the lens first. 2. You could be experiencing camera shake - if you are in shutter mode and if your shutter speed is too slow for the light available you get a blurred image.
Dec 31, 2010 | Olympus Stylus 850SW Digital Camera
Cant take a pic says card is full
If this is a brand new memory card, the two things to do/check are:
- Make sure the camera supports 2GB of memory (manual should say that)
- Format the memory card - the manual should give detailed instructions of how to navigate through the menu and perform a format on the memory card
Dec 26, 2009 | Olympus Stylus 850SW Digital Camera
How do i delete all pictures from memory card at once
The best way to do this is to reformat the card, an option which must be in the settings menu somewhere. This has the added benefit of resetting everything on the card. As a matter of fact you should always do this once you have downloaded the most recent batch of pics.
Dec 01, 2009 | Olympus Stylus 850SW Digital Camera
Blurry lens after using it underwater
Apr 29, 2009 | Olympus Stylus 850SW Digital Camera
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open,...
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open, but no image is available just a black screen. When I I try to take pic is showed very low light but doen't show image of pic taken when I check. Please advise. This a brand new camera and was taken excellent pic as of this friday. Groove_us@yahoo.com Mr.Tracy Johnson
Apr 26, 2009 | Samsung i85 Digital Camera
Olympus stylus 800 lens problem
Fair reasoning but I suspect incorrect.
The screen remaining black- do you mean that it shows no menu item either? or are you getting those but no image? clarify.
If you are getting nothing- is there a hint of 'shadow' images but not illuminated?
It nothing at all then this is an indication of a connector/ main board failure.
Lens not appearing could be the drive motor has stalled.
But the two items together could also mean something much easier to resolve- The battery[s] is not delivering enough power.
Clean the battery contacts. Make sure it is of the correct value as in the manual - if you have replaced it recently .
If that fails it may be new camera time as the likely cost of a repair will be high.
Dec 17, 2007 | Olympus Stylus 800 / ? 800 Digital Camera
Cameras Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
