Question about Frigidaire Refrigerators
What happens if you get 120v of if you dont on this frigidaire afinity f/l water valve?
    New Friend:
  • 20 Answers
I'd like to help you with your question. First, I haven't got a clue what you are talking about. If you would, rewrite the question, read it over, do you understand it? Then send it again and I'll give it a shot
Posted on Nov 26, 2014
Testimonial: "I apologize it is a s/s frigidaire fridge i am not getting water to dispenser and or the ice maker. Man i am loosing itLOL"
Whats the difference between e10 and e11 error codes on frigidaire afinity f/l washers?
Thank you for your post, greg aguilar!
Both error codes "E10" and "E11" stand for fill time is too long on your Frigidaire washer. This could be an issue with the water pressure coming into your washer the psi must be above 30 psi. If it is not you may need to correct the pressure issue. If it is check to assure that the hose is not kinked or blocked. You may need to replace the water inlet valve, pressure sensor, or control panel. I would recommend having a professional technician come out to provide a proper diagnosis for repair. Hope this information is helpful to some degree. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
With an ohm meter how can you test the water inlet valve on a frigidaire afinity f/l washer?
If its a AC volt system, set meter to 120v AC. put a lead in each side of cold water valve wires. start wash on cold and should get 120v reading
How do you check the inlet valve on a frigidaire afinity f/l washer?
Hello greg aguilar, thank you for your inquiry!
From the information you have provided you would like to check the inlet valve on your Frigidaire washer. In order to check your valve correctly I would recommend speaking with a professional technician for a diagnosis to be completed. This will help avoid any unnecessary part purchases. Hope this helps. -Matt
It will not produce ice nor despence water
i cant remember when that both happen at the same time electronically. But it happeens often this way.
Check water (of course) to make sure that the water coming in is really coming in (cause the shut off can be plugged) I know you did that already (just asking).
Things you can do is replace the filter.
Unplug the frig for 2 days with the doors open. The water might have frozen in the doors (crazy but this is common) and the water will not come out. An easy way to check this huh? unplug. After the 2 days if water resumes let us know cause you have to get a special kit to prevent from happening again.
if you do all this, and you have water going to the frig then the last thing it could be is the water valve. thats the part that is connected to the main water supplying the frig. but to be positive (ask a friend or relative who is an electrician dont try this yourself) you need to manually put 120v to the valves to check them. thus the electricians. if still no water after 120v check then replace the water valve. but if water comes out let me know so i can trace the problem for you using the original wiring diagram ok thanks hope i was alittle helpful
Mar 29, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice maker not working but water keeps leaking and freezing on the freezer door
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards
Jan 04, 2010 | GE GSS23SGSSS Stainless Steel Side by Side...
GE refridge icemaker won't work
I hope you find this Very Helpful and best regards!
Jan 03, 2010 | GE Refrigerators
Will a water valve for a frigidare refrigerator work on a kenmore refrigerator? the one shown for my kenmore won't work, but the one for the frigidare looks like it will work.
Actually kenmore don't make their own appliances, if you have been given a Frigidaire valve as a replacement for your Kenmore the likely hood is your refrigerator was made by Frigidaire. So the answer to the question is maybe. The second answer to this question is that all valves will most likely work on all refrigerators since they all work off 120v it's just a matter of adapting the water lines. Mike
Nov 30, 2009 | Kenmore Refrigerators
My frigidaire dishwasher is not spraying out any water??
check the water lines going to the dishwasher. they are usuall under the sink running to the dishwasher, the line may was a cut off valve that might have accidently been activated.
Jun 23, 2009 | Frigidaire 24 in. FDB635RF Built-in...
No cold water
the most common failure for that would be the cold water side of the inlet valve. To be sure you would need to access the valve and test the leads to make sure you have 120V at the valve,if you do then replace the valve
Feb 19, 2009 | Frigidaire FWS833A Top Load Washer
No water
no water getting to machine to start its cycle.
Jun 03, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Refrigerators Logo
53 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
