Question about 2014 Ford Escape - All Escape models - Weathershield HP Car Cover
How do I dim dash lights
Everything
    New Friend:
  • 34 Answers
I'm not being a 'Smart A-s here, but have you looked in the owner's manual? I have a Ranger pick-up, and the combo, dome light switch, and dash lamp dimmer, are on a thumb roller knob, down by the headlamp switch. When all else fails, go ask the dealer.
Posted on Nov 20, 2014
2001 Civic dimmer not working
It's not high and low beam, it's the dash lights that are dim. I've hooked up many aftermarket radios but never knew it was a no no to hook up the dimmer/illumination orange wires in a '01 civic. I googled it and seen many others with similar issues like mine but nothing exactly like the issue I have.
All the dash lights work, they are dim though. The radio lights work but they are even more dim than the rest of the dash lights. I have check every single fuse under the dash and in the engine bay. The dim controller does not work at all now. I'm guessing that's the issue and from what I read, the dimmers circuit board is in the instrument cluster. Some can fix it, others can't.
I will probably end up buying a used instrument cluster off of ebay, they are not expensive. Hopefully that fixes it since everything else works.
Oh, yes, the brake lights work.
Ted, I think you answered the wrong question...I mentioned nothing about the battery or the low/hi beams
Aug 13, 2012 | 2001 Honda Civic
Installed new radio and now radio and interior light wont work, thought it might be a fuse but they are ok?
DUDE!!! Installing a new ground Worked for these symptoms ive been having for MONTHS! Dim headlights, pressing brake would shut off radio, turn signal slow and non blinking, also would shut down radio, dash lights dim and gauges FREAKING OUT!!! Process CHEAP AND EASY!
Jul 20, 2012 | 1998 Dodge Dakota
I had a routine tire rotation and car alignment on yesterday. As I drove my car later in the evening, the vsc/ecm dash light came on, followed by the brake and battery light, radio and dash lamp lights...
Sounds like you lost the charge from the alternator.
When the alternator quits charging your battery light comes on and your car will run on battery power only...and only for a short time.
As the battery gets its stored energy used up...everything that is electrical will get slow or dim.
I'd check your alternator for proper operation and its drive belt...
Hope this helps...
Aug 14, 2011 | 2003 Lexus LS 430
Digital display went dark. Everything else seems to work fine. Cannot find any problem with fuses.
Unfortunately there may not be a cheap fix for this. You can try to replace the switch that dims your dash lights, but you will probably have to replace your digital dash.
Feb 23, 2011 | Chevrolet Blazer Cars & Trucks
My Pioneer AVH-P5700DVD's screen is very dimmed i can bearly see the buttons, it seems like there is no brightness in the screen please help... I checked everything already... Maybe is a dim adjustment?
it could be a dim adjustment. did you hook up the dimmer wire to the factory harness if so and your dash lights are low then thats the issue. if not then check the brightness on the unit. if that is not lowered then the internal lights inside the unit have started to burnout. if thats the case uninstall it and send it in for repairs
Nov 17, 2010 | Pioneer AVH-P5700DVD Car DVD Player
1997 Ford F250 light duty, 5.4L triton. Dash lights are off when exterior lights are on. Headlights, taillights, brake lights, and backup lights all work. Blinkers are stuck on, both sides, all the...
Your dash lites are on with headlamps off? I'd check the wiring for headlamp switch/dimmer. Not only check the fuses, check the fuse circuit for voltage, use a test lite. You could use a jumper to bypass dimmer, see if dash lites work.
Mar 05, 2017 | Ford F-250 Cars & Trucks
My 1992 s-10 blazer head lights work but the digital dash will dim with either the parking or headlights on when they are off the dash works fine, have replaced the dash itself and checked the switch and...
You Digital dash is working as it should, it is supposed to dim with the lights on so your eyes don't have to adjust, from looking ahead to checking speed and back
Jul 08, 2009 | 1992 Chevrolet S-10 Blazer
Dim dash lights
Did you have the alternator check? Low voltage will cause light dimming.
May 27, 2009 | 1992 Volkswagen Cabriolet
2014 Ford Escape - All Escape models - Weathershield HP Car Cover Logo
67 people viewed this question
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
Tom
baire
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
