Question about 2014 Ford Escape - All Escape models - Weathershield HP Car Cover
How do I dim lights on dash
Everything I can think of
    New Friend:
  • 4 Answers
Should be in owners manual or call dealership.
Posted on Nov 29, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Hi got a grand scenic my key card u put in it registers everything on dash thenu press start button dont start
After reading that I would try boosting or charging battery, with the push button start if battery low it will just make a little noise and do nothing the dash lights stay on and don't dim like u would think if battery low
Jan 11, 2013 | Cars & Trucks
2001 Civic dimmer not working
It's not high and low beam, it's the dash lights that are dim. I've hooked up many aftermarket radios but never knew it was a no no to hook up the dimmer/illumination orange wires in a '01 civic. I googled it and seen many others with similar issues like mine but nothing exactly like the issue I have.
All the dash lights work, they are dim though. The radio lights work but they are even more dim than the rest of the dash lights. I have check every single fuse under the dash and in the engine bay. The dim controller does not work at all now. I'm guessing that's the issue and from what I read, the dimmers circuit board is in the instrument cluster. Some can fix it, others can't.
I will probably end up buying a used instrument cluster off of ebay, they are not expensive. Hopefully that fixes it since everything else works.
Oh, yes, the brake lights work.
Ted, I think you answered the wrong question...I mentioned nothing about the battery or the low/hi beams
Aug 13, 2012 | 2001 Honda Civic
Dim dash lights
Check your owners manual. There must be a way to dim the dash lights. Should be a dial or a knob somewhere.
Apr 21, 2010 | 2008 Nissan Sentra
Interior dash lights are dim
make sure that there is nothing covering the Ambient Light Sensor on your dash - if the computer thinks it is night time, it will dim your dashlights during daylight hours.
Nov 08, 2009 | 2004 Jeep Grand Cherokee
2005 Chevy Trailblazer. We recently had the gas
you need a new altinator if ur head lights dim and u are loosing power!!
Sep 28, 2009 | Chevrolet TrailBlazer Cars & Trucks
Dash lights come on when dome light goes out
The only possible location I can think these circuits cross is at the headlight switch.The dimmer rheostat or the wheel you turn to dim and brighten your dash lights also should turn on your dome light so I think maybe a new headlight switch assembly or rheostat should fix tour problem
Aug 15, 2009 | Chevrolet Lumina Cars & Trucks
CAR WONT START BUT LIGHTS STILL WORK
with headlights on, try cranling the engine. I they dim the batt is no good, If they go out, you have a battery connection problem/loose or poor contact on groung(neg) cable. If nothing happens your starter relay is kaput.. Good luck
Jun 14, 2009 | 1995 Lincoln Town Car
Location of headlights brights and dims
the inner lights are the brights but some vehicles also use the bright lamps with low voltage as the daytime running lights
Dec 04, 2008 | 1996 Chevrolet Beretta
The lights on the dash board are so dim I cannot see speedometer
check the dimmer switch on the dash board, switch may be bad
Nov 21, 2008 | 2003 Ford Taurus
2014 Ford Escape - All Escape models - Weathershield HP Car Cover Logo
60 people viewed this question
Top Covercraft Vehicle Parts & Accessories Experts
Tenderfoot
Tom
baire
Are you a Covercraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
