Question about Philips Norelco 7340 Mens Electric Rechargeable Shaving System Trimmer
I have a norelco 7340xl that makes an aweful noise when i turn it on to shave. what could be the cause of the noise? it was fine one minute then making noise the next.
I replace the heads last christmas. I clean it at least month with a tooth brush.
    New Friend:
    Problem Solver:
  • 7 Answers
Blade lock is the main reason of hair trimmer noise. In order to prevent the blades from making noise, you should put special oil regularly into the blades of your hair trimmer. This will keep it sharp, smooth, and easy to use. Read More >> http://www.hairclippershq.com/how-to-store-and-maintain-your-hair-clippers-the-best-way
Posted on Jul 24, 2015
    New Friend:
    Problem Solver:
  • 8 Answers
Clean hair out of it the oil it.
Posted on Nov 24, 2014
HQ8 or HQ6? What is the correct head replacement?
These Philips Norelco Replacement Shaving Heads HQ8/52 are compatible with the following series: 7100 series, 7200 series, 7300 series, 7700 series, 7800 series, 8800 series, PT/AT700 series and PT/AT800 series. They are sturdy and durable and provide for a smooth finish. The Norelco razor heads keep your shaves close and comfortable and are easy to replace.
Norelco HQ6The Norelco HQ6 is men's replacement heads. The Norelco HQ6 is made up of stainless steel and contains 3 cutters. The Norelco HQ6 works with all Quadra Action razors. HQ6 Features:Replacement Heads Stainless Steel 3 Cutters / Combs
Norelco HQ6
Oct 14, 2015 | Head Health & Beauty
Norelco 8140xl new blades doesnt shave
Did you use part HQ9 for your replacements? Norelco makes many different replacement heads and only one type is correct. The correct type for model 8140XL can be found at shaveroutlet.com below
http://shaveroutlet.com/norelco-philips-hq9-replacement-heads-p-252.html
Feb 02, 2014 | Norelco 8140XL Electric Shaver
Using a Model1180X Senso Touch. I would like to use it wet shaving with shaving cream, which shaving cream will get the best results and not damage the unit? (Norelco 1180X) ?
Sensotouch shavers can be used with any shaving gel or cream. It will not harm the shaver. Philips makes no recommendation as to which type is best. Just use whatever favorite brand that you have
Oct 08, 2010 | Norelco Health & Beauty
I have a philips norelco 7340xl with dead batteries. I disassembled the unit and used a heat gun to remove the old battery. I replaced the battery with an energizer nimh rechargable just like the dead...
If your solder joints are good and no solder has slopped over to short it out, the only thing left to check is the polarity of the battery. Positive end goes toward the motor
Sep 21, 2010 | Health & Beauty
Red light came on in the form of the heads. Is it time to replace
This means that it is time to change the shaving heads. You will find Arcitec replacements at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Jun 11, 2010 | Norelco Arcitec Electric Shaver -...
After using the shave a digital red symbol of the head shows up at the bottom of the shaver. What does this mean? Thanks.
Digital red symbol of the head shows up. It's menas that you should change new replacement heads, that Norelco Arcitec electric shaver replacement heads is Norelco RQ10 shaving heads.
May 21, 2010 | Norelco Arcitec Electric Shaver -...
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
Can i use shaving cream with a norelco electric shaver?
According to the Phillips website, it is NOT a waterproof shaver, therefore it is not advisable to use any liquids prior to or during shaving.
However, as a hairdresser and having experience with shaving men for many years, you can use the tried tested and true method of either shaving AFTER you get out of the shower so that your hairs on your face are softer from being in the moisture, or if you are not planning on having a shower, you can just use a hot face cloth on your face for a few minutes before you shave. This will soften the bristly hairs on your face and make it easier to shave.
I hope this helps. Please remember to rate my help. I would greatly appreciate it!
Apr 26, 2009 | Philips Norelco Micro 5625 XL Electric...
Jet clean system will not clean.
I had the exact same problem. Then I put more solution in so that it was just above the MAX line and it worked fine. So make sure you have enough cleaning solution in the system and it should work great.
May 20, 2007 | Norelco 8160XLCC Electric Shaver
Philips Norelco 7340 Mens Electric Rechargeable Shaving System Trimmer Logo
125 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
