Question about Royal 120 Cx 120-cx 120cx Ink Roller 10-pack
How can get free instruction manual for set up
I can not used, because I lose the menu
How do you oil the singer xl.1000
please read the instruction menu for oiling area. a small plastic bottle singer oil can be purchased at joanne fabric shop or any department store carries fabric. if you can't find the menu booklet, a drop of oil should be enough on all moving mechanism. don't over do it. best way is move the pulley where the belt is attached. see the movement for all moving mechanism. then one drop oil should be enough. be sure clean out the dust in general are by using vaccum cleaner before lubricating the macjine. do not oil the belt, otherwise will lose friction and slip when sewning. hope this will help. bob
Mar 02, 2015 | Singer Quantum XL-1000 Computerized Sewing...
How do I program a Legrand 04761 timer?
Generally, the instructions are shown below: you will have to fiddle around to tweak the instructions since this model Legrand is discontinued, and replaced with the 412641
There are 4 programming buttons located on face of timer: menu, on, +, -
Press menu, use +- to scroll down to GCFEIL, Press on, select language
Press menu, use +- to scroll down to set, press on, set current time and date using same basic commands.
Press menu, use +- to scroll down to program, press on, select new, press on, select day-days of operation for program 1, select individual, set On and OFF times for program 1, save
Press menu, use +- to scroll to function, select auto to run programs.
http://waterheatertimer.org/pdf/legrand-412641-D22-manual.pdf
http://waterheatertimer.org/Din-rail-timers-and-manuals.html
Gene
Water Heater Timers Save Money
Mar 02, 2015 | Legrand Hardware & Accessories
Nikon Coolpix L 810
It would help to know if the lens extends when you turn on the camera. Assuming it does and that you have made a setting error rather than a functional issue; reset your menu settings. If you do not have a copy of the L810 instruction manual, you can download it for free at http://cdn-10.nikon-cdn.com/pdf/manuals/coolpix/L810RM_CH(11)03.pdf. Go to page 65 and follow the reset instructions. If you still have the problem, contact Nikon Service at 1-800-645-6687 between 9AM and 8PM EST, Monday through Friday for a repair estimate and instructions.
May 25, 2014 | Nikon COOLPIX L810
Panasonic =iv NV-MV40 , how to set the clock please
You can download the user manual for free from the Panasonic website.
Apr 03, 2011 | Televison & Video
How to reset the parental control code - I forgot the code and want to reset with a new one
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
How to access underwater setting on finepix f30
1. Turn the function selector dial to "N/SP"
2. Press the "Menu/OK" button.
3. Use the up and down buttons round the "Menu/OK" button navigate until you see a fish symbol.
4. Press "Menu/OK" to confirm your selection.
You may also find the following web address for a free user manual to be of assistance:-
http://safemanuals.com/user-guide-instructions-owner-manual/FUJIFILM/FINEPIX%20F30-_E
I hope that you've found my answer to be useful and ask in return only that you take a moment to rate my answer. Have fun with the underwater photography, it's highly addictive!
Oct 12, 2009 | Fuji FinePix F30 Digital Camera
Help setting Viking Designer I machine for free motion quilting
I assume you are doing free motion quilting? Use the V Menu, choose the first stitch. If you are using the Q Sensor foot or the spring free motion foot, go into the Set menu, hit "More" twice then turn On for either the Q Foot or Free motion. Make sure you have Needle Down turned on (top right-hand button on the left side above the needle). You might need to loosen the top tension by one or two clicks - first screen of the Set menu, under the picture that looks like DNA. A Size 90 needle is probably best and if the quilt is difficult to move about you might like to either use the Sewing Advisor to set for Heavy fabric or lessen the upper presser foot pressure - Set menu once again, next picture after the DNA. I have never had to do this with my D1 but I know some other people have. Get back if things are not working well for you.
Pam
Apr 29, 2009 | Bernina Activa 140
Cant get s-video working on tv
hello ..go into the sets menu and select ..set up menu..you'll need to find the 'A.V' SETTINGS select the 'S' setting . when i did this a few years ago i also had to select add a tv in the pc settings [control panel] hope this helps .farr64
Apr 27, 2009 | Televison & Video
Siemens cordless phone gig set 4000
Hi James, Here is a link to the instructions below to download the Siemens Gigaset Manual for free or for Siemens repair services. However, on the 4000 model you can easily set the time by pushing menu, scroll down to base settings push OK, push OK again for clock, then scroll down to TIME, and push OK and make your changes. Also, you can change the date, as you saw in the menu. If your using a 4200 handset, the menu is slightly different, but similar. And if you get caller id, the phone will automatically read the system date and time from the phone company so you never have to set your time again. Here is the link for the manual, you may need to go to a different manual depending on your base station model. Good Luck, CG http://www.barclayent.com/manuals/Gigaset%204000%20Quick%20Start.pdf
Feb 17, 2008 | Lands Phones
Not being able to access my aux input
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Sep 22, 2007 | Kenwood KDC-135 CD Player
Royal 120 Cx 120-cx 120cx Ink Roller 10-pack Logo
95 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
