Question about HP LaserJet CP5225 Laser Printer - Colour - 600 x 600 dpi Print - Phot
What is causing the black toner to not print the bottom 55mm (2inches), changed toner cartridge still the same? All colours are OK.
  • Noel Gordon
    Noel Gordon Feb 24, 2015
    I eventually called HP out, They provided a very good serviceI'd recommend them as in this case it was very much value for money, the main cause seemed to be the shutter on the black cartridge was not openning completely and so the laser was not writing over the full width. They changed a small piece of plastic on the end of the shutter arm and the complete main drive board which hosts all the cogs and wheels.
    Sergeant:
  • HP Expert
  • 223 Answers
Paper tray setting out
Posted on Nov 21, 2014
  • Noel Gordon
    Noel Gordon Nov 24, 2014
    Its only the black, colours are ok.
  • 8 Answers
SOURCE: Hp Deskjet 3650 will not print colour
Are you sure the color cartridge is in properly and you removed all of the tape?
Posted on Feb 18, 2007
  • 238 Answers
SOURCE: Colour won't print - HP Deskjet 5150 Inkjet Printe
hi, remove the color cartg take a tissue paper and run it horizontaly on the nozzel, if u can notice the three colors, ur cartridge is ok, may be the contact area of the cartridge,try to clean both the surfaces, and install the exact driver for the printer which will give you the cartridge maintenence options. let me know??
Posted on Dec 16, 2007
khanmohammad
  • 188 Answers
SOURCE: hp psc 1510 - only want black ink
Hi Manavoc,
I will explain you the cause for it.
It prints in yellow first and then override with black for better quality. This is the reason your color ink gets empty.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00308490&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Have a great day!
Posted on Mar 25, 2008
SOURCE: HP 3310 - problem with black ink supply
I heard you can get the 3310 to do a pump up the tubes cycle but i don't know how to make it do it. Pressing the ok and cancel buttons when you power up didn't work for my machine. Which has too died a inkless black death!
Posted on Oct 01, 2008
SOURCE: Why does my new HP Laserjet 1020 12A cartridge print too light?
It's rare that an original HP would do that? It's more likely that it's a compatible / remanufactured cartridge. is it? Compatibles can be as good as or better than OEM (mine are for example), but there are a lot of "hacks" out there.
Either way, I would return it for a new one, because that is your problem.
*please rate me :)
Posted on Mar 26, 2009
My printer suddenly prints all black pages.
are you using 3rd party cartridge if so replace them all with OEM cartridge.
Sep 28, 2015 | Office Equipment & Supplies
Printer ink doesn't appear to be dry on colour printing.
Dripping is impossible with laser as the toner is dry. A bad cartridge may cause the color shift. Print the demo page to confirm whether the problem is the printer or your program. Remanufactured cartridges provide very poor results with this model of HP.
Jun 24, 2015 | HP LaserJet Pro 300 color MFP M375nw
I have a HP LJ 4700 printer set up to a network. It will print black but not colour
1. Go to menu set as default.
2. Do color calibration.
3. Print PQ test pages, observe the colors, chk
4. Print demo page. chk
5. Print from different file/system..
Nov 28, 2012 | HP LaserJet 4700 Printer
Printer is printing the black color as light grey. Toner is already exchanged.
When you print something from a website and the print box comes up, click on preferences tab, and when it comes up click on color . Then click on print in grayscale and change the setting from High Quality to Black ink only, click apply at the bottom, then OK. It should print in black ink.
Jan 11, 2011 | Laser Phaser 6125 Colour XEROX Phaser...
Samsung CLX-2160, keep getting faded toner stripe down page. changed toner numerousof times The same problem occurred for me after only 300 pages. The black color on the all prints is faded out on the...
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
May 18, 2009 | Samsung CLX-2160N All-In-One Printer
Is there a override function to keep printing when toner alerts are on?Wondering since black still shows 30%.
These printers will still print when any or all of the toners are LOW, but if any one of them is EMPTY (according to the chip on the toner cartridge) printing stops.
Standard capacity toners ere 2000 page for the colours, and 3000 page for the black, so they can soon be used up.
Much cheaper per page printed, if you use the high capacity cartridges (6000 page for the colours, and 8000 page black).
There are high quality remanufactured cartridges available now, as good as OEM, and typically you'll get a Hi Capacity Remanufactured cartridge for the same sort of price as a Std Capacity OEM cartridge.
As a short term solution at a lower cost than replacement cartridges, you could just replace the cartridge CHIP. The printer would then think the toner was full (there'll likely to still be some toner in it), so you'll be able to print. Don't run the printer like this for ever though, as the toner has some lubricant properties, and with a TRULY EMPTY cartridge, you'll eventually do some damage to the cartridge, and then possibly the transfer belt (and you don't want to be changing that until it's rated 100,000 page life is up.
May 01, 2009 | Xerox Phaser™ 6180DN Laser Printer
Prints in black are poor quality
fist of all reunisall your printer driver ....
if problem dose not fix .
it means black colour laser section have problem so you can clean lens of laser if posible and replace laser secaner.
thanks
Apr 29, 2009 | Epson AcuLaser C4100 Printer
Samsung CLP-500 cutting off print
The duplexer is bad or needs to be realigned, shake up the cyn color. it mostly likely low.
Dec 06, 2007 | Samsung CLP-500 Laser Printer
HP LaserJet CP5225 Laser Printer - Colour - 600 x 600 dpi Print - Phot Logo
95 people viewed this question
Seeker5211
Seeker5211
