Question about Vehicle Parts & Accessories
I lost my viper remote starter and don't remember the model .. What could I do to get a replacement control
  • 33 Answers
You'll need to locate the unit under your dash, the too of the module will have the model number embossed on it (example: 562T), otherwise most local stereo shops should be able to help you out. If you go to a local independent Viper dealer, they should also be able to get the remote you need and program it for you.
Posted on Nov 26, 2014
5 Suggested Answers
  • 12 Answers
SOURCE: No install instructions
email me at face2face11@bellsouth.net and i will give them to you. i 've been doing install professionally for 10 yrs and have access to directechs (DEI technician website)
Posted on Jan 22, 2009
MECP Guy
  • 344 Answers
SOURCE: I have a Viper LE 5301 remote starter. Currently,
rest the modual to factory default
Posted on Feb 15, 2010
logosc75
  • 625 Answers
SOURCE: my remote starter for my viper 5900 2 way trans
Try reprogramming the remote. Open the door, turn ignition on, press and release valet switch one time, then press and hold valet switch while pressing lock button on remote.You should hear a confirmation chirp from the alarm. Release both buttons.Turn off ignition. test.
Posted on Oct 03, 2010
  • 4 Answers
SOURCE: i lost my viper remote
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Posted on Jan 05, 2011
Remotes won't program! Installed Viper 5001 on my 2007 Kia Sorento. Triple checked wiring..all is good. Remotes won't program...no power to main unit. Yet, tested main unit and it has power. Any...
There are two constant 12 volt wires at the ignition on this vehicle: blue and green. The red power (with fuses) wires from the Viper should be connected to either of the two. The ignition wire is yellow. The pink wire from the Viper should be connected there. The accessories are orange and white. The pink with white from the Viper should connected to one and the orange from the Viper should be connected to the other. Please note that the Pink with white should be programmed to act as an accessory (off during crank). The starter wire is red and the purple from the Viper should be connected there. Also check for a good ground connection.
For programming:
Press and hold "f" until LED lights solid (approximately 10 seconds), then press and hold remote starter button(circle w/arrow) until LED blinks three times and the amber transmit LED lights up.
Now you have to enter the remote control learn routine: Turn ignition on, within ten seconds press and release control button on antenna then, press and hold control button while pressing the lock button on remote. System will respond (horn/chirp/flashing parking lights) when holding control button and when pressing lock button on remote.
Jan 17, 2011 | 5101 LE 1 Way Car Remote Starter System
Remote car starter worked last week but this week it won't start. Changed battery in the remote and still won't start. It will unlock and lock the doors but just won't start.
It probably needs to be re-programed
I have a viper model 5101 and this is how you program it Hope it helps !
Jan 05, 2011 | Remote Start System
I need instructions on how to use my viper 5101 remorte starter
go to www.directed.com this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Dec 30, 2010 | 5101 LE 1 Way Car Remote Starter System
I lost my viper remote starter, i already bought a replacement remote, but how do i progam it? I have the basic five button remote, black buttons and silver borders around the whole remote.
Dec 12, 2010 | 5101 LE 1 Way Car Remote Starter System
Lost my Viper key fob alarm is on and cannot start truck. any solution to disable?
Your alarm should have a button that was installed called a valet. What you want to do is put your key in the ignition turn it to the on position (Don't start it) then with the car in the on position hold down the valet button until the led light on the alarm goes solid and you should here the alarm beep twice. now your alarm will be disabled. To reable the alarm do the same thing.
Feb 12, 2010 | Viper Security and Remote Start System...
Viper 5701 remote issue
sounds like the remots have lost two way communication. try to disconnect the windsheild antenna.try remotes again after pluging antenna back in.
Feb 07, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have a viper starter and car alarm with 2 controlls and one got stolen what should I do
The Viper alarms will accept (if I remember correctly), 4 codes at one time. That is, 4 individual remotes, or two remotes two times, or one remote 4 times. So, if you program your remote 4 times, it will essentially remove any previously programmed remotes. Another option, and you'll have to check with your dealer, but I think there is a way to delete ALL remotes, and then program your remaining remote one time, and again, all previously programmed remotes are now removed from memory. This was done by the manufacturer just for such events.
May 17, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper remote starter-
we have a viper 600hf and it has recently started draining thebattery and it won't stay charged.
Feb 05, 2008 | Viper RCVGC022 Remote Control
Viper remote starter sets off alarm.
Whoever hooked up your system did not hook up the factory alarm disarm and arm wires. Your car thinks it is being stolen as a result of this. You need to get a wire diagram of your car and hook up the proper wires.
Dec 12, 2007 | Viper (VGC421) Remote Control
Vehicle Parts & Accessories Logo
51 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
