Question about Hardware & Accessories
How do I set my noma timer model 052-8873-0/49887.
I want to set it for 5 in the morning and go off at 6
  • 5,089 Answers
Timer not identified.
According to google search052-8873-0 is fixya invention or older timer pre-internet
Following links will have same or similar timer
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/How-to-set-timers.html
Gene
Water Heater Timers Save Money
Posted on Nov 19, 2014
What are the benefits of drinking water in the Morning??
drinking water in the morning has a number of benefits for your overall health of body and mind.
  • It helps you to re hydrate your dehydrated body.
  • It helps your body to flush out toxins.
  • It fires up your metabolism.
  • It fuels your brain.
  • Keeps you regular and relieves constipation.
  • Prevents and cures many disease.
  • It is completely refreshing.
Feb 08, 2016 | Water Dispensing & Filtration
Bmw e70 x5 5 out of 6 glow plug fault codes logged
Check the glow plug control unit and connections.
Mar 16, 2014 | BMW X5 Series Cars & Trucks
Intex krystal pump systems how do i set the timers to set the interinterv
Nancy... This is how I have mine set up... I have a cheap Home Depot Timer that I use for the Filter/Pump the comes on at 6:00am in the morning and goes off at 12:00 pm... This Timer is very simple to use... For the Salt water System, For the first time I turned it on was at 6:30 AM (before work) and set it for 5 hours... Once is has completed the 5 hours, it will go into Sleep Mode and automatically start 24 hours later, so in my case, it will start the next day at 6:30 am... So i have have my Filter/pump come on 1/2 hour before the salt system comes on and it goes off 1/2 hour after the salt system goes off...
Hope that helps.
Dan
May 19, 2013 | Intex Automatic Salt Water System for ...
We have a honeywell cm921 and we cant set the therm astat to come on in the mornijng and then go off then come on again in the afternoon on timer please can you help
Your CM921 has 6 built in temperature settings based on time of day:
1 - 6:30 AM
2 - 8:00 AM
3 - 12:00 PM
4 - 2:00 PM
5 - 4:00 PM
6 - 10:30 PM
meaning that at 6:30 AM the themostat will change its temperature setting to setting 1, at 8:00 AM it will change the temperature setting to setting 2, and so on. To schedule temperature settings which best fit you, determine which time periods you would like more or less heat.
For instance, to fit what you requested in your question you could program a temperature you would like to maintain in the morning and afternoon times when you would like it to be on, and in the time periods in between set a lower temperature as follows:
1 - 20C
2 - 16C
3 - 16C
4 - 20C
5 - 20C
6 - 16C
With this example your thermostat would turn on at 6:30 AM as long as the temperature was below 20C and maintain that temperature until 8:00 AM. At 8 it would change its setting to 16C allowing temperature to drop from 8 AM to 2 PM to a lower setting to conserve energy until afternoon time when the setting would change back to 20C from 2 PM to 10:30 and then change back to 16C to save energy throughout the night. The actual temperatures would be at your discretion based on your individual comfort level.
Pages 5 and 6 of the following link will guide you in setting each of the 6 temperature settings.
http://www.wolseleysbc.co.uk/_STEPData/Assets/Honeywell%20CM921%20Room%20Thermostat.pdf
I hope this helps. Let me know if you have any additional questions.
Dec 10, 2010 | Honeywell Programmable Thermostat Heater
About pin setting
1. pin 6 and 8
2.pin 5 and 7
3.pin 9 and 13
4.pn 1 and 3
5 pin 2 and 4
Mar 23, 2010 | Iwill XA100 (MAXA100) Motherboard
Good morning, I would like to know in which side is number 5 cylinder. It's a 2004 t-bird. On drive side or passenger.
Firing order 3.9 L V8 (1-3-7-2-6-5-4-8) Cylinders are numbered as such. Passenger side front to rear 1-2-3-4 Driver's side front to rear 5-6-7-8
Oct 17, 2009 | 2004 Ford Thunderbird
Car running rough when raining
check the spark plug wires, put water in a spray bottle and spray along the wires,especially by the coil,if the car starts to run bad or you see sparks, the wires are no good, hope this helps, Ray
Apr 03, 2009 | 1999 Mercury Villager
Heater comes on at 5:10 am prior to the programmed setting
Access the installer setup menu (You will need the installation manual from the t'stat to do this) and turn off the "intelligent recovery" feature. This feature turns the equipment on in order to bring the conditioned area up to temp at the set time. Or you could set the "wake time" to 6:50!!!
Dec 15, 2008 | Honeywell Programmable Thermostat Heater
Black Screen with sound
make sure the TV time is correct. Reset the time. if that does not work, but the TV operates ok, it's in the circuit board, or could be a fuse problem.
Nov 10, 2007 | Apex Digital AT2702 27" TV
Hardware & Accessories Logo
766 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
