Question about Frigidaire Washing Machines
How do you check the inlet valve on a frigidaire afinity f/l washer?
  • Official Brand Answer
  • 2,267 Answers
Hello greg aguilar, thank you for your inquiry!
From the information you have provided you would like to check the inlet valve on your Frigidaire washer. In order to check your valve correctly I would recommend speaking with a professional technician for a diagnosis to be completed. This will help avoid any unnecessary part purchases. Hope this helps. -Matt
Posted on Nov 21, 2014
Testimonial: "If i was going to get a tech i would not have been on ur site.I can give this advise all day long day and nite 24/7 LOL"
aborcass
  • 2651 Answers
SOURCE: water leak
you would acess ut from under the main top. alittle involved but acessable,.. you need to remvoe teh four phillipsscres from with in the soap dispensor area. then remove the front door as well as th e2 screws oppisite t eh door hinge, then pop off the front cover. from there youll find 2 more 5/16 screws holding the top to the frame assy. then the main top can be flipped backward allowing you acess to the valve
Posted on Nov 03, 2008
blueextc3221
  • 15935 Answers
SOURCE: changing inlet valve
If you suspect you have a defective Water Inlet valve (also known as a FILL valve or MIXING valve) it can easily be diagnosed by performing the following steps:
- First, make sure the water taps are turned on all the way, and the fill hoses are not kinked in anyway. If everything checks okay, proceed to the next step.
- Now, turn the water taps off, disconnect the fill hoses from the back of the washer and place them in the wash tub. Turn the taps back on and make sure you have proper and forceful water flow (minimum water pressure should be 10-25PSI).
- Check the sediment screens on the Water Inlet valve on the back of the washer. Sometimes these screens will clog with rust or sediment and prevent water flow. Cleaning with some distilled vinegar works well.
If you've attempted all the steps above, but still have no luck, more than likely the inlet valve is bad and requires replacement. Please, read all instructions thoroughly BEFORE attempting. This is a simple repair that any "Do-It-Yourselfer" can accomplish. Follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. The inlet valve is located on the back panel with two or more sets of electrical connectors attached to it. The connectors are usually color-coded to indicate which valve is HOT and which valve is COLD (In the case of a Mixing Valve, you may have additional electrical connectors). Remove the connectors and check the contacts for corrosion. Sometimes a good cleaning can restore a valve solenoid to working order. (You may want to label the connectors, if necessary, to ensure you know how they go back on).
8. Disconnect the small rubber water hose(s) attached to valve with a pair of pliers to release the hose clamps. Inspect the hose(s) for any evidence of cracking.
9. With the water hose(s) removed, loosen the mounting screw(s) and the inlet valve comes off.
10. Re-install new inlet valve following these steps in reverse order. Pay careful attention to make sure you correctly connect the HOT & COLD electrical connections (RED is usually the HOT water side). Make sure all hoses are fitted back in place and the hose clamps are snug.
11. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
12. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
13. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
14. Reinstall console.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
SOURCE: Fisher/Paykel GWL10US washer. Blinking hot and
When they say replace the valve There,s a very good chance the diaphram is the valve is purferated or split (common Problem).But you can Remove the coil from this & with pointy nose plyers you can unscrew the top & inspect the diaphram If it,s ok give us a bit more info Hope this helps.Cheers.
Posted on Aug 10, 2009
Daniel S
  • 4323 Answers
SOURCE: I need to replace the water inlet valve on my
Hi
To access the fill valve take the two screws in the back that are connected. Now, pull the back of the cover towards you and lift it off. Check the three multicolored wires connected to the inlet housing that you have to remove. Next remove the two screws on the inlet housing. Now, pull the housing from the detergent cabinet then back towards it to remove the entire inlet unit. Check part# in this schematic---
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet washer How do I replace the bad inlet water valve"
It appears your timer/main controller/CCU has failed in this instance.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 30, 2010
Whats the difference between e10 and e11 error codes on frigidaire afinity f/l washers?
Thank you for your post, greg aguilar!
Both error codes "E10" and "E11" stand for fill time is too long on your Frigidaire washer. This could be an issue with the water pressure coming into your washer the psi must be above 30 psi. If it is not you may need to correct the pressure issue. If it is check to assure that the hose is not kinked or blocked. You may need to replace the water inlet valve, pressure sensor, or control panel. I would recommend having a professional technician come out to provide a proper diagnosis for repair. Hope this information is helpful to some degree. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
With an ohm meter how can you test the water inlet valve on a frigidaire afinity f/l washer?
If its a AC volt system, set meter to 120v AC. put a lead in each side of cold water valve wires. start wash on cold and should get 120v reading
Kenmore eco cycle front load washer. error E70 displays and stops washer. What does E70 mean?
You should check the model number of the washer. If the model number starts 417, then the washer was made by Frigidaire. In that case, the E70 error indicates that cold water is not being detected at the washer inlet sensor.
In some cases, this could be due to connecting the hot water line to the cold water inlet (and the cold water to the hot water inlet). Make sure that the cold water shut-off valve is open. Try swapping the water hoses (close the shut-off valves first). Try new hoses; some anti-flood hoses will restrict the water flow if they detect damage. Thus you won't have sufficient water coming into the washer. (You can check this yourself. Turn off the shut-off valves. Disconnect the hoses from the washer and put the ends into a bucket. Then open the shut-off valves and check the water flow.) While you have the hoses off, check for debris in the inlet filters.
If the hoses are fine, you probably have a problem with the washer's inlet valve or the reed switch that measures incoming water. The inlet valve should be replaced if you find that only hot water enters the washer.
I hope this helps. Please add a comment with the model number of your washer for more information. It will be on the inside of the door opening (probably at the top).
Sep 30, 2013 | Maytag EPIC MFW9700S Front Load Washer
Washer stops before final spin and flashes no water?
Possible that the inlet valve is not opening at the cycle to allow water for rinsing which can be due to a faulty program cycle.
Please check the inlet valve and the program harness.
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
Frigidaire gallery series Model GLGH42FS1 stackable washer leaking
see this causes and fix it. God bless you
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace the water inlet valve.
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is down under neath. To disassemble your washer follow the appropiate tutorial. Hoses can be tightened. If hoses or pump housing is leaking replace the pump assembly.
Tub Seal
This is in the center of the tub. The seal is inexpensive but will require some labor to install. Check the tutorials on disassembling the cabinet then remove the agitater and inner tub. Enter your model # above for a diagram or illustration.
Oct 11, 2012 | Frigidaire Washing Machines
I am getting E10 error code, there is no water going into washer.
Hi
Error E10 in Frigidaire washer means Long Fill. It means that the washer is taking a longer time to fill; it may be due to low water pressure, due to faulty pressure switch or due to faulty water inlet valve. Please try and clean the inlet filter screen. If this doesn't resolve your issue then check the connections at Water inlet valve. Make sure the connections at the fill valve are firm and check the continuity using multimeter. To access the fill valve take the two screws in the back that are connected. Now, pull the back of the cover towards you and lift it off. Check the three multicolored wires connected to the inlet housing that you have to remove. Next remove the two screws on the inlet housing. Now, pull the housing from the detergent cabinet then back towards it to remove the entire inlet unit. Hope this helps... Please post back if you need more information.
Daniel
Feb 11, 2011 | Frigidaire Affinity ATF7000E Front Load...
Washer does not water fill anymore???
Hi there....check that there is a water supply to the washer...(b) remove the fill hose from the washer and check that the inlet water valve filter is not blocked...(c)...Check that the water inlet valve is functioning
regards Sir Galahad
Aug 16, 2009 | Frigidaire FTF530FS Front Load Washer
HOW DO YOU REMOVE AND REPLACE WATER INLET VALVE ON FRIGIDAIRE LTF2140FS1
remove the screws holding the top panel on, they are located on the back at the top. Standing at the front of the washer, push top panel towards rear, then lift up and remove. Notice the water inlet valves on the rear left while facing the washer front. Unplug washer, then remove the mounting screws holding valve assy onto machine, on some fridg's there are 2 screws holding an inlet valve assy onto the dispenser underneath the valve assy, they are very hard to get to. Remove valve assy from washer and replace. Remember to mark wiring locations as needed.
Jul 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer
It's slow to fill Check to see if there's good water volume coming through the hoses attached to the washing machine. If there is, check to see if the screens inside the water-inlet valve are clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If they're clean, you probably have a defective water-inlet valve. If so, you should completely replace the valve.
There's no water at all If there's no water at all, make these checks:
  • Is there water getting to the machine?
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
May 04, 2009 | Frigidaire Washing Machines
Frigidaire washer {gallery series}
Close your inlet valve at the wall. Unscrew your washer hose to examine any blockage in the small filter screens; clean out thoroughly and refit carefully, check for any water leak on opening the valve fully. If you have 2 inlets for the machine it would be good to get an F or Y adaptor.
Pl rate if helped................
Jan 13, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
46 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
