Question about Motorola Radio Communications
<!-- from fixya rte -->How do I change frequency on Motorola pr860 - Motorola Radio Communications
  • Motorola Master
  • 1,654 Answers
The PR860 is programmed using Motorola proprietary software (available to dealers and some entities by subscription), a radio interface box (RIB), and cable. Easiest method is to visit your local dealer or send in to a nationwide repair center for programming.
Best regards.
Posted on Nov 19, 2014
  • Official Brand Answer
  • 1,623 Answers
Contact Motorola Solutions. portal motorolasolutions com for assistance.
Mark
Motorola Mobility Support
Posted on Nov 21, 2014
  • 3,100 Answers
Contact. Motorola Solutions.
Get Support
Mark
Posted on Nov 23, 2014
Cp150 frequency change
This is a programmable radio. Using Motorola proprietary software, programming cable and radio interface box (RIB) the radio can be reprogrammed to another frequency/PL Code. This can be done by your Motorola dealer.
Feb 12, 2014 | Motorola Radio Communications
How do I change and select channels and frequencies w my motorola axv5100 two-way radio? Can it communicate with a motorola talk about?
This radio comes with programmed channels and tone codes programmed into it. Should it still be stock the the diagram below is what you will use. The tones programed into are there to prevent someone on the same frequency from interfering with your conversation. It's a way of isolating the frequency. These are adjusted by the A,B,C,D You will know what frequency it is by the channel indicated. As for weather or not it will communicate with a Motorola talk about the answer is no. This radio is a VHF frequency and the talk about is MURS.
Regards, Tony
Channel - Pre-Loaded VHF Frequency (MHz) - Code (Hz)
1 151.6250 67.0 2 151.6250 77.0 3 151.6250 88.5 4 151.6250 179.9 5 151.6250 None 6 151.9550 67.0 7 151.9550 82.5 8 151.9550 94.8 9 151.9550 179.9 10 151.9550 None
Apr 17, 2011 | Motorola AXV5100 2-Way Radio
I own Motorola GP300 2 way radio.I need some device for changing frequencies as I needed.What equipments or any softwares to complete my need and their prices?
to change the frequency of your radio,you need programming cable/programming sofware,but this is only for authorized Motorola dealers,other options go to your nearest motorola dealer,along with your licensed frequency ,they'll program it,thank you
jack
Dec 02, 2010 | Motorola GP300 Compatible 2 Way Radio...
I have a Motorola Axu4100 , I want to change the frequence that I currently have on this radio to a Motorola CP-200...just wondeing if these two radio can work together....
Hi
Motorola CP-200 have frequency range
VHF: 136–162, 146–174MHz;
UHF: 403–440, 438–470, 465–495MHz depending on the model
Motorola AXU4100 have frequency range 435 - 480 Mhz
The first model has a wider frequency range so it is best to include transmitter Motorola Axu4100 to transfer and try to receive signal to Motorola CP-200
Sep 03, 2010 | Motorola AXU4100 (10 Channels) 2-Way Radio
XU2100 (1 Channel) 2-Way Radio: How do I change frequency on a motorola xu2100...
Hello, I just purchased 3 of the discontinued XU2100 radio's, Can someone help me to change the frequency on them? My email address is cubnboy@yahoo.com. Thank u for your time...
May 16, 2010 | Motorola XU2100 (1 Channel) 2-Way Radio
How can i change u.s. motorola radio frequency to u.k. frequencie
Sorry, but the freq range of these radios cannot be reprogrammed.
Bill B
Mar 19, 2010 | Motorola Talkabout T5500 (7 Channels)...
When I tried to change the frequency on my Motorola CLS 1110, I see a lock graphic. How can I get rid of the lock so I can change the frequency. Right now it has only 1 and 2 frequency and I need 4. Thank...
To unlock (or lock) your keypad hold the menu button in for 3 seconds.
Here is a link to the user guide. The CLS1110 is a 1 channel radio. It has several frequencies built in to choose from.
Dec 08, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Can i change the frequencies on my two way radios?
No, unfortunately there is nothing you can do to change the 462-467 MHz radio to do the PMR 420-450 MHz which is legal in the UK.
Here is some info concerning PMR446: http://en.wikipedia.org/wiki/PMR446
Apr 24, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
My phone wont connect to the network
did you use of 3g, or just you frequency is changed. with motorola you can select regime manualy and frequency too. try in phone settings to set frequency to auto and 3g too.
Jun 07, 2008 | Motorola Mobility A1000
Communications
Yes, but depends on the configuration/setup and programming/frequency assignation of the MTS2000.
To my knowledge, the UHF version of the Motorola MTS2000 are designed to operate either in the 403~470Mhz or the 450~512 or 520MHz band.
On the other hand, Motorola TalkAbout Radio are design limited to operate in the FRS band which is 462.5625~462.7250MHZ and/or the GMRS band which is 462.550~467.725.
So technically, both the MTS2000 and the FRS/GMRS share some frequencies. What needs to be done is to re-program the frequency allocation of the MTS2000 into its channels to match the TalkAbouts frequencies. The other way around is not possible. TalkAbouts frequency assignments can not be reprogrammed/changed. Below are typical TalkAbout Channels/Frequencies.de11c4e.jpg
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 04, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Radio Communications Logo
239 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
