Question about Ricoh Office Equipment & Supplies
RICOH MP 3350B ask for toner even having a new one
Some days ago it started making bad copies and delaying adding toner. As the machine has 168K copies made, I change the developer and put a new toner cartridge and started to work OK but only made 300 copies and now the error red light is ON and the msg ADD toner as well. I got some experience on MITA and Panasonic but not on Ricoh. Any help????
  • Copy Quick Digital
    Copy Quick Digital Nov 26, 2014
    how many copies on the drum? the developer could be worn out or the mixing gears could be broken or you may have the stopper from the old toner bottle still stuck in there.
    New Friend:
  • 4 Answers
Is there or was there a grinding noise? If so the gears on the magnetic roller in the development unit are shot. You'll need to replace them. Part numbers: B0393060 and B0393062. If those gears are in good shape then check the front of the development unit where the toner drops in. If it's overflowing then turn the gear in the back of the development unit with a pair of pliers. If it turns, there is a drive problem for the development unit. If it doesn't, replace the developement unit. If there is no toner in the front, check to see if the toner bottle turns. If it does, replace the toner hopper. If not, replace the toner bottle drive motor.
Posted on Dec 13, 2014
  • Ricoh Master
  • 10,291 Answers
Take out the toner cartridge and shake it vigorously. When they sit for a long time the powder tends to clump.
Posted on Nov 19, 2014
Testimonial: "Do I have to run a specific simulation telling the machine that I change the developer? Wich one?"
2 Suggested Answers
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Posted on Apr 11, 2009
After feeding toner, my Ricoh mp 5001giving bad result in coping. How to solve this problem?
remove the toner bottle and make around 50 copies but make the copies in A4 LEF but with open ADF and put a white paper on half of the A4 LEF area for to be the copes half white half black. This must be done for the extra toner that is inside the developer unit to be removed. It must be half black-half white for the machine can print the copies, otherwise it will constantly jams. pit the white paper in the right half section of A4 LEF area and make around 50 copies. But do this without toner bottle inside the machine. After the 50 copies end,print a counter and see does it got better. If is ok then return back the toner bottle and the machine will continue to work. If still the copy is bad then make more copies without toner bottle until the image is clear.
Apr 11, 2018 | Ricoh Office Equipment & Supplies
HOW DO I RESET WHEN adding a new toner cartridge
There is nothing to reset the toner will load itself unless there is another problem. Make sure the insert plug from the old bottle came out before you placed the new bottle in.
Jun 11, 2015 | Ricoh Aficio Mp161 Copier Photocopier Copy...
Ricoh mP 2018D Giving " adding toner "message always
that what it does to let you know that its adding toner
Apr 04, 2015 | Ricoh Office Equipment & Supplies
Ricoh Aficio 2852 copier is having depleted toner error after adding new toner
Clear modes- 107 -hold down C button machine will enter service mode, in case it does not, open the right side door and front door then give it a try, it will enter service mode,but the fact is that for a depleted toner error you don't have to fight so hard, don't tamper the SP mode settings you are likely to land into some other problem & things will get complicated further. Install a genuine Ricoh toner and replace the developer along with cleaning of the TD sensor if a non Ricoh or compatible toner has been used previously.
Jun 24, 2014 | Ricoh Aficio Mp 2852 B&w Copier
Add toner problem
If it is not adding toner there could be 4 possible causes, 1.make sure all the covers are closed, if they are not then the machine will not "run" to add toner. 2.Did you check to make sure there is enough toner in the toner bottle. 3. when the machine starts running/adding toner, can you feel a vibration or hear noise like gears grinding/slipping, if so, call a technician to replace drum/dev gears.4. when you open the toner tray/harper/hopper, at the bottom there is a flat silver sliding plate, when you slide it open, is there toner falling oout of that hole, if not, ask a technician to strip and clean the toner tray/harper/hopper.
May 01, 2014 | Ricoh Aficio MP 1600 Black and White...
Ricoh aficio mp 1600 add toner problem ?
If its not adding toner there could be 4 possible causes, 1.make sure all the covers are closed, if they are not then the machine will not "run" to add toner. 2.Did you check to make sure there is enough toner in the toner bottle. 3. when the machine starts running/adding toner, can you feel a vibration or hear noise like gears grinding/slipping, if so, call a technician to replace drum/dev gears.4. when you open the toner tray/harper/hopper, at the bottom there is a flat silver sliding plate, when you slide it open, is there toner falling oout of that hole, if not, ask a technician to strip and clean the toner tray/ harper/ hopper.
May 01, 2014 | Ricoh Aficio Mp-1600 Copier
How to clean Ricoh Aficio MP 2000
sounds like either drum blade has fail or drum is bad. try printing the counter report and see if it is doing this. Then photo conductor unit needs to be rebuilt or replace. open right side door and look at drum make sure you don't touch it and see if toner is on it. If so drum blade has fail. call a tech or buy new photo conductor unit. this are good for approx 60,000 copies but sometimes will go longer age also play with drum blade life. were you might have 20,000 copies but unit is 5 years old
Jan 31, 2012 | Ricoh Aficio MP 2000 Black and White...
I added the toner in ricoh aficio mp 1500 but is still saying that there is no toner
how many copies on the machine? to find out press the user tools goto counter
if it is over 60,000 you will need a new PCU you may also need a new toner hopper (toner cartrage holder)
Jul 26, 2011 | Ricoh Aficio 2015 Copier
My Ricoh Aficio MP 161 said to add toner but still won't copy
Check your old toner bottle and make sure the plastic "cap" is still in the bottle. These machines have an occaisional problem with the caps coming off (not the black screw off cap but the semi clear cap under the black screw off cap) and staying inside the black plastic "cup" that you insert the toner into. If the cap is missing it may be stuck inside this cup. If the cap is still in your old cartridge then try opening/closing the front door and letting the machine cycle to see if the toner light goes out. May have to do this several times. Had one customer just yesrday have to do this to clear the toner light after adding toner.
Good Luck.
Jan 28, 2010 | Office Equipment & Supplies
209 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
