Question about iHome Audio Players & Recorders
Does my ihome iH2 require batteries to run even when it is plugged in?
I can see the clock, but it will not turn on.
3 Suggested Answers
SOURCE: Sony Bravia TV Remote controls the iHome clock radio
I am as well, does anyone know how to change or fix it-- it is driving me insane!
Posted on Dec 22, 2009
SOURCE: my ipod turns itself on, even in the lokced
My ipod turns on in the locked position also.
Posted on Mar 23, 2010
My iHome keeps resetting the date, alarms, presets... everything! I fix it to how I had it, then two days later it resets itself again to January first, 2008..
Check that the power supply cable isn't broken. It could turn itself on and off by itself. If it has a battery backup use that.
Jun 05, 2011 | iHome Clock Clock Radio for iPhone iPod...
My ihome want charge my iphone 4
Your iHome may be an older model with an the wrong charge type. Different iPhone / iPod generations use different charge voltage with iPhone requiring a higher voltage than your iHome gives. My suggestion would be to get an adapter that should fix the problem.
Jun 02, 2011 | iHome iP90SK Dual Alarm Clock Radio for...
How do I program my remote for the ihome ... I lost the manual and I cant find it.
According to the manual the iHome IP90 line does not have a programmable remote. Have you checked the battery in the remote? It requires a CR2025 battery. The remote also has a 30ft. range, not sure if you are trying it at a further distance.
In any case, first thing I would do is to get a replacement CR2025 battery and give that a shot. If that doesn't work then the remote might be defective.
May 06, 2011 | iHome iP90SK Dual Alarm Clock Radio for...
My iHome is charging my iPod but won't do anything else. The clock face isn't working which means I have no alarm clock.
I just had this same problem, I removed the battery and my IHome now works
I hope this helps
Feb 25, 2011 | Audio Players & Recorders
My brand new ihome ip87 just stopped working. It will charge my ipod but it shows no clock and it won't turn on.
Mine is doing the same thing. So I looked it up. And it said to take out your iPod and unplug the ihome then take out the batteries from the ihome and leave it for an hour.. Then it will reset itself.. I just did it and it worked.. I also had to put in new batteries in the ihome
Jan 02, 2011 | Audio Players & Recorders
Ihome--ih8,
I got the iH8 as a present everything works fine except for the ipod alarm. the unit will play my music when i press the play ipod button, and recognizes its plugged in, but when i set the ipod alarm, without taking out the ipod or anything, it doesnt go off with my music, it just buzzes. Idont think it is the ipod because i have updated the software on the ipod and have even tried 3 different ipods with the iH8. i have had the iH8 for about 2 weeks and set it nearly every day, and out of all those times it has gone off with my music only 3 times. How do i get it to work every time!??
Jul 08, 2010 | iHome Ih8 Dual Alarm Clock Radio For Ipod...
Ihome ip9 will not turn on even with power chord attached. I have tried following what the manual says and unplugging it and that has not worked either. Any help will be appreciated
you might wanna try checking that the outlet actually works. try the outlet with something you know for sure works, like a lamp or something. if it works, then try the ip9 in a different outlet.
Mar 22, 2010 | iHome Clock Clock Radio for iPhone iPod...
Ihome won't play ipod, even after resetting ipod
When I first got my ipod touch and my ihome I had no problems and then all of a sudden everything worked except for the ihome wouldn't play music. It charged properly and the alarm and clock worked fine just the music wouldn't play. So I assumed it was the ihome and took it back and exchanged it only to get home and have the exact same problem. So I reset my Ipod and it worked. To do it you have to hold the sleep button until the red slider appears. Slide your finger across it to turn off. Press and hold the sleep button until the apple comes on. Next I sync'ed and looke dfor an update. After all this I docked it and it worked.
Jun 30, 2008 | Audio Players & Recorders
48 people viewed this question
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
