Question about 1982 Mercedes Benz 300D Instrument Cluster Bulb
Working on a 1982 300d Mercedes do not have glo plug light comer on on the dash. checked fuses all good, changed the glo plugs and having trouble keeping it running
    New Friend:
    Problem Solver:
  • 15 Answers
Check relay should be in engine compartment
Posted on Nov 19, 2014
Glow plug light in cab does not come on and small light in centre of instrument panel is no longer flashing
Check the relay for the glo plugs as it is not supplying power to the glo-plugs. Check that there is power getting to the relay. Check if a fuse is blown
Aug 15, 2015 | Cars & Trucks
Mercedes 300td wont start
It's likely a bad glow plug relay found on the left fender well. You may have bad glow plugs as well. You should hear a faint click when you turn the key to glow psn. . Open the hood and have someone glow it. The click should be abvious and the wires will run from the relay to the glow plugs. also obvious.
Oct 06, 2014 | 1998 Mercedes-Benz E-Class
Hard start cold
IF the engine is a diesel then have the GLO-plugs checked and the GLO-plug relay checked for correct operation. If not run fault codes to find which sensor is not working in cold weather
Oct 25, 2013 | Mercedes-Benz E320 Cars & Trucks
2002 mercedez-benz sprinter van schematics glo plugs
Hello try to measure the voltage at the glowplug wire with ignition on.
It must be at between 5 and 12 volts.
They need to be changed at 60000 to 80000 km.
Because at this mileage they are normaly burned out.
Each plug can drag 8 to 10 amps, when on.
If no reading volts, the glow plug relay, and maybe the plugs must be renewed.
There should also be a big fuse at the firewall, check that also.
Follow the glow plug wire, where it goes to.
Does the glow plug lamp light up in the dashboard ??
Are the relay clicking ???
Check also for blown fuses, resistors, or broken wires.
If you change the glowplugs, DO NOT overtighten them, not more than 15 NM !!!
Good luck
Sep 06, 2013 | Mercedes-Benz Sprinter Cars & Trucks
1993 Chey Van 30 6.2 Diesel Van. Looking Fuse block for glo plug fuse
There is no fuse. The glow plugs work on relays. If you are having trouble with the glow plug system then Haynes has an excellent manual for the Chevy 6.2. It is part # 10330, Haynes Techbook, Diesel Engine Repair Manual. It cost about $20.
Aug 29, 2013 | 1993 Chevrolet C3500
I had a failed tail light which I replaced but ever since then the glo plug warning light is constantly on but the glo plugs are fine and the car starts easily even on cold mornings on my 2002 C 270. How...
Dear Sir Glow plug light is on it didn't mean that glow plug faliuer, it mean the power supply is continusly on to glow plug, car will start good even incold condition,please check glow plug timer or show it technician ,but it can cause glow plug failuer in future. Thanks.
Oct 17, 2010 | 2002 Mercedes-Benz C-Class
Electrical wiring
You need to revisit the fuse box ,, there may be more than one ! If you think the dashlights fuse are intact , check by switching on/off the side lights while checking the fuse. The fuse beside the side lights fuse should also be a side light fuse. They are handed LH and RH for safety reasons and check you have both side lights in the front. Power locks may be a dash switch /plug connection. Worst case senario ,(temperarily) remove radio and remove any fault you may have introduced into the system . A small bulb type tester will be a great help ! Good luck
Apr 11, 2010 | 2005 GMC Sierra
2004 g35 coupe wont start. Is it the starter?
Hi there.
Firstly, have you checked that the battery is connected and has a charge in it? (This can be determined by looking to see if the dash lights illuminate when you turn the ignition on).
It could also be your spark plugs/glo plugs need cleaned or changed.
Another thing it may be is if the immobiliser is switched on.
Check all of your fuses.
Failing all of this, then yes, it could be your starter.
Hope this helps.
Oct 18, 2009 | 2004 Infiniti G35 Sport Coupe
1982 Mercedes Benz 300D Instrument Cluster Bulb Logo
65 people viewed this question
Top GE Vehicle Parts & Accessories Experts
ray012965
ray gallant
Are you a GE Vehicle Part and Accessory Expert? Answer questions, earn points and help others
