Question about Fujitsu LifeBook AH530 NoteBook
How can I clear a CMOS configuration in a Fujitsu AH530 ?
The problem is that i already took out the CMOS battery and so far only the time and date are reset. It still asking me for a password. And i can't find any jumper on the MoBo.
  • Fujitsu Master
  • 9,639 Answers
Place a short on the battery holder's + and - tabs for a minute or two. It has to be on long enough to discharge a capacitor on the motherboard. This will delete the bios password only.
Posted on Nov 19, 2014
mdsaeed67
  • 849 Answers
SOURCE: fujitsu n series n3530 lifebook
you need to open your laptop, you will find it on the motherboard, near the battery you will find the CMOS reset jumper or switch.
Posted on Oct 22, 2008
ianswer007
  • 75 Answers
SOURCE: Find the cmos battery in a Fujitsu Lifebook N3511
CMOS battery is located on the motherboard ...so you have to open the back cover of your laptop ...
Posted on May 11, 2009
  • 5 Answers
SOURCE: how to open the back panel of fujitsu AMILO D 7820
u can use the software herionee to change the password ...if not use the guide which is given to u with the lptp t
Posted on Feb 05, 2010
mariolands
  • 2296 Answers
SOURCE: I have a fujitsu e8110
To reset the BIOS password read the information from this link.
In your case I would suggest using Hiren's Boot CD as none of the others worked. There is a program called Kill CMOS which wipes the BIOS.
Posted on Jan 25, 2011
  • 102 Answers
SOURCE: I CANNOT ACCESS BIOS SETUP
Unlockbiosrecovery.com can unlock your bios for only $20 and they guarantee their work. Great service have used many times and they have always worked perfectly.
Posted on Oct 03, 2011
System options not set hp compaq dc 7600
Make sure your clear cmos jumper is not in the clear position! It is usually close to the battery and there is labelling on the mboard near it. If you're sure you didn't move it, then don't worry about that.Did you try setting the bios to defaults?
One possibility - it could be it does this if you don't re-set at least the date (and possibly the time) in the bios from the default it sets itself to when you remove the battery or use clear cmos - set it to today's date and time, or to anything other than the default, save settings.
If after you save the above settings, turn off the computer for a few minutes, and check the bios again, the date and time re-sets to defaults, then the cmos doesn't see the battery. If the date and time are consistant with what you set them to, it is seeing the battery.
By the way, I don't think this is the problem because you have the 162 error code, but make sure the battery polarity is right - is in the holder the right way - and the contacts for it are making good contact - if it is the wrong way or the contacts are poor, the cmos will think there is no battery. Usually you can tell by the way the contacts are arranged which way it goes - if it is the wrong way both contacts touch the same part of the coin cell (if that is what you have) - usually + is upwards.
If setting the bios to defaults, setting the date (to anything other than the default) does not get rid of the error message, try making sure everything on the board is properly seated. Unplug the computer when you do that!
.........it says memory error, below that it says 162 System Options not set, then it says 164 error.
(later)
I just took everything that would unplug and reset them in and it corrected the problem. Thanks
That error code is common on many computers, and in many bioses.
e.g.
161 POST Error - System options not set - (Run SETUP) - battery
162 POST Error - System options not set - (Run SETUP)
161 System options not set; dead battery
162 System options not set; CMOS checksum/configuration error
If it is 161 the battery is dead, it is installed with the polarity backwards, or the battery contacts are not making good contact.
If it is 162, there is nothing wrong with the battery - you need to go into the bios Setup.
I have found nothing other than the above post about what to do about that.
If you still have issues, go to and talk to one of our techs
Clean Optimize Speed Up and Secure PC Freeware Download EZ System Repairs
Oct 15, 2015 | HP Compaq dc7600 Small Form Factor PC...
Where can you find the CMOS battery for Fujitsu Siemens Amilo PI3625
On the web!
Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie - YouTube
? 6:39
www.youtube.com/watch?v=s8kKHChQ2sw
Oct 16, 2013 - Uploaded by MrHarsel Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie ... Fujitsu-Siemens Amilo Pa 3553 - Disassembly and fan cleaning - Duration: 16:09. by ...
Sep 25, 2015 | Fujitsu Computers & Internet
What.s the useful of cmos in this board
CMOS Battery powers the real-time clock and CMOS memory, which retains all the BIOS Settings including date.
CreativeTECH
May 04, 2011 | Compaq (203966-001) Motherboard
I have a Gateway laptop model no. M622-UCX which continues to prompt for the system date configuration in cmos setup during start. It also cannot remember the date and time I entered several times and...
When a laptop/computer prompts for a BIOS date and Time setting every time you boot up, this indicates the BIOS battey is flat or nearly flat. This BIOS battery needs to be replaced and the BIOS Date and Time setting needs to be configured etc.
Mar 14, 2010 | Gateway Computers & Internet
CMOS settings on startup
If u mean by the internal battery ..the icon battery which placed on the mainboard .. so u just need to prss F2 to adjust the current date and time .. and to get stable Download the bios update from fujitsu.com .
good luck
Nov 10, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Clearing cmos
The BIOS battery maybe under one of the panels on the bottom of the laptop or under the keyboard.
To reset the BIOS ack to the default settings, go into the BIOS configuration and look at the various configurations, usually there is a setting to load the Default settings, then save and exit, and this would not change the Date & Time setting.
The other way to set the BIOS default setting is to remove the BIOS battery (it is probably a lithium 3volt button battery), wait 1/2 hour and replace the battery, the go into the BIOS configuration and set the Date & Time setting etc.
Jul 04, 2009 | Compaq Computers & Internet
Clear cmos
You can reset the BIOS back to the default setting by going into the BIOS configuration and there should be a setting "Load default settings" then save and exit.
The other way to reset the BIOS is to remove the BIOS battery, wait 1/2 hour, insert the battery, then go into the BIOS configuration and set the Date & Time etc.
Jul 02, 2009 | Toshiba Satellite A305-S6863 Laptop
Motherboard with mistake in the initialization
after changing the battery the problem is suppose to stop but since it continues i think u have to set the date and then save the changes made after saving cos is not all about changing batteries most times too the new batteries u just bought may be bad as well. so set the date and time then save changes i think it shoukld work well.
thank u
May 29, 2008 | ASUS P4V8X-X Motherboard
Loses CMOS settings
there is a jumper near the board cmos battery. try to clear cmos by changing the jumper to the other position for some seconds (while power is off) so smos is clear.
turn the pc on hit delete to enter setup and load system defaults then exit saving configuration.
Nov 11, 2007 | ASUS P4S800D-X Motherboard
Fujitsu LifeBook AH530 NoteBook Logo
471 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
