Question about Coffee Makers & Espresso Machines
<!-- from fixya rte -->Does the fire need ventilation - Coffee Makers & Espresso Machines
    New Friend:
Yes a fire Needs oxygen to burn
Posted on Nov 19, 2014
My husband is sick - our hot water pipes are frozen, and I need to know how to start our all Pro Space Heater PLEASE!!
Where do you intend to place it? Important it will emit fumes so you need some ventilation, or you will get ill if indoors. Extreme fire hazard.
Jan 05, 2018 | Water Water Heaters
Must l have 5cm for ventilation between my hob and the cooker if the fan is halfway over a larger gap
yes
the reason for the large gap is to prevent flames setting alight to anything above it what has caught fire and allow you room to get a fire blanket over the flames
Dec 12, 2017 | Ovens
Am told that a cozymizer gas fire installed in conventional grate now requires additional ventilation. Only id marks on plate are "18N and input 9.6 kw. Can you advise?
I just happened to be looking at this site. I have just changed a Cozymiser for a Wonderfire (remote control). For fires over 7kw, you will need a vent in the room - which will cause a through draft. Our Cozymiser was 9.2 kw and without a vent, it was against regulations to use. These regulations came in after we acquired it in 1989! Our new 7kw fire is great and a vent is not needed.
Oct 10, 2011 | Heating & Cooling
Hi there We have a Trident Excel 549 RMN fire which was already installed when we moved in. British Gas will not service the fire as we do not have the manual. I would be gateful if you knew how we...
terry, I have to agree with you. There's very little out there concerning your model Trident Fire. However, I did locate a company by the name of Trident Systems Fireplaces in the UK. Here is their website link below and their contact information. Hopefully, they can help you.
http://www.trident-systems.co.uk/index.html
Apr 13, 2011 | Heating & Cooling
Error fan check message always appear when you turn the DVD on
Page 32 of the manual:
http://www.retrevo.com/support/Samsung-HT-Z510T-Home-Theater-Systems-manual/id/14714ci454/t/2/
Cooling Fan
The cooling fan supplies cool air to the unit to prevent overheating.
Please observe the following cautions for your safety.
Make sure the unit is well-ventilated. If the unit has poor ventilation, the temperature inside the unit may rise
and may damage it.
Do not obstruct the cooling fan or ventilation holes. (If the cooling fan or ventilation holes are covered with a
newspaper or cloth, heat may build up inside the unit and fire may result.)
So look at the fan and make sure it's turning. Pick out the dust balls. Give the system room to breath (Page 13: 4" clearance from the fan)
Feb 07, 2011 | Samsung HTZ-510 Theater System
Hello, I'm having problems getting a new gas fire fitted in my rental property. I have been quoted at £763. I already have a coal effect gas fire on the wall (no fire place) with a flue and obviously...
Older fires have an exhaust flue and get their air supply from the well ventilated room in which they're fitted. Balanced flue fires are the correct choice for rooms which lack sufficient fresh air ventilation. They have a flue which draws in outside air necessary for combustion whilst also acting as an exhaust for the combustion products. To work the appliance must be completely sealed so that no air is drawn from the room; the pressure of the incoming air and the pressure of the outgoing exhaust is equal so the flue is described as balanced.
The lack of a requirement for fresh air ventilation means that less energy is used; open outside vents let heat out as whilst allowing fresh air to enter.
Balanced flue appliances which exit directly through an exterior wall should cost very little more to fit than a regular appliance: the only additional cost may be in blocking up the old flue outlet and creating a new one but this rarely takes more than half an hour. A sealing collar is fitted to the outside of the flue (included in the flue kit) so there may be additional costs in hiring a ladder (or even erecting scaffolding) if you're higher than the ground floor.
Budget-level balanced flue fires typically cost between £350-£500 and the fitting charge may be fair depending upon your property, but it's also worryingly vague. A properly qualified and experienced gas fitter should be able to give you a precise quote and will already possess all of the tools needed to fit a new flue.
Also, ensure that you have your landlord's written permission to fit the new fire. If you don't then the landlord can claim that you have damaged the property and demand that you restore the property to original condition when you leave. If you get permission then you can also expect your landlord to insist that when you leave the property you do not take the new fire with you and that you supply an original copy of the gas fitter's installation certificate. Without this the landlord is within his/her rights to commission a safety inspection at your expense. Note that subsequent annual gas safety checks are required to be carried out by the landlord at his/her expense as per normal.
Oct 20, 2009 | Dryers
Fires one nail then just a puff
Check your gas. I had new gas with no pressure inside. When pressing the pipe of ventile, visible spray should come.
Oct 07, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Overheating too fast.
There's a cooling fan on the back. Is it clogged up or otherwise not turning when hot? From Page 21...
■ Make sure the unit is well-ventilated. If the unit has poor ventilation, the temperature inside the unit
may rise and may damage it.
■ Do not obstruct the cooling fan or ventilation holes. If the cooling fan or ventilation holes are covered
with a newspaper or cloth, heat may build up inside the unit and fire may result.
May 04, 2009 | Samsung HT-X40 System
My dryer won't start
Probably a lint blockage of some sort. To prevent fires the manufacturer of this dryer places numerous safe guards to prevent fires. If the dryer does not rub at all then you need to replace the fuse. You also need to clean the dryer lint out or you will just be buying fuses. The fuse looks like this:
52f663d.jpgb4c1945.jpgLocation is in the rear on the blower housing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 07, 2009 | Whirlpool LER3624JQ Electric Dryer
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
