Panasonic eco drive inverter 9 kg washing machine NA-FS90X1 HAVE A PROBLEM AFTER I SWITCH ON THE MACHINE. I ALREADY PRESS START BUTTON BUT IT CANNOT RUN. IT DISPLAY H09
  • 101 Answers
SOURCE: How can I fix my Hoover Washing Machine, model H130E?
which light?
Posted on Apr 23, 2008
SOURCE: Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
Posted on Feb 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: instruction manual for a beko 1512s eco care washing machine
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!
Posted on Sep 16, 2010
SOURCE: Please I have got error
This is a code for an internal leak. Same happened to us today 2 weeks after buying the machine from John Lewis. We had a small pool of water appear in front of trhe machine. Waiting for Panasonic to sort out a repair.
Posted on Feb 11, 2011
SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Posted on May 22, 2011
The error code H 01 in Shows my washing machine(panasonic na-f70gs)
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3328-panasonic-na-series-washing-machine-fault-codes.html
H01
Pressure sensor or level switch detected as out of range
  • Check wiring to level sensor
  • Check pressure switch is not defective
  • Replace pressure sensor
  • Replace main power PCB
Apr 06, 2015 | Washing Machines
Error code h20
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Mar 26, 2014 | Ariston Technologies AW 129 NA Washer With...
I have panasonic eco drive washing machine model NA-FS14x1 have error code H57 how to repair
Unscrew the back of the machine to look and see if there is any water in the base of the machine.
How old is your machine? If it's new I'd exchange it for another one like the LP or even Mag tag-
It's not easy to fix these machines and finding the real problem is sometimes a night mare.
The Panasonic error codes are difficult to find, but 'H' faults are generally faults which may or may not be repairable. Like the sump pump -or motor.
The other codes are like this: U11 indicates machine unable to drain. Blockage between drum and drain pump?? Blockage of drain hose??
U13 indicates unbalanced load. Many modern machines suffer from this, but may be related to problem causing U11 fault.
H43 indicates an internal water leak reaching its detector in the machine base.
Like any washing machine, they are great until they go wrong. The problems are usually related to the after sales service.
I hope something helps here-just my 2 cents worth!
Dec 23, 2012 | Dryers
How to do manual setting for Panasonic Washer NA-F701GS
I keep program to normal, water level 51 and wash,rinse & spin but half way the washing machine go to reserve button (9 hrs).
how do i cancel the reserve button?
Nov 28, 2010 | Panasonic Washing Machines
Hi when i strart the washing machine on it does its normal thing for about two to the minutes and then it shuts it self of . to get it to work again i have to switch off and back on the power piont and...
Hi just read your posting.Now does your machine show an ERROR CODE? After you have restarted your machine does it go throe the complete cycle?Please reply with additional information on the questions and I am sure I can help you on this problem.
Aug 10, 2010 | Fisher and Paykel Washing Machines
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
The machine stops at wash cycle every minute or so
Firstly, the model 708 is way more than 9 years old. More like 18 - 19 years old. There is 2 types of errors on a smartdrive. One is signalled by a single beep every second & the top row of lights will change. The 2nd is a rippling musical sound (like when you turn the power on at the wall) and some lights will be blinking. You need to tell us what sound it is and which lights are blinking or which of the top row lights are on (exactly, count from the right to left and which number is on & which is off) There is no such thing as a reset to do. Once I know the fault I can advise you what to do about it.
Mar 10, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Fischer Paykell 7.5kg Smart Drive top load washer
Have you checked the lid micro switch under the motor controller which activates when you close the lid to start the machine?
Jul 24, 2008 | Fisher Paykel EcoSmart GWL15
Washing machine not working
Before switching the "on" switch select your programme, ie whether you want spin, wash, etc. Then put the "on" switch on.
Mar 02, 2007 | Ariston Technologies AW 129 NA Washer With...
Washing Machines Logo
239 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
